Anyone with the URD y-pipe ? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > 2nd Generation (2005+)
2nd Generation (2005+) Discussion area for the 2nd generation of the Toyota Tacoma
Old 11-22-2006, 10:45 AM   #1 (permalink)
View mountain lion's Photo Gallery
I searched and didn't find much...has anyone on these boards installed the urd y pipe? The charts from Gadget looked like it gives ~15hp to the wheels. I'm thinking about buying it, (not concerened with emissions) but am conerned about any significant MPG gains/losses, especially when paired with an intake. Woth getting? Any thoughts, observations, opions are welcomed.
mountain lion is offline   Reply With Quote
Old 11-22-2006, 11:32 AM   #2 (permalink)
View yrffej's Photo Gallery
the y pipe will eliminate both rear cats.... coupled with a free flowing catback and free flowing intake won't give you the hp you think without adding a maf calibrator and have it tuned...
'05 prerunner access trd sprt pkg1 w/tow & trd catback
yrffej is offline   Reply With Quote
Old 11-22-2006, 12:10 PM   #3 (permalink)
View Xacto's Photo Gallery
i have an airaid intake and magnaflow catback and with a tune i pulled 241 hp and 268 lb. tq. on the dyno. Gadget pulled 234 hp and 272 lb. tq. with the tuned URD CAI and Y-pipe with URD exhaust. Of course, this isnt the end all be all, but it's pretty obvious that the URD exhaust is much more effective on a F/I truck, rather than N/A...
Shite McGuinness!
Xacto is offline   Reply With Quote
Old 11-22-2006, 12:24 PM   #4 (permalink)
Did you retune and do you need a plug in module to retain the tune (like a power commander or the like)? Hows mpg now?
Old 11-23-2006, 04:03 PM   #5 (permalink)
look at the urd site.. they have 2 different devices applicable for normally aspirated.... i don't have actual #'s for mpg savings. but leaning out the mixture will save gas and increase hp...
Old 11-24-2006, 12:10 AM   #6 (permalink)
well i was getting shitty ass mileage before, im talking 280 miles per tank, im not done with this tank, but im guessing im gonna hit 310-320
Shite McGuinness!
Old 11-24-2006, 02:18 PM   #7 (permalink)
Nice, how restrictive is the stock muffler and piping after the y-pipe? Would it be pointless to only do the y-pipe and not the whole thing?
Old 11-24-2006, 05:40 PM   #8 (permalink)
the only mod i've done so far is the catback.... and it was noticable on the butt dyno. the trd is 1/4" larger inside diameter than stock. my spin is, mods should be done from back to front. if you can't let it out fast, letting it in fast is a waste.... i'll bet the stock y-pipe is restrictive in bends alone, eliminate 2 rear cats and it's gotta' be noticable. (i don't recall the inside diameter of the urd y-pipe)
Old 11-24-2006, 10:15 PM   #9 (permalink)
scottie9982's Avatar
View scottie9982's Photo Gallery
those tuning modules on the URD site, do they require any special expertise to operate?
Cardomain.com: 2005 PreRunner TRD-OR DCab - Borla C/B, TRD CAI, Alpine, JL Audio, Boston Acoustics, Monster Cable
scottie9982 is offline   Reply With Quote
Old 11-24-2006, 11:14 PM   #10 (permalink)
Offical TN Vendor
View Gadget@URD's Photo Gallery
I can not tell you how pleased I am to see that you have gotten such a great result with your combination and using our URD MAF Sensor Calibrator to tune it all in. However, I think your end conclusion that is much more effective on a F/I truck rather then a N/A truck.
First, it is not the maximum number, but the total over gain that is important. Every vehicle is different to some degree and every one will print a different baseline number as a starting point. Just comparing a final result is not a good way to make a good comparison.
Next, you should be careful comparing the results from different types of dynos. We all know that differnt dynos report a different number even on the very same truck and the same day at the same location.
Finally, your dyno chart, although very impressive, is reported as flywheel HP and TQ. That dyno you used uses power taken from the hubs and tries to make a wild guess what the power is at the flywheel.
Now with these things considered, 234 rear wheel HP beats 241 flywheel HP, and that would mean that a URD True Cold Air Intake and URD Exhaust beats an AirRaid and Magnaflow. Of course the only true way to properly compair this is to compare those products on the same truck, on the same dyno, at the same location, on the same day. I will bet you a box of donuts the URD True CAI will crush the AirRaid one...
Gadget
www.GadgetOnline.com
Gadget@URD is offline   Reply With Quote
Old 11-25-2006, 02:02 AM   #11 (permalink)
Engine 80 is in service
10SE's Avatar
View 10SE's Photo Gallery
Gadget
He speaks!!!
If I wasn't on a bit of a diet, I'd have you deliver those donuts personally. After all... an actual intake will outperform a theoretical intake 5 times out of 5.
2008 Black D-Cab Limited 4x4
5.7, Red Rock leather, stock... for now
10SE is offline   Reply With Quote
Old 12-26-2006, 07:16 PM   #12 (permalink)
View Joeyg023's Photo Gallery
Does Anyone have any sound clips with the URD exuast? It looks like a real nice system,but was curious how it sounds. At least just the exuast, but i'm looking at getting the catback and the y pipe.
Joeyg023 is offline   Reply With Quote
Ques. about the Flex pipe (front pipe) VietBoi Camry & Solara Lounge 9 01-31-2011 04:14 PM
URD Y pipe racer1x 2nd Generation (2005+) 4 11-08-2006 07:13 AM
DIY Cold-Air Intake bondobondo Hardcore Tech and Competition 40 11-24-2004 01:41 PM
5s-fe leaking front pipe bronzemaxell Camry & Solara Lounge 1 10-23-2004 03:37 PM
Double check... _VVTi_ Camry & Solara Lounge 43 04-22-2004 01:25 AM
