tailight bulb replacement - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > 2nd Generation (2005+)
2nd Generation (2005+) Discussion area for the 2nd generation of the Toyota Tacoma
Old 11-20-2006, 03:33 PM   #1 (permalink)
View msgntsu's Photo Gallery
Has anyone had to replace the bulb in the tailights yet? I was wondering how you got to the bulb? Does the whole assy. come out by removing the bolts inside the tailgate?
Thanks.
msgntsu is offline   Reply With Quote
Old 11-20-2006, 04:23 PM   #2 (permalink)
Precision driver
mhadden's Avatar
iTrader Score: 7 reviews
View mhadden's Photo Gallery
Thanks.
Yes, you will have to remove some bolts. I don't remember exactly which ones they are, but your owner's manual says how to remove the assembly and replace the bulbs (look under blub replacement in your OM index).
2011 Fit Sport 5MT
2011 Pilot EX-L AWD
2008 Goldwing Navi
mhadden is offline   Reply With Quote
Old 11-20-2006, 05:45 PM   #3 (permalink)
Pb
Surfing TN via iPhone
Pb's Avatar
iTrader Score: 15 reviews
View Pb's Photo Gallery
Let down the tailgate. There are 3 bolts on each side of the jamb. You only need to remove 2 of them. The top and bottom bolts. They're the 10mm bolts that don't have a washer under them. Then pull out on the light. It will pop loose. Then you gotta twist it a little bit to get the light out. Then you can easily get to the bulbs.
Pb is offline   Reply With Quote
Old 08-09-2007, 08:49 AM   #4 (permalink)
this_is_nascar's Avatar
View this_is_nascar's Photo Gallery
Is this the same on the '07? I thought it was the bolts WITH the washers. On my '07, I attempted to get the taillight off, but didn't have too much luck. I was able to get the top portion un-snapped, but not the bottom. Now I'm wondering if I had the correct bottom bolt removed, even though I did remove the one the owner's manual suggested.
Current Ride: 2007 Toyota Tacoma TRD Off-Road Stock)
Former Ride: 2001 Ford Ranger XLT Off-Road (Stock)
"... it's not what you take when you leave this world behind you, it's what you leave behind you when you go."
this_is_nascar is offline   Reply With Quote
Old 08-09-2007, 09:02 AM   #5 (permalink)
Pb
Pb's Avatar
It's the top and the bottom bolt. Not the one in the middle that's different. Just grab the light and pull straight back real fast. It will pop loose.
License plate bulb replacement thday Archived Corolla threads 1 12-30-2005 10:40 AM
Headlight Bulb Info - Halogen, HID, HIR, Lumins, etc... BLUEMEANIE General Discussion 2 02-09-2005 01:19 PM
Bulb replacement and EGR valve Hwkpride Camry & Solara Lounge 1 12-13-2004 04:54 PM
Headlight bulb replacement YotaRolla74 Archived Corolla threads 0 03-13-2004 09:12 PM
Headlight Bulb Replacement Gen 3 I4 Gen3caMLos 3rd & 4th Generation (1992–1996 & 1997–2001) 10 09-02-2003 04:09 PM
