Rear Chrome Bumper Question: - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > 2nd Generation (2005+)
2nd Generation (2005+) Discussion area for the 2nd generation of the Toyota Tacoma
Old 11-13-2006, 06:03 PM   #1 (permalink)
View samcollett's Photo Gallery
i have a nasty ding in my rear bumper from about two months ago. a guy with an f250 backed into me and dinged my bumper with his trailer ball as i was walking out of Lowe's. well, i've been putting off fixing it, and it's like 350$ for a new bumper, so today i tried to take it off to hammer it out with a hammer and a 2x4. i think the black clips that hold the composite bumper covering on could not be more inconveniently placed. has anyone removed their rear bumper? and if so, do you have a service manual/guide? how did you get the clips up through the chrome to take off the composite? by the license plate and such). this is the only visual cosmetic damage my truck has (aside from a dime sized ding in the tailgate) and i want to hammer it out this weekend. thanks guys.
also, if anyone has a chrome bumper for sale for cheap, let me know.
samcollett is offline   Reply With Quote
Old 11-13-2006, 06:48 PM   #2 (permalink)
need to find money tree
View amp2oo1's Photo Gallery
why isnt the guy with the f250 paying to fix it?
No more truck...
amp2oo1 is offline   Reply With Quote
Old 11-13-2006, 06:52 PM   #3 (permalink)
he drove off. it happened right as i walked out the door and i saw him back into it, and then drive off.
Old 11-13-2006, 06:59 PM   #4 (permalink)
Banned
BillBrasky's Avatar
iTrader Score: 12 reviews
View BillBrasky's Photo Gallery
1) Remove license plate, disconnect and remove lights. Don't forget the little orange insert for the light housing screw (if you are swapping bumpers). Use a pair of pliers on these from the back side.
2) Pry open the square covers over the "push-in"-type clips in the lower pad/lower step, and use the tool of your choice to pry up the 2 clips. The square covers pry/flip to the outside.
3) Remove the 2 bolts (IIRC 10mm) on the lower section (underneath) of the lower pad/lower step. Remove lower pad. This reveals 2 (IIRC 14mm bolts)
4) Remove the spare tire. It is worth the effort in the long run. Stay under the truck.
5) Using a pair of needle-nose pliers, compress the clips holding the upper pad to the bumper and push them upwards. Once all the clips are free, while you are down there, remove the (IIRC 4 10mm) bolts that hold the bottom of the bumper to the frame.
6) Get up. Remove the upper cap from the bumper. It should be loose, but if not, just give it a quick pull at the clip points. This will reveal 4 (IIRC 14mm) bolts securing the top of the bumper to the frame.
7) remove the 6 14mm bolts (the ones under both caps) holding the bumper to the frame. Pull bumper out towards you to remove.
8) Once the bumper is free, remove the corner braces/brackets and covers/caps.
9) Reinstall in reverse order.
BillBrasky is offline   Reply With Quote
Old 11-13-2006, 07:47 PM   #5 (permalink)
thanks a lot man. i appreciate it.
Old 11-13-2006, 07:59 PM   #6 (permalink)
I Drink your Milkshake
GTCOMA's Avatar
View GTCOMA's Photo Gallery
It's not too bad. I think I could have mine off in about 10 minutes. I backed into a light pole at Taco bell and dinged my color matched silver streak mica bumper a month after i bought my truck. I was so pissed at myself, but I went ahead and bought a new Chrome bumper to replace it. Two months after that i was driving in the mud in my new neighbor hood and backed into a 2x4 stuck in the mud in the tall grass. And dinged my new bumper in the exact same spot. Again, very pissed at myself.
So I took it off again and massaged it out with a few C clamps and some soft wood. it came out pretty well, but I pretty much decided that it is destiny that i have a small dent in my bumper. After all, it is a truck.
GTCOMA is offline   Reply With Quote
Old 11-13-2006, 08:05 PM   #7 (permalink)
how did you go about getting it out with the C clamps? i was just going to hammer it out with a 2x4 and a hammer.
Old 11-13-2006, 08:08 PM   #8 (permalink)
Banned
BillBrasky's Avatar
Sure thing.
It is pretty easy. I just swapped bumpers Friday.
Old 11-14-2006, 08:54 AM   #9 (permalink)
GTCOMA's Avatar
I just used a giant c clamp and a peice of wood on both sides of the bumper so it wouldn't scratch it or leave a circular impression. I had a pretty clean vertical dent and I just worked my way up the crease. It does not look perfect, but nobody notices it until I point it out.
You can kinda see the after in this pic. Just look at where the reflection of the ground takes a dip on the left side
Old 11-14-2006, 05:17 PM   #10 (permalink)
cool. i have a couple of smaller C clamps that i think should make it around the bumper edges. i'll try it this weekend.
Old 11-14-2006, 05:21 PM   #11 (permalink)
Stupid is stupid does
lotust's Avatar
View lotust's Photo Gallery
I hate people that drive off. I dove a county parks truck into some Aholes 3 foot ball hitch extension, I just crincled the plate on mytruck though. Of course I did not damage that guys truck Ever walk into a hitch ? Ouch!
Good luck with the dent though.
295/65/18 Goodyear Duratracs:2.5" lift in the front with 1" rear Block
JBA single exhaust:HID's W/Led's inside:Nfabs
E&G grill insert:ARE Z topper:Overhead DVD for my son:Front DVD for me
lotust is offline   Reply With Quote
Old 11-14-2006, 05:27 PM   #12 (permalink)
My name is Blake
View NorCalTacoma's Photo Gallery
Get it popped by a PDR for super cheap.
Access to the dent on the bumper is a joke, should not cost more than $50.
NorCalTacoma is offline   Reply With Quote
Old 11-14-2006, 05:48 PM   #13 (permalink)
i've talked to two dent removal guys around here about my tailgate, and both were complete jerks. one lectured me about how intricate his work was and that i couldn't expect him to be done in three days, but it would cost 110$, and the other thought i was stupid for denting my tailgate, and wanted to charge me 90$.
Old 11-14-2006, 06:47 PM   #14 (permalink)
GTCOMA's Avatar
I checked in to the PDR for my bumper, but the guy said he could not do it. the metal was too thick and they don't do chrome finishes.
Old 11-14-2006, 06:48 PM   #15 (permalink)
i've also talked to them about my bumper, but they said if they fixed it, it would look worse than it did dented.
Whiteline; Superpro and Dobinson Group Sale ...PART II raptorracing Supporting Vendor Sales 93 05-02-2007 05:02 AM
Whiteline; Superpro and Dobinson Group Sale raptorracing Supporting Vendor Sales 222 03-09-2007 05:51 AM
2005 Chrome rear bumper 4 sale 55reasons 2nd Generation (2005+) 3 10-21-2005 12:56 PM
