How to run a wire from outside the cab to inside the cab? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > 2nd Generation (2005+)
2nd Generation (2005+) Discussion area for the 2nd generation of the Toyota Tacoma
Old 11-17-2006, 12:12 AM   #1 (permalink)
View peppino's Photo Gallery
i need to run a wire from the tailgate to inside of the cab. anyone know how i can get this wire into the cab? any photos would be great
peppino is offline   Reply With Quote
Old 11-17-2006, 12:20 AM   #2 (permalink)
Pb
Surfing TN via iPhone
Pb's Avatar
iTrader Score: 15 reviews
View Pb's Photo Gallery
run the wire along with the stock bundles of wires on the driver side frame rail. Zip tie it along the way. Then when you get up to the area underneath the driver, let the wire go through a side hole in the frame. Stick the wire through a rubber drain "grommet" that's underneath the drivers seat. You will see some stock wires going through the grommet too. Pull off the door sill cover, reach under the carpet and the pull the wire through. Then run it along with the other wires in the door sill, behind the kick panel and up to the dash or wherever. You might have to puncture a hole in that grommet to get the wire through. Where the grommet is seal around the wire with some silicone sealant to keep moisture from getting in. There is also one of these grommets on the passenger side, if you want to run the wire up that side of the truck. It's best to protect the wire with wire loom as the wire travels up the frame rail. Lowes and AutoZone have it.
Pb is offline   Reply With Quote
Old 11-17-2006, 12:40 AM   #3 (permalink)
PB, THANK YOU! i just went out to the truck and i totally saw what you are talking about. how do i get the door sills off? do i just yank on them?
Old 11-17-2006, 12:43 AM   #4 (permalink)
Pb
Pb's Avatar
Yeah, just yank em off. The kick panels come off easy too. Pull off the black foot rest, then pull off a little black nut thing that's under the foot rest, then just pull the kick panel back towards the back of the cab. it will pop loose. When you reassemble the peices make sure the little tabs fit back into the clips and don't get bent to the side.
Old 11-17-2006, 12:50 AM   #5 (permalink)
awesome, thanks!
'05 regular cab rattle from behind/next to seat Ron V 2nd Generation (2005+) 1 02-08-2007 12:50 PM
info and quick fix for inside cab rattle buef1 2nd Generation (2005+) 0 04-14-2006 03:15 PM
Gasoline smell inside cab zborg 2nd Generation (2005+) 10 12-04-2005 06:16 PM
Basic Amp Install Instructions Phi Audio, Video, and Security - Tech 11 04-06-2005 02:25 PM
Subwoofer Install? CamrySpeaksJL Audio, Video, and Security - Tech 17 02-07-2003 08:33 AM
