Brake Light in Camper Top Stopped Working - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > 2nd Generation (2005+)
2nd Generation (2005+) Discussion area for the 2nd generation of the Toyota Tacoma
Old 11-18-2006, 04:53 PM   #1 (permalink)
View smokymt's Photo Gallery
I just noticed that the brake light on my camper top is no longer working. I have an A.R.E Z-series. I plan to check with the local dealer on Monday, but does anybody know any other sources where I can find a replacement light? Its an LED light, and apparently the whole thing has to be replaced instead of just the bulbs.
smokymt is offline   Reply With Quote
Old 11-18-2006, 07:18 PM   #2 (permalink)
Pb
Surfing TN via iPhone
Pb's Avatar
iTrader Score: 15 reviews
View Pb's Photo Gallery
My first guess is that it's a bad connection where they tapped into the stock brake light wiring.
Pb is offline   Reply With Quote
Old 11-18-2006, 08:01 PM   #3 (permalink)
View rugerm44's Photo Gallery
Probably used a 3m wire tap and didnt get a good connection. They can corrode with time.Make sure your getting power to it before you replace it.
rugerm44 is offline   Reply With Quote
Old 11-18-2006, 11:54 PM   #4 (permalink)
View ambrew's Photo Gallery
had same problem with my truck cap: the wire that leaves the tail light striped and grounded out. improperly routed.
ambrew is offline   Reply With Quote
Old 11-19-2006, 09:22 AM   #5 (permalink)
I actually retapped the wires trying to get it to work, but still no luck. What can I use to test if its getting power? I picked up a circuit tester at Autozone, but I don't think I got the right thing.
Old 11-19-2006, 09:45 AM   #6 (permalink)
Pb
Pb's Avatar
What kind of tester is it? A little light thing? Is the brake light housing easy to take down?
Old 11-19-2006, 09:58 AM   #7 (permalink)
It looks like a screwdriver with a light & battery in it, and it has a cord with an alligator clip on the other end.
The brake light housing on the camper top is easy to remove, but it is fully enclosed and sealed. So I don't think I can get to the internal wiring.
Old 11-19-2006, 01:11 PM   #8 (permalink)
Pb
Pb's Avatar
use a razor blade and peel back a little peice of insulation on both wires so that you can see the copper wire. Connect the aligator clip to one wire, and then touch the end of the pen to the other wire. Have somebody press on the brake pedal. The test light should come on if you've got a good connection. If the light doesn't come on then that means you need to check your wiring again, it's not the LEDs. If the test light lights up then you have a defective brake light unit.
Old 11-19-2006, 01:20 PM   #9 (permalink)
I'll give it a try. Thanks for the help.
94 Camry brake warning light eaglemtn 3rd & 4th Generation (1992–1996 & 1997–2001) 25 05-04-2012 11:57 AM
Brake light warning icon abovethelaw Camry & Solara Lounge 7 02-22-2006 03:53 PM
stop light not working mister Joe Camry & Solara Lounge 8 05-31-2005 10:55 AM
gen2 brake light stays on... help... please.. busted_ride 1st & 2nd Generation (1983–1986 & 1987-1991) 2 09-24-2004 04:56 AM
