4 Wheel Drive Jerk! - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > 2nd Generation (2005+)
2nd Generation (2005+) Discussion area for the 2nd generation of the Toyota Tacoma
Old 12-07-2006, 08:48 PM   #1 (permalink)
I'm 1 in Southern Ont.
View BABAROGA's Photo Gallery
4 Wheel Drive Jerk!
Alright got some snow here today, decided to go play around. When I shift in and out of 4 wheel drive my truck makes this hideous clunk and jerks. Any ideas? I am pissed! its an 05 Reg.
BABAROGA is offline   Reply With Quote
Old 12-07-2006, 09:10 PM   #2 (permalink)
20' Daredevil (Retired)
Gameroom cash: $510182
View Splicer's Photo Gallery
Are you going into/out of 4Low or are you shifting between 2High and 4high? At what speed?
Are you momentarily lifting off the throttle as you go in/out of 4WD?
Are you doing this on snow or on pavement?
2005 D-Cab O/R 4x4
Splicer is online now   Reply With Quote
Old 12-07-2006, 09:24 PM   #3 (permalink)
Hi, going from 4 high to 2 high is where I get the clunk. I get a light hard to hear sound when I go into 4high, but coming out i get a crazy clunk and jerk
I did it twice today from almost standing still, and the second time at approx 30mph. I did it on snow both times.
Old 12-07-2006, 09:31 PM   #4 (permalink)
Can't think what it might be, then, aside from this:
If you are holding the throttle steady (or worse, accelerating) as you make the shift, try momentarily lifting as you shift. It will relieve the strain on the powertrain & may allow for smoother transitions.
2005 D-Cab O/R 4x4
Old 12-07-2006, 09:40 PM   #5 (permalink)
Thanks I'll test it out in the morning on my way to the office. But tonight I was at a complete stop when I did it so i cant see it being that, but I'll try anything to avoid the stealership.
Old 12-07-2006, 09:57 PM   #6 (permalink)
Precision driver
mhadden's Avatar
iTrader Score: 7 reviews
View mhadden's Photo Gallery
Could be some slight binding if you've been "monkeying around in the snow" and have hit some solid patches of concrete/asphalt while turning. I have a small clunk, but I percieve and am pretty sure that its normal.
2011 Fit Sport 5MT
2011 Pilot EX-L AWD
2008 Goldwing Navi
mhadden is offline   Reply With Quote
Old 12-07-2006, 11:35 PM   #7 (permalink)
Trevor
View Adventure North's Photo Gallery
If you are driving slow it's normal to sometimes get a clunk or a little jerk when engaging or disengaging the transfer case, more likely when disengaging though. It's just the tension being released once the shift fork inside moves and releases the engagement of the front drive shaft. You're more likely to get a clunk or some noise if you are turning or just turned and try and switch out of 4wd, not to worry. You should hear a rear locker disengage, it can be even louder. It's a little unnerving if you've never experianced it before.
My Images
Trevor
Adventure North is offline   Reply With Quote
Old 12-08-2006, 05:50 AM   #8 (permalink)
docktortal33's Avatar
View docktortal33's Photo Gallery
change out to syn oil front back and transfer case no more clunk
Extang Black Max, Toy tube steps,Toy bug defl. , door sil protectors,Weather Tech liners,20% tint,Cobra 360 radar,fog light mod,Compu star remote start sirius radio, jl audio amp spk. alpine head MBRP dual catback FT 8900 ham radio
docktortal33 is offline   Reply With Quote
Old 12-08-2006, 06:40 AM   #9 (permalink)
I appreciate ALL the comments. I was initially pissed off becuase I traded in my GM Sierra for this Toyota and I never had such a clunk from the GM, but I did get about 5000 recall notices on it, and am still getting them (I hav'nt had that truck in a year).
If your all saying its nothing to worry about I wont worry. Was just kinda scary.
Old 12-08-2006, 08:13 AM   #10 (permalink)
PiercedTiger's Avatar
View PiercedTiger's Photo Gallery
Also, if you have a manual press the clutch in.
I usually switch drive modes while moving at least a little in a straight line. I make sure I'm rolling straight, twist the knob, back off the gas, and hit the clutch. I hardly notice any noise now. I DID notice it a lot when I first got it. But I have over nearly 25k on the truck now, have used 4hi off road several times, and driven to or from work in 4hi (24 miles) a couple times so it's probably also broken in by now. The clutch part seemed to help a lot though. Took most of the tension off the system.
Edit:
When I twist the know the 4wd light flashes, and almost as soon as I hit the clutch the light goes out. Again, I hardly hear anything now. Have also driven a couple miles of straight road while checking my locker mod, and that's fairly quiet now too. I usually just here a slight "click" as either one is engaging.
^sig by me!
Toytec 3" lift & AAL, 285/75r16 Kumho Road Venture
DTRL, Fog Light, locker, & diff breather mods, Bestop Supertop, Hi-Lift mount, hood struts, reinforced tailgate, BHLM, ABS kill switch, bed lights, rock lights
PiercedTiger is offline   Reply With Quote
Old 12-08-2006, 08:19 AM   #11 (permalink)
Precision driver
mhadden's Avatar
I have the 5-speed and have a slight clunk regardless of pushing in the clutch or not. I have noticed that if you are accelerating, even slightly, it won't disengage, so I always let up on the acclerator for it to disengage, but I don't clutch...there's really no need to.
2011 Fit Sport 5MT
2011 Pilot EX-L AWD
2008 Goldwing Navi
Old 12-08-2006, 08:19 AM   #12 (permalink)
SOOPER DOODIE!!!
View jdwilson's Photo Gallery
first four wheel drive?
YOU SAY REDNECK LIKE IT'S A BAD THING.
2007 Tacoma Access Cab, 4cyl., 5 speed, Prerunner, and FOOL INJECTED.
jdwilson is offline   Reply With Quote
Old 12-08-2006, 08:21 AM   #13 (permalink)
short beds are ghey
View BrandonM7's Photo Gallery
If the clunks this one makes scare you, you would've shit yourself if they still had the manual lever for engaging it.
BrandonM7 is offline   Reply With Quote
Old 12-08-2006, 08:25 AM   #14 (permalink)
short beds are ghey
Have any of your previous vehicles had an automatic locker (like a Detroit?) That's seriously unnerving when you aren't used to it. When the one in my Jeep would release (like turning into a parking space,) it would pop LOOOOUD, almost like a gunshot or axle breaking. Once I got used to it that was kind of fun, though, as I knew how to load tension on it and pretty much make it release on command, so I could make people jump.
Old 12-08-2006, 08:31 AM   #15 (permalink)
Maybe no need too, but I've noticed it does engage or disengage faster if I do that.
Sounds like something I would do....
^sig by me!
88 2 wheel drive wheel bolt pattern fast68 Pre-88 Toyota Pickup/Hilux 10 04-11-2007 02:44 AM
Wheel offset---please check--help! kemo sabe 1st Generation (1995.5–2004) 3 08-26-2006 01:28 PM
2000 tundra 4 wheel drive problem schlo_00Tundra 1st Generation (2000–2006) 1 09-14-2005 03:43 PM
Highlander 2 wheel drive or 4 wheel drive ? hl2003 1st Generation (2001–2007) 4 03-04-2004 09:15 PM
