Rear Sway Bars? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > 2nd Generation (2005+)
2nd Generation (2005+) Discussion area for the 2nd generation of the Toyota Tacoma
Old 11-14-2006, 01:52 AM   #1 (permalink)
Dressed N Black
View tacoma-05's Photo Gallery
Rear Sway Bars?
Has anyone installed a rear sway bar on a 4x4. if so can you tell the difference in body roll or handling? i would like to install one on my truck, our trucks dont have a track bar like my previous GMC Sonoma highrider.
2005 TOYOTA TACOMA-SR5 V6 AUTO, SAND-BLACK. W/LEER 700 TONNEAU COVER,SKID PLATE,SEAT COVERS,STEP BARS
tacoma-05 is offline   Reply With Quote
Old 11-14-2006, 02:27 AM   #2 (permalink)
THIS SPACE FOR RENT
humanoid's Avatar
Gameroom cash: $1003264
View humanoid's Photo Gallery
I imagine it should stiffen up the rear a bit and give better handling around corners.
This is my sig.
humanoid is offline   Reply With Quote
Old 11-14-2006, 04:18 AM   #3 (permalink)
Why Chu Gotta Be A Douche
TacomaKid06's Avatar
View TacomaKid06's Photo Gallery
Not sure why you'd want to fly around corners in a double cab 4WD though. But good luck with that anyways.
2006 D-cab, 4wd, TRD Sport, Tow pkg, SR5
Are you scared? You will be, you will be.....
EMPTY [IIIIIIIIII] FULL
The WTF!?-o-meter is currently... At work... Guess it's not tooooooo bad . . .
TacomaKid06 is offline   Reply With Quote
Old 11-14-2006, 12:46 PM   #4 (permalink)
View Rower4VT's Photo Gallery
http://www.suspensionconnection.com/...scon/7671.html
Here's a sway bar for our trucks. In my mind a little on the pricey side, but I'd still concider getting one. I've upgraded the rear sway bar on about every SUV or car I've owned previously, and it doesn't just make a difference "at the limits" but in day to day cornering and handling.
Rower4VT is offline   Reply With Quote
Old 11-14-2006, 01:11 PM   #5 (permalink)
SR5-2006's Avatar
View SR5-2006's Photo Gallery
Has anyone removed the FRONT sway bar for better Articulation?
Whould this make a difference with an IFS setup?
My Pics
06 Access Cab SR5 4X4, OME 884s & Nitros, DAKAR leaf packs, 33" Cooper ATRs, MB Gunner 6's, Westin Bull Bar, PIAA 525s, Banks Monster Exhaust, Injen Powerflow Intake.........
"You can't have MANSLAUGHTER without LAUGHTER!"
SR5-2006 is offline   Reply With Quote
Old 11-14-2006, 01:15 PM   #6 (permalink)
Dressed N Black
Thanks man i think im going to go haed and get one and i will let evryone know how it is on the tacomas.
Old 11-14-2006, 01:16 PM   #7 (permalink)
View rudy0027's Photo Gallery
Its not a sway bar, but URD has this http://www.urdusa.com/product_info.p...4b2929bac10ff8
rudy0027 is offline   Reply With Quote
Old 11-14-2006, 01:23 PM   #8 (permalink)
Dressed N Black
i thought those were only if you lift your truck. So can you put it on a stock 4x4????? i dont plan on ever lifting my truck.
Old 11-14-2006, 02:55 PM   #9 (permalink)
View Silver-Bolt's Photo Gallery
That type of traction bar works fine on stock height trucks too. Prevents axle wrap. Pro-Comp has a very nice set too. I am adding the Pro-Comp bars and rear sway bar to mine.
06 Taco 4DR TRD-Sport
08 VW R32
04 Subaru STi (377whp)
00 Ford Lightning (528whp)
04 Aprilia Tuono Factory & Aprilia SXV 550
Silver-Bolt is offline   Reply With Quote
Old 11-14-2006, 02:58 PM   #10 (permalink)
Official Lurker
View chukstr's Photo Gallery
That does not provide the same function as a sway bar. I haven't noticed this truck having so much power that the springs wrap up under hard acceleration.
For a really great dog, Rescue a Retired Racing Greyhound!
chukstr is offline   Reply With Quote
Old 11-14-2006, 03:00 PM   #11 (permalink)
Official Lurker
I've used Helwig bars in the past on trucks and vans. Always had very good luck with them, and they make a remarkable difference in handling.
Old 11-15-2006, 09:43 PM   #12 (permalink)
View ALL-TERRAIN's Photo Gallery
I do a lot of highway driving and I notice that my truck has a some body role around turns on the highway when I'm doing 70-80 mph. I would by the rear sway bar if it was to help body role which is what I think it is designed to do, but will it hurt the trucks off road performance. I've read were others have removed the front sway bar to get full articulation of the suspension( I think thats why they remove it). So will this rear sway bar limit the flex of the trucks suspension and also is it located high enough that I won't crush it whenever I go off road. Thanks.
2006 Double Cab TRD 4X4 Off-Road
ALL-TERRAIN is offline   Reply With Quote
Old 11-16-2006, 02:08 PM   #13 (permalink)
Official Lurker
It will definately help body roll on the highway. It will definately hurt articulation off road. Depending on how it installs, you can possibly disconnect one end when going off road. But these two objectives are definately at odds with one another.
Old 11-20-2006, 02:17 AM   #14 (permalink)
View HUTCHSTACo's Photo Gallery
i would like to see someone try this on their truck
HUTCHSTACo is offline   Reply With Quote
Old 11-20-2006, 02:25 AM   #15 (permalink)
THIS SPACE FOR RENT
humanoid's Avatar
Yes, it would give you better articulation, especially for an IFS setup like ours. I believe a few companies make quick discos for the swaybars, but I can't think of them off-hand.
This is my sig.
Removing rear sway bar because of rattle noise. green94camry 3rd & 4th Generation (1992–1996 & 1997–2001) 13 02-16-2008 05:53 PM
Installing Front Strut Brace & Rear Sway Bar nscamry Camry & Solara Lounge 23 11-19-2005 11:10 AM
Sway Bars Drifting Dane MR2 Forum 3 09-08-2004 08:30 PM
Which REAR Sway Bar? dejacky Camry & Solara Lounge 20 06-27-2004 11:55 AM
