P0705 - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > 2nd Generation (2005+)
2nd Generation (2005+) Discussion area for the 2nd generation of the Toyota Tacoma
Old 12-06-2006, 08:26 AM   #1 (permalink)
Flash550's Avatar
View Flash550's Photo Gallery
USA P0705
Well the trip was nice of coarse did not have a good time. The truck did good. I pulled in the driveway and unloaded. Later on I spun my truck around like I normally park and the transmission slipped when put into drive. Now this morning I'm throwing a P0705 transmission error. I hope that it wasn't just the trip that caused this. I will be taking it in for service. Anyone else experiance something like this. I searched but didn't see anything.
Flash550 is offline   Reply With Quote
Old 12-06-2006, 09:09 AM   #2 (permalink)
Precision driver
mhadden's Avatar
iTrader Score: 7 reviews
View mhadden's Photo Gallery
It's the 1st I've heard of this
2011 Fit Sport 5MT
2011 Pilot EX-L AWD
2008 Goldwing Navi
mhadden is offline   Reply With Quote
Old 12-06-2006, 09:33 AM   #3 (permalink)
Theatre Nerd Person...yea
Sony's Avatar
View Sony's Photo Gallery
P0705 Transmission Range Sensor Circuit malfunction (PRNDL Input)
Looks like you busted the Shifter Position sensor to me when it slipped in drive.
2006 Toyota Tacoma DCab Long Bed SR5 V6 5spd Auto 4x4
Tow Package, 6 CD Changer, Rear Limited Slip Differential, 16" Alloy Wheels
Silverstar H4 Headlamps and
Silverstar 9005 Foglamps, Bed Storage Utility Lock Mod, Redline Tuning Gas Hood Struts, Roll-N-Lock M-Series Retractable Tonneau Cover
Sony is offline   Reply With Quote
Old 12-06-2006, 11:47 AM   #4 (permalink)
SP Jon M3's Avatar
View SP Jon M3's Photo Gallery
I had that exact same CEL code. P0705. Mine was because of the remote start that was installed. It turned out that the Black-white wire coming out of the ignition switch was being used by the remote start, but this was grounding out and reducing the voltage to .45v. The ECU needs to see 10-14v from this wire when it's in any position except for P or N. I basically disconnected that lead from the Black-White and that solved my problem. Now I have to go back and find a new source for the remote start. Just so you know the P/N switch is on the passenger side of the transmission. It has a plug with about 7 or 8 wires coming out of it. There is a whole procedure on how to diagnose the error. I can send you the Toyota pdf for troubleshooting that code if you'd like. Just PM me your e-mail and if you have a 4x4 or prerunner (they have two different PDFs for those).
I also drove around for over a month with that error. The trans goes into a "limp" mode and will shift harder than normal, and can sometimes take a few seconds to get into drive. But other than that it drove normal and I didn't notice and slipping.
Another thing you can try first is resetting the computer by pulling the neg battery cable and let sit for about 5 min. This should clear the code and then see if it comes back again. It will take two starts of the truck and placing the truck in gear before the code will return.
EDIT: Looking at you cardomain it looks like you've installed an Eclipse HU. If you connected the park/neutral wire for any reason (liek to watch DVDs or if you haev Navi and it wants to see a Park signal) this could cause your error. This wire would have been purple behind the passenger side kick-panel or the Black-White wire coming from the ignition.
Jon
'05 Double Cab 4x4 V6 SR5 Auto White
Mods: Fabtech DirtLogic 2.5 coilovers and Total Chaos UCAs up front, Deaver springs and Bilstein 5150's in the back, American Racing Mojave 16x8, BFG M/Ts 265/75/16, Demello Bolt-on sliders.
'01 Double Cab 4x4 V6 Auto TRD Black, you will be missed.
SP Jon M3 is offline   Reply With Quote
Old 12-06-2006, 08:10 PM   #5 (permalink)
Flash550's Avatar
Since the remote start requires two starter wires the green/black, and the white/black.
I cut the ground wire on the key bypass transponder and thus it works fine. I removed the power wire for the transponder from the green/black to the black/red ignition wire live during cranking. That way there is not extra load and my transmission is working correctly. Thanks for the Help Jon.
Old 12-06-2006, 08:55 PM   #6 (permalink)
SP Jon M3's Avatar
Cool! I'm glad you were able to get it fixed!
Jon
CEL code P0705 Transmission Range Sensor Circuit Malfunction (PRNDL Input) myoda999 5th & 6th Generation (2002-2006 & 2007-2011) 0 03-06-2006 05:34 PM
