qustion: air compressors - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > 2nd Generation (2005+)
2nd Generation (2005+) Discussion area for the 2nd generation of the Toyota Tacoma
Old 12-05-2006, 09:48 PM   #1 (permalink)
View xcomm's Photo Gallery
This is my first post, and I don’t want to look dumb.
I got my truck a couple weeks ago, and I have never had a truck before.
I plan on going out to the desert a lot with my truck and quad.
What I want to know is what’s is a good air compressors too fill up my tires from a low PSI, and also maybe seating a bead on my quad from time to time. I think I would need some thing with a tank to seat a bead. Also has any one here installed an air compressor on there truck? , or do most people just get a portable one.
My Truck: 2006 Toyota Tacoma 4x4 trd offroad SR5 "all stock(right now)"
xcomm is offline   Reply With Quote
Old 12-05-2006, 10:12 PM   #2 (permalink)
Official Newb
TucsonTRD's Avatar
View TucsonTRD's Photo Gallery
you might try ttora. it is more of a "hard core off roading" website. also, wheelers sell co2 systems that might work better for seating beads. i know they are capable of airing up many many tires quickly unlike standard air tanks
2006 Tacoma DC 4x4 OR, OME 884 Coils, Alcan custom leaf pack, Bilstein 5125's, Cooper Discoverer STT's 265/75R16
TucsonTRD is offline   Reply With Quote
Old 12-05-2006, 10:20 PM   #3 (permalink)
acidchylde's Avatar
View acidchylde's Photo Gallery
TTORA probably would be a good place to check, but since I've looked into this a little myself... ARB makes two, the larger of which runs about $300 and is primarily for their air-lockers. However, they also have a hose kit for it that can be used to run air tools or just air up. Tanks can be bought separately - I've seen one, three, and five gallon tanks around, with five being pretty common in local 4x4 shops here. I've no idea where I'd mount the thing if I even needed it though, it's relatively huge.
There are also a couple of threads around here that mention compressors and air tanks if you use the search to hunt for them.
acidchylde is offline   Reply With Quote
Old 12-05-2006, 10:21 PM   #4 (permalink)
Toyotanation
iTrader Score: 12 reviews
View toku58's Photo Gallery
The MV50 portable comp. is good to air up. But as for seating Beads? wow? You may need a tank. I've seen people do it with lighter fluid and a match in the field. But I would only recommend that as a last resort.
toku58 is offline   Reply With Quote
Old 12-05-2006, 10:25 PM   #5 (permalink)
View rugerm44's Photo Gallery
Puma makes an excellent 12 volt 100% duty cycle portable unit with tank attached.Go to yotatech and do a search.I own one so I can vouch for it.Its only around 35 lbs and has a handle to carry it by.That is if a portable is what your looking for.It gose up to 150psi if I remember right.For the quad a cheap 12volt one from auto zone would do.If your going to use on the truck I would get a good one.I bought it off ebay brand new for right at 200 bucks.By the way WELCOME to the forum.
rugerm44 is offline   Reply With Quote
Old 12-05-2006, 11:21 PM   #6 (permalink)
Pb
Surfing TN via iPhone
Pb's Avatar
iTrader Score: 15 reviews
View Pb's Photo Gallery
I just bought an Air Zenith compressor and 3 gallon tank for my air horns, air tools, and airing up tires. The Air Zenith is a beast. It can pump up to 200psi. It's very well made, but it might be more than you want to spend. About $290.00
http://www.air-zenith.com/
Pb is offline   Reply With Quote
Old 12-05-2006, 11:39 PM   #7 (permalink)
Forumatic Immunity!
docindahouze's Avatar
iTrader Score: 9 reviews
View docindahouze's Photo Gallery
airing up tire kent. where you gonna mount the tank and compressor.
05 Tacoma DC LB TRD Sport Super White.
"I thought I'd get your theories, mock them, then embrace my own. The usual."-House.
docindahouze is offline   Reply With Quote
Old 12-05-2006, 11:44 PM   #8 (permalink)
Pb
Pb's Avatar
I'm still layin' it out. There's a lot of room behind the front bumper, below the grill. I can probably mount the compressor and horns there. I might have to put the air tank under the cab on the side of a frame rail.
This is the compressor I got, except I got mine with a cooling fan on top of the heatsink fins. It's a very nice unit. It's overkill for my application, but you know me, Go big or stay home.
Old 12-05-2006, 11:50 PM   #9 (permalink)
Forumatic Immunity!
you better do a write up or i'm gonna be super pissed. i have been wanting to add a compr just by itself.
Old 12-05-2006, 11:53 PM   #10 (permalink)
Pb
Pb's Avatar
I'll take pics and stuff, don't worry.
Old 12-06-2006, 07:18 AM   #11 (permalink)
Banned
BillBrasky's Avatar
View BillBrasky's Photo Gallery
I just got a new 4wheelparts mag yesterday and they are advertising an ultra-compact PowerTank C02 bottle for $49. It's really small (about twice the size of a can of Coke) and it says it has enough air to raise the pressure 10psi on 10 normal-sized tires. So, you'd probably get 2 uses out of it per charge. But, for $50, thats not too bad.
BillBrasky is offline   Reply With Quote
Old 12-06-2006, 12:52 PM   #12 (permalink)
View live4swell's Photo Gallery
I do a decent amount of offroading, mainly beach and purchased the Tsunami Master Flow MF1050. Here is a pic and review:
http://www.gearinstalls.com/pepboys.htm
They sell them at Pep Boys, they run about $50-60 and when I got mine there was a rebate so it was a good deal. I have read many great things about it and I have used it with great success, It will air up 10 psi pretty quick. Pep Boys sells a couple Master Flow models so make sure its the right one.
Cool writeup on install:
http://www.4x4wire.com/tech/portable_oba/
live4swell is offline   Reply With Quote
Old 12-06-2006, 01:49 PM   #13 (permalink)
PiercedTiger's Avatar
View PiercedTiger's Photo Gallery
Viar seems popular in the off-road/crawling forums.
http://www.offroadwarehouse.com/Store_ViewProducts.asp!Cat!609
^sig by me!
Toytec 3" lift & AAL, 285/75r16 Kumho Road Venture
DTRL, Fog Light, locker, & diff breather mods, Bestop Supertop, Hi-Lift mount, hood struts, reinforced tailgate, BHLM, ABS kill switch, bed lights, rock lights
PiercedTiger is offline   Reply With Quote
Old 12-06-2006, 06:06 PM   #14 (permalink)
Thanks for all the input.
I think im going to go with "Tsunami Master Flow MF1050" for the truck right now.
Then later down the road look at other options. Moneys hard to come by with a new truck.
I know this will not seat a beed but its good for airing up the tires.
Down the road maybe a co2 bottle or see what Pb's install looks like.
HELP! Car won't Rev past 3000rpms supraskyguy 1st Generation (2003-2008) 26 09-19-2007 11:49 AM
Camry 95 Air Con intermittent ianm 3rd & 4th Generation (1992–1996 & 1997–2001) 1 08-13-2006 03:47 PM
Air filter usage ctrigger Archived Corolla threads 0 10-30-2004 11:49 PM
Open air filter or panel air filter?? Della D. Turbo MR2 Forum 7 10-18-2004 06:04 PM
Planned Air intake Mod... please suggest Audi Man MR2 Forum 10 11-25-2002 10:35 PM
