Front fender squeaks...and I broke the clip....Damm! - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > 2nd Generation (2005+)
2nd Generation (2005+) Discussion area for the 2nd generation of the Toyota Tacoma
Old 08-07-2006, 11:53 PM   #1 (permalink)
myt90's Avatar
View myt90's Photo Gallery
When washing the truck, I accidently found the drive side fender was squeaking; out of curiosity, I tried to look for any loose bolts/screws under the area so I might be able to secure the fender and stop the squeak.
I removed the six screws that held the fender flare to the inner fender and tried to remove the flare, first "pop" - I got the flare loose at the front end but I broke the clip. I stop trying 'cause I don't want to break any thing else.
Anyone here had experienced with the front fender flare removal, please enlighten the trick to remove this damm piece, thanks in advance for your advice.
myt90 is offline   Reply With Quote
Old 08-08-2006, 12:10 AM   #2 (permalink)
TacoSport05's Avatar
View TacoSport05's Photo Gallery
i noticed that my passenger-side front fender squeaks- right behind the headlight. I noticed it about a month after I got it (15 months ago) when I leaned on it while washing. That's the only time it squeaks. Probably some fender bolt that is not adequately torqued. It has not bothered me enough to get it fixed. IMHO, the dealer would probably do more damage trying to remove the front bumper and fender just to get to one bolt that is loose. I'm just gonna leave it.
'05|V6|4x4|Access Cab| TRD Sport| Tow Pkg
TacoSport05 is offline   Reply With Quote
Old 08-08-2006, 12:43 AM   #3 (permalink)
myt90's Avatar
My pass-side is Ok'ed, so this tells me that the squeaks is unsual. I had the same thought like you said "the dealer would probably do more damage trying to remove the front bumper and fender just to get to one bolt that is loose." Therefore, I tried to do it myself, because I've done things like this with my older Tacoma truck; comes to find out my skill needs an update :.
Old 08-08-2006, 06:49 AM   #4 (permalink)
Hobby or Mental Illness?
FRiZzO's Avatar
View FRiZzO's Photo Gallery
My passenger side was squeaking, till I got my friend to shake the truck as I layed underneath. I couldn't hear it. Then he says its up hear some where. I was WTF! Long story short, f-in antenna wasn't screwed in all the way and it was making a very loud scratching squeaky clothes line noise.
2005 Tacoma Access Cab, Super White, TRD Off Road package, Production Date:07/01/05 //// Viper 791xv Alarm/Remote Start / Panasonic CQ-C5310U // K&N Intake with AEM Dryfilter // TRD Exhaust // Toyota Hard Cover
FRiZzO is offline   Reply With Quote
Old 08-08-2006, 09:23 AM   #5 (permalink)
Cincylance's Avatar
View Cincylance's Photo Gallery
I too have an annoying squeaky noise coming from my front end on the passenger side. I'll have to check the antenna. It makes the noise just driving through a minimally rough parking lot. I've had it on a lift and inspected everything I thought it might be, but haven't found it. I had the same thought about taking it to the dealer--they'll do more harm than good. Sad.
My buddy had a wind noise coming from the sunroof in his new 4Runner. He took it to the dealership where he bought it to have it fixed. The dealership put some kid on it and when my buddy got it back, the wind noise was still there AND they put a crease in his headliner and put a 8" scratch in his center console. They also forgot to put some of the screws back in the side panels! He was furious. He complained and the dealership eventually made everything right, but it took at least 5 trips in total. Don't assume just because you are taking it to the dealer that it will be done right. He said he showed the kid the things that were f-cked-up and the kid just shrugged his shoulders, like "so?"
I'll put up with the squeaky noise for a while before I take my new truck to the dealership where they'll put some young, inexperienced kid to work on it.
Cincylance
Cincylance is offline   Reply With Quote
Old 08-08-2006, 12:11 PM   #6 (permalink)
I stepped in what?
View musclemag54's Photo Gallery
mine squeakes on both the driver and pass side of the truck right behing the headlights. The only time mine does it is when I wash it, geuss it's not to much to worry about
musclemag54 is offline   Reply With Quote
Old 08-08-2006, 02:48 PM   #7 (permalink)
myt90's Avatar
Thanks for responding
With all responds here, I guess I'll deal with the squeaks and hoping that none of my friend will "accidently" lean/push on that darn fender behind the head light to cause it squeaking; otherwise it'll be an endlesstalk of the truck since I've been bragging sooooo much of how good Toyota held up its quality .
Old 08-08-2006, 03:09 PM   #8 (permalink)
Pb
Surfing TN via iPhone
Pb's Avatar
iTrader Score: 15 reviews
View Pb's Photo Gallery
The overfenders are supposed to fit loose. They're cushioned by that rubber strip. A strong stream of water might get some dirt out of the joint and stop the squeaking.
Pb is offline   Reply With Quote
Old 08-08-2006, 03:11 PM   #9 (permalink)
My name is Blake
View NorCalTacoma's Photo Gallery
I'm squeaking here too.
NorCalTacoma is offline   Reply With Quote
Old 08-08-2006, 03:14 PM   #10 (permalink)
Pb
Pb's Avatar
Does it just sqeak when you push on it?
Old 08-08-2006, 03:15 PM   #11 (permalink)
My name is Blake
Yes.
When I push on it I can hear some squeaking. It's only on the passenger side though.
Weird as hell.
Old 08-08-2006, 03:22 PM   #12 (permalink)
My name is Blake
You know what?
I just went outside to double check and it's not my entire fender that squeaks.
It's the part of the fender closest to the headlight and the piece under the headlight.
Old 08-08-2006, 03:28 PM   #13 (permalink)
Pb
Pb's Avatar
So stop pushing on the fender.
Old 08-08-2006, 03:30 PM   #14 (permalink)
myt90's Avatar
Yes, the fender (not the over fender/flare) moves when lean to/push against it. However, the passenger side is firm solid.
Old 08-08-2006, 03:32 PM   #15 (permalink)
myt90's Avatar
Originally Posted by NorCalTacoma
You know what?
Same exact spot but on opposite side on mine.
