DRL - Daytime Running Lights - Yet another variation W/Pics - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > 2nd Generation (2005+)
2nd Generation (2005+) Discussion area for the 2nd generation of the Toyota Tacoma
Old 11-10-2006, 11:08 AM   #1 (permalink)
I Drink your Milkshake
GTCOMA's Avatar
View GTCOMA's Photo Gallery
I did this mod this morning. It took parts from a few different people. I wanted to keep it simple and Clean! Here is how I did it.
First I bought the recommended connector that fit in the spot where the blue plug is
I bought extra 16g wire, Butt connectors with heat shrink & Crimp connectors
i connected the wires
Wrapped it in tape
Then I poked out the blue plug and put in the new connectors
Then I zip tied all the wire
Then I put the crimp connector on the green wire to the marker lights. I also used a little bulb grease to waterproof the connection
And here is the finished product
The first pic is the normal running lights, the second has the flashers on (caught mid flash) and the last is all of the lights on
The whole thing took about an hour and a half taking my time. I like how it turned out.
GTCOMA is offline   Reply With Quote
Old 11-10-2006, 11:38 AM   #2 (permalink)
need to find money tree
View amp2oo1's Photo Gallery
Do you have any pictures of how you mounted your front license plate?? I hate having mine on the bumper like it normally is. Do you ever get hasseled for having it down so low?
No more truck...
amp2oo1 is offline   Reply With Quote
Old 11-10-2006, 02:09 PM   #3 (permalink)
GTCOMA's Avatar
I'll have to take some pics. I made a frame out of aluminum angle stock and stainless hardware. Here is a quick drawing of the frame. The upper corners mount to the excess threads on the bumper bolts with two extra nuts
Old 11-10-2006, 02:21 PM   #4 (permalink)
musubi's Avatar
View musubi's Photo Gallery
wow...interesting stuff!
1991 Pickup, V6, 2wd, 5sp, Ex. Cab.
2008 Nismo 350Z
2006 4x4 6 sp. OR DC (Sold)
musubi is offline   Reply With Quote
Old 11-10-2006, 02:42 PM   #5 (permalink)
blubalz
View tarandus's Photo Gallery
sweet. that is exactly how I want to do it. have you considered doing the fog light mod?
2006 Taco 4x4 Off Road . OME struts Rear AAL with 1" blocks WeatherTech mats, Grillecraft and emblem, WO seat covers, OEM roof rack, OEM tube steps
2005 Taco DCab 4x4 Indigo
2002 Taco DCab 4x4 Lunar mist
1997 T100 Xtra cab 4x4 blue
tarandus is offline   Reply With Quote
Old 11-10-2006, 03:15 PM   #6 (permalink)
GTCOMA's Avatar
I think I am going to keep the foglight function stock. i just wanted the running lights that would actually show up, since the corner lights are so dim.
Old 11-10-2006, 03:35 PM   #7 (permalink)
blubalz
Very good. Do you happen to know the part # for the connector? How much$$ Did you look at other options like Radio Shack for parts?
Old 11-10-2006, 05:18 PM   #8 (permalink)
Tina come get some ham
R0dzilla7's Avatar
Gameroom cash: $201750
View R0dzilla7's Photo Gallery
excellent write up. I may actually try this one. thanks for the info
[SIGPIC][/SIGPIC]
R0dzilla7 is offline   Reply With Quote
Old 11-10-2006, 05:23 PM   #9 (permalink)
View littleblue's Photo Gallery
Doesn't that mess up your approach angle?
littleblue is offline   Reply With Quote
Old 11-10-2006, 05:31 PM   #10 (permalink)
View Nhayden51's Photo Gallery
So does the black 16g wire go into an empty fuse slot or do you cut it off at the end of where you had it crimped to the green wire?
Nhayden51 is offline   Reply With Quote
Old 11-10-2006, 05:33 PM   #11 (permalink)
Nevermind. That was my dumbass fault for not looking carefully. Genius, pure genius
Old 11-10-2006, 07:20 PM   #12 (permalink)
GTCOMA's Avatar
It is actually tucked up in there petty tight. It might take a degree and half off my appraoch angle, but it doesn't reallt impact my suburbanite uses. I did drive it sraight up a pretty steep berm for kicks when I first installed it and it didn't even come close to touching
Old 11-10-2006, 07:25 PM   #13 (permalink)
GTCOMA's Avatar
I did look at a few autopart stores, but they only had the domestic parts and non of them have the built in seal. The part # is 82998-12440 and they cost $6.01 each. Kinda pricey, but I was willing to pay it for the perfect fit. When I ordered them they told me they were on national backorder, but it still only took 2 days to get them in.
Old 11-11-2006, 01:35 AM   #14 (permalink)
I just did your way of the DRL mod today. It came out real nice but I was hoping for it to turn on once my key was turned. It is also pretty dim until you signal and I wasn't too fond of that either. I was actually looking into it being bright right off the start maybe the side amber to signal, so I probably will rewire the entire mod and start all over.
Nice setup though but just not the way I want it to be.
Old 11-11-2006, 01:46 AM   #15 (permalink)
Hey There...
OneMnk's Avatar
View OneMnk's Photo Gallery
There is another write up for that which involves directing the wires directly into the fuse box under the dash. Similar but a little more time consuming.
- 2005 Taco, Trd Exhaust, Trd CAI, Tint, Blacked out Emblem, Debadged, Eclipse AVN 5500 -
- 3" Toytec/OME Lift, 285/70/17 BFG M/Ts on 17x9 Blk Moto Metal 951s -
OneMnk is offline   Reply With Quote
Daytime Running Lights - 2006 southof30a Sequoia Forum 3 02-18-2007 05:03 PM
Disabling Daytime Running Lights ??? GogglesPaizano 2nd Generation (2005+) 24 10-31-2006 10:17 PM
Adding Daytime Running Lights to 97 Avalon bobcrane 1st Generation (1995-1999) 2 04-24-2006 01:11 PM
Daytime Running Lights abercrombietoy Archived Corolla threads 4 10-22-2002 09:18 PM
Daytime Running Lights abercrombietoy General Discussion 0 10-13-2002 05:29 PM
