Originally Posted by Mike5150
I have run into a few CDs that I have burnt that will not play on the stock unit and they play fine on everything else.
I believe you may have burned them using an option labeled burn in disc-at-once mode or something simliar. Some devices aren't compatible with it. It helps to keep the volume equal from track to track.
This 'may' be your problem.
What software did you use to burn it? I use Nero for all my burning needs and I've never had a problem. Well, the one version that was put out recently had a bug it in where burned CDs would skip, even after they were freshly burned.
Trail Rig: '85 Pickup - Dual Cases - 5.29s - Rear Spool - 38" Creepy Crawlers - Internal Cage - Partial Exo - 30 Spline Longs
Tow Rig: '06 D-Cab Offroad - She gets me places...
