Need Some Help On This Check Engine Light - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > 2nd Generation (2005+)
2nd Generation (2005+) Discussion area for the 2nd generation of the Toyota Tacoma
Old 11-19-2006, 12:02 AM   #1 (permalink)
Coastgardsman's Avatar
View Coastgardsman's Photo Gallery
Gen6 Need Some Help On This Check Engine Light
Well I think I got the curse when it comes to these kind of things. Before I take it in to the dealer, just want to know if any of you guys have had this problem? My truck only has 9,800 miles on my 06 4x4 trd and the check engine light came on. My buddy says it does it when its time for sched maint. I dont really buy that... any suggests?
2006 Tacoma Double Cab LB 4x4 TRD Sport
Coastgardsman is offline   Reply With Quote
Old 11-19-2006, 12:06 AM   #2 (permalink)
cam2Xrunner's Avatar
What exactly does the light look like? Like a little engine or does it say maint reqd?
Old 11-19-2006, 12:10 AM   #3 (permalink)
It says Maint required...i was just thinking about it right now... I thought the check engine light and maint req were all in one...
Old 11-19-2006, 12:10 AM   #4 (permalink)
stretch200's Avatar
View stretch200's Photo Gallery
The little engine light means you need an oil change. The maint reqd means you need maintanance. hope that helps.
stretch200 is offline   Reply With Quote
Old 11-19-2006, 12:12 AM   #5 (permalink)
yeah, time for an oil change.
http://www.toyotanation.com/forum/t161878.html
Old 11-19-2006, 12:13 AM   #6 (permalink)
Like what kind of maint? I mean is it specific as in valve adjust or just filling the washer fluid?
Old 11-19-2006, 12:13 AM   #7 (permalink)
Originally Posted by cam2Xrunner
ah ok cool deal...thanks man, i was already getting a little ticked off there...
Old 11-19-2006, 12:17 AM   #8 (permalink)
Yeah no problem...
RTFM hahah
Old 11-19-2006, 04:51 AM   #9 (permalink)
Humble Servant
msibille's Avatar
View msibille's Photo Gallery
I read this thrd a couple of times and I think someone might be confused.
Maintenance Req'd Light -> oil change/sched maint -ref your manual (read the manual, then use the search button, then post question?)
Check Engine or Malfunction Indicator Light (MIL) -> Triggered when PCM detects an error condition (either operation outside programmed range, malfunctioning sensor, or control, etc.) Most commonly caused by not tightening the fuel cap until it clicks. (if this happens, several "drive cycles" will clear the code, or you can use a code reader to clear it) For other triggers, a code reader is req'd to read the error code and/or clear it. If not due to fuel cap being loose, don't ignore this. Depending on the prblm, continued operation can cause damage.
Again, description of the indicators and meanings are shown in the manual.
msibille is offline   Reply With Quote
Corolla 2002 P1349 trouble code? check engine light. g.b. Archived Corolla threads 6 10-01-2009 01:52 AM
check engine light Islandtrix 1st Generation (2003-2008) 17 03-05-2009 01:02 AM
Locking gas cap and check engine light on Tacos paco 2nd Generation (2005+) 36 06-06-2008 10:00 PM
Official 2007 Toyota Camry Announcement, Images & Specs EKam Toyota News 1481 05-17-2007 09:50 PM
Check Engine Light (again) t4x4_offroad Camry & Solara Lounge 5 10-19-2006 11:52 AM
