If you are trying to align your carrier bearing - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > 2nd Generation (2005+)
2nd Generation (2005+) Discussion area for the 2nd generation of the Toyota Tacoma
Old 12-04-2006, 09:30 PM   #1 (permalink)
Hans Moleman's Avatar
View Hans Moleman's Photo Gallery
don't waste your time. It will shift back to its original position all the way to the left after driving for a while. It is due the to the way it is clamped down. I torqued it to 50ft-lbs and 70ft-lbs and it still shifted back. From the FSM for 01-06 Tundra, the calls for 30 ft-lbs, for reference since I don't have the full FSM for the Tacoma. I had tried to align it to smooth the drive line out. It just made a little bit of difference, maybe it's all in my head
Does anyone happen to know the torque spec for 05-06 Tacoma? I don't think it makes it a difference anyways since it still shifted back at 70ft-lbs.
Donahoe Coilovers & Remote Reservoir Shocks
Total Chaos UCAs
TSB Springs
Hans Moleman is offline   Reply With Quote
Old 12-04-2006, 09:40 PM   #2 (permalink)
Trevor
View Adventure North's Photo Gallery
What do you mean by "align your carrier bearing?" Align it how? Move to the left??
My Images
Trevor
Adventure North is offline   Reply With Quote
Old 12-04-2006, 09:48 PM   #3 (permalink)
LaVaCrAwLeR
beachbumz's Avatar
View beachbumz's Photo Gallery
I've been messing around with mine also this week.. trying to see if it wood make a difference in the initial shudder I got.. Been moving it left and right... at about 50 lbs, doesnt seem to move on my truck.. I mark it each time too. can't say it helps though yet..
beachbumz is offline   Reply With Quote
Old 12-04-2006, 09:54 PM   #4 (permalink)
moving it left and right trying to align it with the transmission and rear differential to make the driveline smoother. Initially it was all the way to the left most from the factory. I moved it 4mm to the right and it went all the way back to the left due to the force of the driveshaft.
Total Chaos UCAs
TSB Springs
Old 12-04-2006, 09:54 PM   #5 (permalink)
Trevor
Ok maybe I'm missing something but I don't recall being able to move the carrier bearing left or right. Can someone explain, I'm tired so perhaps I'm just not seeing it.
My Images
Trevor
Old 12-04-2006, 09:57 PM   #6 (permalink)
I swore it was a little smoother when I was first playing around with it. Now it doesn't seem to make a difference where ever I move it.
Have you tried axle degree shims to try to eliminate the shudder?
Total Chaos UCAs
TSB Springs
Old 12-04-2006, 09:59 PM   #7 (permalink)
If you loosen the carrier bearing mount, there will be play in the left and right directions
Total Chaos UCAs
TSB Springs
Old 12-04-2006, 10:04 PM   #8 (permalink)
Trevor
Hmmm, well there ya go. I thought it was only forward and back. I'll have to peek at mine again tomorrow, Thanks
My Images
Trevor
Old 12-04-2006, 10:38 PM   #9 (permalink)
LaVaCrAwLeR
beachbumz's Avatar
Yeah the axle shims are next I guess.. toytec 2.5 degree probably... heard they worked for some on the initial studder problem... hopefully they will work for me... cause I'm tired of the initial studder and vibration at about 20mph...
Hey aAdventure... ya the carrier moves left and right about and 1 - 1-1/2 inches. once the bolts are loosened..
aloha
Old 12-04-2006, 10:43 PM   #10 (permalink)
LaVaCrAwLeR
beachbumz's Avatar
vibes all gone. I did not change the shaft. I moved the carrier bearing left and right until it was smoothest. I kept having doubts about the carrier bearing not being centered from the factory.
So Hans did the vibe go away completely and then come back ?? just curious..
Old 12-04-2006, 11:01 PM   #11 (permalink)
No vibrations came back. The odd thing was it seemed smoother when I moved it initially, but now it still seems the same, no more no less vibrations where ever I move it. I found out it moved the first time when I was retorquing everything. Today I just decided to check and it saw it move all the way again.
Total Chaos UCAs
TSB Springs
Old 12-05-2006, 12:12 AM   #12 (permalink)
Trevor
aloha
That is interesting because when I installed my spacer (pic above) I didn't notice or realize there was that much play. An inch sure seems like a lot of room for play. Cheers.
My Images
Trevor
Old 12-05-2006, 03:16 AM   #13 (permalink)
View HILLCLIMBER's Photo Gallery
whatever happend to the driveshaft group buy? Im gonna eliminate all the problems and just fork out the $400 for one! I talked to 2 some jo blow at the tom woods place and he told me if it didnt fix my problems i'd have 30 days to return it for a full refund. Hmm sounds like a no brainer 2 me...
05 double cab 4x4 trd off road
HILLCLIMBER is offline   Reply With Quote
Old 12-05-2006, 05:35 AM   #14 (permalink)
russ25nys's Avatar
View russ25nys's Photo Gallery
I cancelled the group buy becuase we only had 2 people doing it. EDIT: Thats pretty sweet that they will take them back.
05, Silver DC. TRD O.R # 2 with Tow. 3" O.M.E / Toy Tec.
russ25nys is offline   Reply With Quote
Old 12-05-2006, 12:49 PM   #15 (permalink)
View big dumps's Photo Gallery
is this from raising the front or the rear. Im planning on just raising the front 2inches.
big dumps is offline   Reply With Quote
carrier bearing play Huey 89-95 Toyota Pickup/Hilux 5 11-14-2011 12:57 PM
Carrier Bearing Question beachbumz 2nd Generation (2005+) 36 11-25-2006 12:12 PM
carrier bearing drop, rims, shifter pics. toku58 2nd Generation (2005+) 7 11-07-2006 10:07 PM
Updated Lift Pics, Volant Intake, and Carrier Bearing Drop kit! (56K Warning!) Rodge 2nd Generation (2005+) 24 11-04-2006 03:52 PM
how to pull pilot bearing on 22re 99mustang232 Hardcore Tech and Competition 1 10-19-2005 06:47 PM
