How do I raise the manual driver seat in the o6 Taco - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > 2nd Generation (2005+)
2nd Generation (2005+) Discussion area for the 2nd generation of the Toyota Tacoma
Old 11-22-2006, 10:56 AM   #1 (permalink)
View tacolibre's Photo Gallery
My new Taco manual driver seat is too low. My lower back is killing me. Can the back rail portion be raised? Suggestions? Old guy here.
tacolibre is offline   Reply With Quote
Old 11-22-2006, 11:03 AM   #2 (permalink)
dl1027's Avatar
Gameroom cash: $127425
View dl1027's Photo Gallery
RTFM. It's on page 36 in the owners manual. Lift the lever on the side to tilt the seat back up. Turn the knob to increase lumbar support. I really like the seat in my new Taco. Finally a drivers seat that doesn't hurt my lower back. My only gripe was the headrest is tilted too far forward and touches the back of my head but I got used to it.
dl1027 is offline   Reply With Quote
Old 11-22-2006, 11:34 AM   #3 (permalink)
OR_TRD's Avatar
View OR_TRD's Photo Gallery
Uhh, i belive he asked how to "raise" the driver seat.
I don't think you can raise the seat though? i've never seen a lever to do this.... if you create a mod let us know.
OR_TRD is offline   Reply With Quote
Old 11-22-2006, 11:46 AM   #4 (permalink)
Crtl-Alt-Del
View DaleClough's Photo Gallery
To raise is not a factory "option". You can remove the seat and add a spacer or two...
1998 T4R Ltd, many miles down, many more to go!!!
DaleClough is offline   Reply With Quote
Old 11-22-2006, 11:57 AM   #5 (permalink)
View gahunter's Photo Gallery
raise the seat height
It's really rather simple as the previous post states. You need to unplug the seat belt safety device which is located under the seat. Then if it is a bucket seat I believe you would have 4 bolts to remove to remove the seat. Use washers or spacers as needed to raise to the desired height. You can add even #s for front and back or more of the other depending on how you want the seat to set. I would check the bolt length and size before staring to assure it will have the required length after adding spacers. Buy washers and bolts at the same time. This will keep you from having to put the seat back in to drive to the store to buy additional bolts. If you have another car, it will still be easier if you plan ahead. You may be able to find the bolt size at this site as someone has posted some factory manual info somewhere on site.
gahunter is offline   Reply With Quote
Old 11-22-2006, 12:08 PM   #6 (permalink)
View mikeg281's Photo Gallery
Yeah but after going through all that trouble is it really going to help your back. I mean it is still going to be at the same angles, just a little higher.
mikeg281 is offline   Reply With Quote
Old 11-22-2006, 05:45 PM   #7 (permalink)
20' Daredevil (Retired)
Gameroom cash: $510182
View Splicer's Photo Gallery
Originally Posted by gahunter
It's really rather simple as the previous post states. if it is a bucket seat I believe you would have 4 bolts to remove to remove the seat. Use washers or spacers as needed to raise to the desired height.
That would work if the 4 bolts went straight down, but only the rears do. The fronts are at an angle, so you would need to fab an adapter. That said, if all the OP wants is to raise the rear of the rails a small amount, longer rear bolts and spacers should work.
2005 D-Cab O/R 4x4
Splicer is offline   Reply With Quote
Old 11-22-2006, 05:50 PM   #8 (permalink)
"Clean" the best mod.
Gameroom cash: $235860
View cj99si's Photo Gallery
Originally Posted by Splicer
OP
05 4X4 DC LB TRD Sport(OME 885's, Alcan AAL,silver HL mod, 265/70/17s Firestone destination AT's)
99 Audi A4
cj99si is offline   Reply With Quote
Old 11-22-2006, 06:15 PM   #9 (permalink)
RTFM's Avatar
Gameroom cash: $334162
View RTFM's Photo Gallery
Instead of trying to raise your seat, try pulling it closer to the steering wheel. I'm 6'2" and tried driving with the seat all the way back, but my back quickly didn't like that. Moved the seat forward 2", and the pain never returned.
06 DC LB, 4x4, Speedway , TRD Sport w/ Tow, JBL 6CD w/ Grom to IPod, Roof Rack, Weathertech bug deflector & floormats, Access LE tonneau, Hood Struts, Scangauge, Clifford 10.5x alarm, Homelink Mirror, Ultra Grinder Wheels, Toyo Open Country AT tires
RTFM is offline   Reply With Quote
Old 11-23-2006, 12:41 AM   #10 (permalink)
05 Speedwayblue X-runner
rpmspeedyBlue's Avatar
View rpmspeedyBlue's Photo Gallery
Have you tried using a seat cushion?
Stock 05 X-Runner
rpmspeedyBlue is offline   Reply With Quote
Old 11-23-2006, 09:51 AM   #11 (permalink)
My search-fu is weak!
Zman2k2's Avatar
View Zman2k2's Photo Gallery
Does your seat have lower lumbar support? There should be a wheel on the door side of the seat. Turn the wheel, and you'll feel the lumbar support move out. I've used it ever since I went on a roadtrip and my back started hurting. Now I leave it set to where I like it, and even the wife doesn't move it.
Zman2k2 is offline   Reply With Quote
Old 11-23-2006, 02:18 PM   #12 (permalink)
Humble Servant
msibille's Avatar
View msibille's Photo Gallery
Be cautious with replacing bolts to ensure that you use bolts of equivalent grade.
In the event of a collision, you don't want the seat ripped from the floor. If a frontal collision, the seat would then restrained by the seat belt and cushioned by your body.
In the case of a rear end collision, your risk of injury is greatly increased if the front bolts fail, allowing the seat to flip backward.
Suggest review of the svc manual for appropriate fastener grades, or at least make sure you recognize and duplicate the grade of fastener marked on the bolts already in place.
Just keep in mind that simply shimming up a significant height may load the bolts differently (adding bending in addition to shear) and increase the risk of their failure under load.
The other suggestions (cushion or seat fwd/rear adjustment) might be simpler/safer.
I personaly find that if the seat back is too far forward, I dont' get sufficient support of my lower back.
msibille is offline   Reply With Quote
Old 11-23-2006, 03:10 PM   #13 (permalink)
Stupid is stupid does
lotust's Avatar
View lotust's Photo Gallery
Im 6'3" I wish I could lower my seat
295/65/18 Goodyear Duratracs:2.5" lift in the front with 1" rear Block
JBA single exhaust:HID's W/Led's inside:Nfabs
E&G grill insert:ARE Z topper:Overhead DVD for my son:Front DVD for me
lotust is offline   Reply With Quote
Old 11-23-2006, 03:19 PM   #14 (permalink)
View nyles's Photo Gallery
I'm only 5' 2", I too looked into raising the seat, but found that because of the angled front mounts that it was going to be a pita. I'm the proud owner of a $5 pillow that sits under the seatcover. My friends call it my booster seat.
05 Access Cab TRD Offroad. Looking to sell my new, still in box Toytec lift. Make me a reasonable offer!
nyles is offline   Reply With Quote
Old 11-30-2006, 09:56 AM   #15 (permalink)
View QuickStarr's Photo Gallery
Went to Home depot today and bought 10 3/8" washers and removed the rear bolts securing the seats. Well I could only fit 4 washers under each side and tighten the bolts safely, 5 washers would be too many without longer bolts. It really does make a difference for me as I've always felt a little low in the seat while driving. It is a much more comfortable driving position for me but I want to get longer bolts for safety but I can't seem to find the correct size??? Does anyone know what size and thread these bolts are? Or where I can buy longer ones?
06 Silver DC TRD 6 Speed......
Mabel Is Able!
QuickStarr is offline   Reply With Quote
OEM Driver Seat, Grill, Chin Spoiler/Lip MatrixStatus 1st Generation (2003-2008) 3 02-18-2004 01:43 AM
finally got my sparco seat mounted nicely mr_sinister Archived Corolla threads 49 09-12-2003 10:05 AM
