295/65/18 Goodyear Duratracs:2.5" lift in the front with 1" rear Block
JBA single exhaust:HID's W/Led's inside:Nfabs
E&G grill insert:ARE Z topper:Overhead DVD for my son:Front DVD for me
Hmm. Do 5 lugs have smaller rotors than 6 lug Tacos? Maybe its because those wheels are narrow, and don't have much of a lip. I doubt there are many 15" wheels that will fit. Those wheels sure are ugly.
i bet you the 5 lug has smaller rotors and caliper
Very possilbe, because of the stock tire sizes being smaller on the x-runner, less momentum and mass to stop??? Toyota thought smaller braking system could be justified? X-Runner also weighs less?
The base model 5 lug tacomas all come with 15 inch steel wheels. The XR and the 5lug trucks all have the same rotors and brake parts. Unless the XR was ordered with the big brake kit. The 6 lug trucks are definitely going to have a bigger rotor. The bolt circle for the 5 lug is 4.5 inches and the 6lug circle is 5.5 inches.
Im still reading the thread but here are 15" winter wheels on a tacoma..... and they said it cant be done. Does the Xrunner have smaller calipers?
Yeah, the brochure says the XRunner has the smaller rotors. Go take a look at the specs to make sure I'm reading it correctly (it gives their exact dimensions). Download the '07 brochure from Toyota's web site and take a look at it. Like I said, you could always swap your larger rotors out with the smaller ones... depending on just how badly you want 15" wheels. I personally wouldn't do it, but it's up to you.
Wow, Bet she rocks with those little 15's on. Aint pretty, but talk about a true snow setup. I had to go with 16's on my D-cab.
toku58, for the best winter traction, narrower is better. More pressure on the footprint and less floating. Also the smaller the rims better ablitily to absorb shock, ie, protect from potholes and chewed up winter roads.
__________________ 6-spd, 05' D-cab Sport 4x4, Tow pkg, TRD exhaust Summer: Stock 17's Winter: Blizzaks on 16' black steelies
bingo! that and im not a fan of the larger size rims. I like big bubbly tires on little rims.
