Cold Weather Tacoma? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > 2nd Generation (2005+)
2nd Generation (2005+) Discussion area for the 2nd generation of the Toyota Tacoma
Old 11-18-2006, 12:06 PM   #1 (permalink)
Tacorossa's Avatar
View Tacorossa's Photo Gallery
Question Cold Weather Tacoma?
Has anyone else had this problem... Last weekend it got a little cold where I was and in the morning when I started up my Taco, my clutch pedal did not want to come back up off the floor? When it finally did come up, it snapped into place. This was the first cold period of the winter and it wasn't even that cold, maybe -15C at the worst.
For the next 20mins or so of driving the pedal would do the same thing on every gear change and it was more difficult to depress than normal. It made for some very rough shifting as you can imagine.
So I am wondering if this is a common thing with the 6spd when it gets cold. Is there a way to fix it? Better fluids? Stronger clutch pedal spring? I will be using my truck for work all winter in North Eastern Alberta where it gets a lot colder than -15C, not looking forward to it if I have to HOP to work in my truck.
Thanks in advance for your suggestions!
Canada Toyota 4WD Association
Join Us
Tacorossa is offline   Reply With Quote
Old 11-18-2006, 12:35 PM   #2 (permalink)
PiercedTiger's Avatar
View PiercedTiger's Photo Gallery
I have that problem with my car normally each winter. I usually have to get in, start it up, pump the clutch a few times, wiggle the shifter around some, and let it warm up. When I'm ready to leave I sometimes pump the clutch a little bit and almost always move the shifter around if it still feels stiff. Sometimes I rev the engine a little bit too. It usually just takes a couple miles or so for the fluids to warm up and start flowing properly.
I guess maybe you could get less viscous fluids, but then any grease on the joints, bearings, etc used will probably be stiff too so I wouldn't bother.
My car is usually fine in 5-10 minutes. I'll assume the truck is the same or better as it seems to heat up faster than the car.
^sig by me!
Toytec 3" lift & AAL, 285/75r16 Kumho Road Venture
DTRL, Fog Light, locker, & diff breather mods, Bestop Supertop, Hi-Lift mount, hood struts, reinforced tailgate, BHLM, ABS kill switch, bed lights, rock lights
PiercedTiger is offline   Reply With Quote
Old 11-18-2006, 03:00 PM   #3 (permalink)
View Highway's Photo Gallery
I have the same situation in my truck, although is is a 5 speed. Seems as though the fluid for the chutch is too thick for the tempature. It has only happened on two mornings but both of those were in the low 30's. I'm going to ride it out and see if it does it more. If so I will be picking a cold night to drop it off at the dealer.
06 4x2 Silver Streak Access Cab 2wd Non-Prerunner
Highway is offline   Reply With Quote
Old 11-18-2006, 06:47 PM   #4 (permalink)
View adamt35's Photo Gallery
I have the 6 spd, and it is getting quite cold here now.. it is -15C right now.. I have never had that problem, I would definitely take it in...
2006 Silver DoubleCab Shortbed 6spd V6 Tacoma
Do you fly fish? ---> www.thornesmanufacturing.com
adamt35 is offline   Reply With Quote
Old 11-18-2006, 06:56 PM   #5 (permalink)
demoncleaner's Avatar
View demoncleaner's Photo Gallery
Going on my third winter, started up and drove off in temps as cold as -22F (-30C). No problem like that, if keeps happening, see dealer.
6-spd, 05' D-cab Sport 4x4, Tow pkg, TRD exhaust
Summer: Stock 17's
Winter: Blizzaks on 16' black steelies
demoncleaner is offline   Reply With Quote
Old 11-18-2006, 11:33 PM   #6 (permalink)
Tacorossa's Avatar
I'm going on my second winter with this truck, but I usually drive from garage to garage in the winter. Never really let it sit out in the cold all night until last weekend. I guess it is just my trucks way of giving me shit. It will certainly have to get used to it this winter. If it happens again I will be taking it in. I have another manual pickup that I've been driving for 13 years and it doesn't matter what the temperature is, the thing always feels the same... Except for the temperature of my butt of course.
How big of a job would it be to change the clutch fluid? Never done anything like that before. What would you recommend as a winter fluid?
Join Us
Old 11-19-2006, 02:23 AM   #7 (permalink)
Well, I just went out to turn my truck around so I could plug it in for the night and what should happen? The clutch was sticking... it is -18C right now....
Old 11-20-2006, 01:40 PM   #8 (permalink)
Tacorossa's Avatar
So I'm not losing my mind!!! Fantastic. So how do we fix it? I think I'll just give in and bring it to the stealership.
Join Us
Old 11-20-2006, 02:44 PM   #9 (permalink)
Precision driver
mhadden's Avatar
iTrader Score: 7 reviews
View mhadden's Photo Gallery
Wow...no vehicle, no matter how old or new, should do that. I would take it into the stealership. Sounds like something it sticking in the tranny or clutch pedal. I don't think it's the fluids. Fluids won't solidify to make it operate like that...Of course, you may have air in your clutch line.
2011 Fit Sport 5MT
2011 Pilot EX-L AWD
2008 Goldwing Navi
mhadden is offline   Reply With Quote
Old 11-20-2006, 03:15 PM   #10 (permalink)
Yeah, I think I will have to do the same. I will wait until my next oil change though. Make sure you post what they tell you at the stealership.
Old 11-20-2006, 03:29 PM   #11 (permalink)
Playoff bound, 8 long yrs
zmtnbik's Avatar
View zmtnbik's Photo Gallery
The hydrolic clutch field is basically DOT3 brake fluid (SAE J1703) if this were the cause of the sticking clutch pedal, then I would also suspect you would have braking issues.
Chances are its the result of the grease freezing up. I would definitly take it into the stealership and they should have a resolution for you. I'd be suprised if there wasn't a TSB already for this issue.
I'm waiting for the cold weather here in CO, to see if this will be an issue or not.
2006 4x4 Access, V6, 6spd, TRD Off-Road, tow pkg. Donahoe Co's, TC UCA's, Dakar leafs, 5125's in the back and u-bolt flip kit. TRD exhaust, CAI. URD MAF calibrator. 17x9's, 285/70/17 BFG MT KM2. Locker-mod, fog mod and console vault.
zmtnbik is offline   Reply With Quote
Old 11-20-2006, 06:21 PM   #12 (permalink)
Tacorossa's Avatar
Yeah, common sense would say that you are right. I wasn't having braking issues, so on to the next potential cause. Thanks for the info zmtnbik.
I'll be calling the dealership first thing tomorrow morning to see if they have had that problem brought to their attention yet. We've been having some warm weather here lately so I haven't been able to replicate the problem. Going to be cold next week though so I'll be parking at the dealership if they try and call my bluff.
Join Us
Old 11-21-2006, 01:22 AM   #13 (permalink)
View ambrew's Photo Gallery
Brake fluid actually absorbs moisture/water. If it absorbs too much water, it changes the boil over point as well as the freezing point. if you've been offroad or the seal cap on the master cylinder is loose, or for any othe reason (lots of condensation, washing your engine) think that it may be contaminated, have it flushed and put new fluid.
I have an auto, so i do not know if you can disconnect you clutch pedal and check it's travel to see if it does so freely, but I would do that before spending money on getting it fixed.
Andy
ambrew is offline   Reply With Quote
Old 11-21-2006, 08:15 AM   #14 (permalink)
Tacorossa's Avatar
Andy
Do you think the dealership would charge me to change my clutch fluid? I certainly hope not. I'll be calling today to see what they are going to do for me. I'll keep you guys posted.
Join Us
Old 11-21-2006, 09:50 AM   #15 (permalink)
Probably... They charge to change the oil unless you have some sort of deal or coupon. I can't imagine them doing much for free... lol Hell, I got better service at Jiffy Lube last time I had someone else change my oil. At least THEY washed the windows and vaccumed the car. Toyota didn't do shit besides change the oil.
^sig by me!
Cold Weather start - Doesn't turn Troyfrezze 3rd & 4th Generation (1992–1996 & 1997–2001) 5 11-07-2006 08:32 PM
2.2r Cold Start Problem redntanmiata 89-95 Toyota Pickup/Hilux 3 02-21-2006 07:52 AM
Cold weather car revs to 5,000rpm Red_85_AE86 Archived Corolla threads 13 12-05-2005 05:57 AM
2005 Tacoma X-Runner pickup truck CDNVITZ General Discussion 22 03-29-2004 08:52 PM
