Wiring question - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > 2nd Generation (2005+)
2nd Generation (2005+) Discussion area for the 2nd generation of the Toyota Tacoma
Old 12-06-2006, 04:03 PM   #1 (permalink)
YS4
View YS4's Photo Gallery
Wiring question
I'm trying to wire up a set of Piaa 510 fogs, and I want to thread the wires with the switch into the cabin from the engine bay. How do I get past the firewall. I see a rubber gasket on the drivers side. Dio I make a slit through that and then seal it up with silicone? TIA.
YS4 is offline   Reply With Quote
Old 12-06-2006, 04:20 PM   #2 (permalink)
Fitz235's Avatar
View Fitz235's Photo Gallery
That will work. Make the hole as small as possible though.
Years ago, I used to install mobile phones in cars, and we would tape the wires to a small piece of fish tape and use that to poke through the grommets, most of the time the seal on the wires was so tight, silicone wasn't needed, but I would use it anyway, just to be sure.
Black 05 V6 AC 4WD TRD Offroad
Bilstien 5100's, 275/70/16 Revo's, Lorado Tonneau, Factory DeeZee's
Fitz235 is offline   Reply With Quote
Old 12-06-2006, 04:28 PM   #3 (permalink)
View Fluxaholic's Photo Gallery
That's exactly what I did. I drilled a hold through the rubber grommet and sealed it with silicone. Like Fitz said, you don't really need the silicone because the grommet will tighten around the wires, but I'm a little anal.
Fluxaholic is offline   Reply With Quote
Old 12-06-2006, 04:46 PM   #4 (permalink)
'06 Access 4x4 I4 Manual
View TacoCamry0605's Photo Gallery
I found an "extra" little pass-through on the main wire grommet passing through the firewall. It is under the main wire trunk. The picture below is taken from above looking down. I think it was intended for foglight additions (mine came without fogs but I added them). If you have this, you can cut the end off or cut a slit and seal it after passing the wire through. I actually just put a zip-tie around it with the wire inside to keep the water and dirt from getting in. Just another thought.
2006 Tacoma 4x4 I4 access cab
http://www.cardomain.com/ride/2430812
TacoCamry0605 is offline   Reply With Quote
Old 12-06-2006, 08:21 PM   #5 (permalink)
Precision driver
mhadden's Avatar
iTrader Score: 7 reviews
View mhadden's Photo Gallery
yeah don't drill...no need. I went though that rubber grommet, but rain it through where the hood release cable goes...no need to use silicon either.
2011 Fit Sport 5MT
2011 Pilot EX-L AWD
2008 Goldwing Navi
mhadden is offline   Reply With Quote
Old 12-06-2006, 08:25 PM   #6 (permalink)
PiercedTiger's Avatar
View PiercedTiger's Photo Gallery
I grabbed an old coat hanger, straighten it, and pushed it through the rubber sleeve pictured above where the hood release cable comes out. Got enough of it through to see on the other side, angled it down so I could pull it through, and taped the wires to the engine end of it. Then just pulled the hanger through past the pedals, pulled off the tape, and kept wiring.
It's a pretty tight fit so I had to really push and wiggle the coat hanger, but I'm pretty sure it'll keep moisture out.
^sig by me!
Toytec 3" lift & AAL, 285/75r16 Kumho Road Venture
DTRL, Fog Light, locker, & diff breather mods, Bestop Supertop, Hi-Lift mount, hood struts, reinforced tailgate, BHLM, ABS kill switch, bed lights, rock lights
PiercedTiger is offline   Reply With Quote
Another Trailer wiring question Don W 1st Generation (2001–2007) 3 09-29-2008 02:51 PM
Stock HU wiring color confusion.. rainman Audio, Video, and Security - Tech 1 02-02-2005 03:17 PM
blue LED wiring question? MattSWE Camry & Solara Lounge 8 12-19-2004 07:52 PM
Taking out motor. Have question about engine wiring harness bennington28 Hardcore Tech and Competition 4 08-19-2003 09:01 PM
Wiring question 4AFred Archived Corolla threads 0 05-22-2003 07:52 PM
