Ambo,
I just changed my oil again Saturday too. I assume the reset of which you speak is the one where you press the odo button and turn on the key until the dashes disappear. That does not reset my clock or radio or anything else I notice, except the maintenance light, of course.
Did you disconnect the battery? That would explain the clock, but not the CD player. I suspect it is an unrelated problem. Check the fuse. If you are using a DF-TOY or something, check the threads on that because some owners are having problems with those.
Dan
