I actually didn't lift my taco. I just put helper springs (super springs) on the rear and that was enough to give the truck drive-line vibrations. It only raised the rear about half an inch. This suspension seems to be very sensitive. Never thought and inch would make a difference. I could not believe that this could be the problem. It is ashame because the springs did perform well, but I just could not live with the constant vibes. I still get a slight shudder at take off, but all of the new 07's I have driven do the same thing. Just a bad design of the drive-line I guess (two piece drive shaft). The vibes I experienced came at 0-20 mph, 20-0 mph, a constant speed of 20, a constant speed of 8 mph and when slowing down from highway speeds. Everything will be fine for the winter, but when spring and summer come I will need to find another solution to strengthen the rear end. As it stands now, it will bottom pretty easily if I have adults in the cab and or a good sized load in the bed when going over large dips in the road or very large pot holes. I know this truck is made more for recreation than for work, but I consider camping and towing recreation and It will bottom out if I have it loaded with gear and people.
I informed Gerry at Super Springs and he is going to send me a re-engineered set of springs for the 05 and up Tacoma. They are supposed to be shorter and have longer shackles so they won't raise the ride height which we think was causing the problem. oh well, I still love the truck, just need to get this one aspect fixed.
05 Silver DC 4x4 TRD off road with tow
