Transmission Fluid Accident - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > 2nd Generation (2005+)
2nd Generation (2005+) Discussion area for the 2nd generation of the Toyota Tacoma
Old 11-13-2006, 08:40 PM   #1 (permalink)
View LinhDuyVo's Photo Gallery
What up Peeps,
I wanted to post this because I screwed ROYALLY when i TRIED to change my oil. I was on the computer for hours trying to find how to fix it and the whole process takes less than 20 min. First-off when you change your oil,the oil pan is kinda hidden. Therefore I drained my transmission instead of my oil. Anyways if this happens to you, replacing the "drained" transmission fluid is SUPER easy. (it took me three hours because i had to surf through the web to find the anwser). anyways, directly behind the TRANSMISSION pan is the actual transmission (its gray and almost cone like). it would be easy to identify once you are under the car. on the left side (if you are and your taco are face to face) is a huge, obnoxious screw. you cant miss it. The size of the screw is 24mm and you can purchase the bolt at your local hardware store. The dealers sell the bolt for 50 bucks. I went to Lowes and bought the wrench and bolt for like 20 bucks. ONce you get that bolt, screw that scew off and then PUMP transmission fluid into the transmission. if you totally emptied the transmission, the amount should be 4 bottles. but this whole process is dummy proof. if you dont know how much to add, it will start to ooze out of the hole if there is too much. If it oozes out, that means stop.
the reason i say pump is because you literall have to pump it. you can buy the pump at the auto store for pretty cheap. I bought mine for six bucks. its looks like a lotion pump with a long tube. well good luck. i dont think i missed anything. I believe that you can find some pictures on tundrasolutions.com. i would link you guys, but i had to reformat my comp. sorry....hopefuly my explanation helps. goodluck
LinhDuyVo is offline   Reply With Quote
Old 11-13-2006, 09:11 PM   #2 (permalink)
View jiminabqnm's Photo Gallery
urasmart1
good job.
jiminabqnm is offline   Reply With Quote
Old 11-13-2006, 09:33 PM   #3 (permalink)
Scratchy's Avatar
View Scratchy's Photo Gallery
Originally Posted by LinhDuyVo
...if you totally emptied the transmission, the amount should be 4 bottles. but this whole process is dummy proof. if you dont know how much to add, it will start to ooze out of the hole if there is too much. If it oozes out, that means stop.
Mine only took 2 bottles.... you must have really small bottles
The 6 speed MT actually takes 1.9 quarts. Using Redline MT-90 makes it shift smooth as silk.....
Scratchy is offline   Reply With Quote
Old 11-13-2006, 09:43 PM   #4 (permalink)
Pb
Surfing TN via iPhone
Pb's Avatar
iTrader Score: 15 reviews
View Pb's Photo Gallery
I don't think the oil pan is hidden. If you slide under your truck from the front then it will be right there in front of the cross member. It's not a big flat oil pan, like many domestic trucks have. It takes a 14mm socket or wrench to remove the oil drain plug. The transmission is behind the crossmember.
Pb is offline   Reply With Quote
Old 11-13-2006, 09:45 PM   #5 (permalink)
View MADTACO05's Photo Gallery
Do you have an 05+
DR Coilover & Resevoir/3" PA BL/17" Centerlines W/35" BFG A/T
K&N/AEM Hybrid Intake, FM 40 Sries Catback,Deaver 10 pack
PSC1003 URD Tuner/T-REX 5 Piece Grill-Precision 4:56 gears
TRD Seat Covers, Clarion Dbl Din, XM Shy Fi
2 10" Rockford's In Custom Box, Alpine 400 watt AMP & more!
MADTACO05 is offline   Reply With Quote
Old 11-13-2006, 10:24 PM   #6 (permalink)
SP Jon M3's Avatar
View SP Jon M3's Photo Gallery
Originally Posted by MADTACO05
Do you have an 05+
^ x2
If you have an '05+ with and Auto trans then stop driving your truck immediately! You are gonna destroy your transmission. This is not a fillerup until it starts coming out. There are three plugs for this. A drain plug, the Fill plug, and the check level plug. You basically fill the trans while the truck is running and fill until fluid starts coming out of the check fill plug. The trans needs to be at 140 deg f .
Not only that, you need to use actual Toyota ATF WS fluid. It's different than normal ATF or any Synthetic ATF. The WS is about $40-50 for a jug of it.
Here is the actual Toyota repair manual to change the trans fluid on an '05:
http://web.mac.com/jbryan/iWeb/Stuff...id_Change.html
Jon
'05 Double Cab 4x4 V6 SR5 Auto White
Mods: Fabtech DirtLogic 2.5 coilovers and Total Chaos UCAs up front, Deaver springs and Bilstein 5150's in the back, American Racing Mojave 16x8, BFG M/Ts 265/75/16, Demello Bolt-on sliders.
'01 Double Cab 4x4 V6 Auto TRD Black, you will be missed.
SP Jon M3 is offline   Reply With Quote
Old 11-13-2006, 10:39 PM   #7 (permalink)
Playoff bound, 8 long yrs
zmtnbik's Avatar
View zmtnbik's Photo Gallery
Originally Posted by SP Jon M3
^ x2
I would assume he can tell the difference between 90w gear oil and ATF...then again he thought he was draining his oil.
For starters, I've never seen a 24mm engine oil plug, those are usually reserved for rear differentials, and as we now know, transmissions.
I changed my oil this weekend as well, my 1st oil change and had no problem locating the drain plug, as it was right where I thought it would be, the bottom of the oil pan, infront of the bell housing.
Not to sound like an a$$...but maybe you should leave the mechanical work on the truck to the professionals. $35.00 would have saved you several hours of wasted time.
2006 4x4 Access, V6, 6spd, TRD Off-Road, tow pkg. Donahoe Co's, TC UCA's, Dakar leafs, 5125's in the back and u-bolt flip kit. TRD exhaust, CAI. URD MAF calibrator. 17x9's, 285/70/17 BFG MT KM2. Locker-mod, fog mod and console vault.
zmtnbik is offline   Reply With Quote
Old 11-13-2006, 10:40 PM   #8 (permalink)
View neoseekers's Photo Gallery
Oh Boy. Looks like a "Transmission Fluid Accident"
neoseekers is offline   Reply With Quote
Old 11-13-2006, 10:41 PM   #9 (permalink)
^ x2
Yeah thats why I asked, very bad mistake
Old 11-13-2006, 10:43 PM   #10 (permalink)
Tacoholic
currentsupply's Avatar
View currentsupply's Photo Gallery
The only difference between the transmission fluid plug and the oil pan plug is that the transmission plug right in the middle of the transmission.
'06 ACCESS CAB V6 MANUAL PRERUNNER TRD
currentsupply is offline   Reply With Quote
Old 11-13-2006, 10:46 PM   #11 (permalink)
SP Jon M3's Avatar
The problem is is that you don't use ATF in ythe '05s. You have to use the Toyota "ATF WS". It's not normal ATF fluid.
Jon
Old 11-14-2006, 01:36 AM   #12 (permalink)
Self Proclaimed Genius
View SilverStreak05's Photo Gallery
This has to be like the 10th person who's drained the tranny instead of the oil pan.
Donahoe - Total Chaos - Deaver - Wheelers - Goodyear
SilverStreak05 is offline   Reply With Quote
Old 11-14-2006, 03:00 AM   #13 (permalink)
2005PRERUNNER
View mikemoto81's Photo Gallery
i ALMOST did that the first time i changed my oil.... sure glad i triple checked lol
05 Tacoma Prerunner Reg. Cab
- 3" Toytec lift kit - 884 OME coils with AAL/BFG AT's265/75/16's...http://www.cardomain.com/ride/2467702
mikemoto81 is offline   Reply With Quote
Old 11-14-2006, 07:16 AM   #14 (permalink)
Banned
BillBrasky's Avatar
iTrader Score: 12 reviews
View BillBrasky's Photo Gallery
Exactly. So, evidently, it's not as hard as one might think to do. Good thing there are some decent guys around here to point him in the right direction w/o the "dumbass" remarks.
BillBrasky is offline   Reply With Quote
Old 11-14-2006, 12:40 PM   #15 (permalink)
Ron Jeremy's twin brother
screeber's Avatar
iTrader Score: 6 reviews
View screeber's Photo Gallery
I guess I (or anyone) could jack up one side of the truck, and try to take a decent, wide angle shot of the underside of the truck with both the oil pan and transmission pan clearly pictured and marked. Then post it as a sticky in this forum with a title like:
READ THIS BEFORE CHANGING THE OIL FOR THE FIRST TIME.
There was a guy over on CT that did this same thing just last week and was getting berated by another member - pretty ridiculous....
- disinterested
screeber is offline   Reply With Quote
DIY flush transmission fluid popeye08 Camry & Solara Lounge 6 07-02-2010 11:10 AM
2001 4cyl Highlander, transmission fluid flush bullycanadian 1st Generation (2001–2007) 18 06-30-2010 02:15 PM
Transmission fluid change question orbital Previa Forum 2 12-19-2006 01:18 PM
Transmission fluid change question orbital Previa Forum 0 10-04-2006 11:26 AM
Transmission fluid? 94camryLE Camry & Solara Lounge 4 09-25-2003 12:27 AM
