Question on tire rotation - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > 2nd Generation (2005+)
2nd Generation (2005+) Discussion area for the 2nd generation of the Toyota Tacoma
Old 12-08-2006, 10:01 AM   #1 (permalink)
boomer08's Avatar
View boomer08's Photo Gallery
I had Bridgestone AT Revos put on in Sept and I was curious about how or which direction everyone rotates the tires. I took the truck back to Expert Tire where I bought the tires and they rotate the front straight back and back straight forward. It would seem to me that after rotating the same direction everytime that you wouldn't get very good wear and longevity out of the tires as you would if you rotated the front straight back and criss crossed the backs to the front or vise versa.
boomer08 is offline   Reply With Quote
Old 12-08-2006, 10:08 AM   #2 (permalink)
Twinkle Twinkle
MrSmitty's Avatar
View MrSmitty's Photo Gallery
I personally rotate the front straight to the back and criss-cross the rears to the front every 5000 miles.
I am by no means a tire tread wear expert but I think I read what the manual recommended.
MrSmitty is offline   Reply With Quote
Old 12-08-2006, 10:37 AM   #3 (permalink)
View TRDRadRedTaco's Photo Gallery
That is how the dealer rotates mine. I remember I asked awhile ago why they go straight front to back, etc. AS I'm typing I can't seem to remember the what he said but it seemed like a valid reason.
TRDRadRedTaco is offline   Reply With Quote
Old 12-08-2006, 10:45 AM   #4 (permalink)
Row Dialin'
boone's Avatar
View boone's Photo Gallery
Edit: MrSmitty's way is correct.
If you want to get real complicated, mix in the full size spare.
2005 V6 4x4 Silver Access Cab, K&N/AEM Hybrid Intake, GC + 3oz. ARx, K&N HP-2009
265/70/17 Nitto Terra Grapplers, Black KMC XD Enduro Wheels, TRD Exhaust, URD Short Shifter
boone is offline   Reply With Quote
Old 12-08-2006, 11:40 AM   #5 (permalink)
View Fluxaholic's Photo Gallery
It seems that by moving the front tires straight back and visa versa, the tire shop is saving itself some effort if the tires are uni-directional. Doing it that way, they don't have to take the tires off the wheels when they rotate them. If the tires have to switch sides though, then the tires have to come off and get flipped around.
I've always had it done the way boone's picture shows. Maybe I'm wrong here, but it seems like the tire place is just being lazy.
Fluxaholic is offline   Reply With Quote
Old 12-08-2006, 11:46 AM   #6 (permalink)
Twinkle Twinkle
MrSmitty's Avatar
Actually, what I wrote is incorrect.. I said front straight to back... It should of read back straight to front and criss the front tires onto the back of the truck.. How friggen confusing.. I knew 1 set gets criss-crossed..
Anyways, I just typed it backwards.. I appoligize.. and the above diagram is the way I rotated the tires at 5000 Miles... and when I hit 10K very soon I will rotate them like the above diagram again.
Old 12-08-2006, 12:01 PM   #7 (permalink)
Row Dialin'
boone's Avatar
Close enough. I know there is a diagram in the manual. I'm pretty sure it looks like the one I posted. Too cold outside to check.
Old 12-08-2006, 12:24 PM   #8 (permalink)
View lrak's Photo Gallery
Is the AT Revo a directional tire or not?
Some tires have arrows on the sidewall that indicate the direction the tire is supposed to be rotated for either better traction (tread pattern) or longer life (belt construction). On those tires you only rotate front to back because crossing the wheels spins the tires in the opposite direction it was designed to spin.
lrak is offline   Reply With Quote
Old 12-08-2006, 12:27 PM   #9 (permalink)
Twinkle Twinkle
MrSmitty's Avatar
Great Question, but the diagram above is for non-directional tires.
Old 12-08-2006, 01:22 PM   #10 (permalink)
boomer08's Avatar
I just called a couple of Bridgestone dealers and they said that the Revo is not a directional tire and that is the way they recommend to rotate fronts straight back and back straight forward. He also said because it was a 4X4 is also why they do it. He did also state that they would rotate anyway I wanted. Just doesn't seem you would get the most wear.
Old 12-08-2006, 06:11 PM   #11 (permalink)
20' Daredevil (Retired)
Gameroom cash: $510182
View Splicer's Photo Gallery
Boone's schematic is the way I've been rotating mine on all my vehicles for many years. It equalizes the wear about as much as possible. Dunno why any tire shop would refuse to swap sides on non-directional tires (which most are, including REVOs), other than laziness or a wish to sell you tires sooner. Typically, right side tires tend to wear more rapidly than left side.
For those who move the fronts straight back and cross the rears to the opposite side front, the results are identical -- just remember which method you are using when it's time to do it again.
Also, if you run different air pressure front-to-rear, remember to adjust the pressure after you rotate.
2005 D-Cab O/R 4x4
Splicer is online now   Reply With Quote
Old 12-08-2006, 06:42 PM   #12 (permalink)
Official Newb
TucsonTRD's Avatar
View TucsonTRD's Photo Gallery
that makes no freakin sense. did they also tell you that cause your truck is white, or whatever color it is, that you can only make left turns? just because your have a 4x4 doesn't change how you rotate tires.
2006 Tacoma DC 4x4 OR, OME 884 Coils, Alcan custom leaf pack, Bilstein 5125's, Cooper Discoverer STT's 265/75R16
TucsonTRD is offline   Reply With Quote
Old 12-08-2006, 07:10 PM   #13 (permalink)
Master Geniculater
Bamboo's Avatar
View Bamboo's Photo Gallery
According to BFG it makes a difference if your rig is FWD, RWD or 4WD. Click on the "How to rotate" link towards the botton right.
http://www.bfgoodrichtires.com/overv...t-a-ko/44.html
2006 Tacoma SR5 ACab 4x4 2TR-FE Engine - 5 SP Manual - LT265/70R 16 BFG TKO All Terrains
Bamboo is offline   Reply With Quote
Old 12-08-2006, 07:32 PM   #14 (permalink)
View tsl90's Photo Gallery
Unless I'm crazy (which is quite possible) the RWD and 4WD are the same.
TL
06 Silver Streak Mica V6 4x4 Access Cab TRD Off Road
tsl90 is offline   Reply With Quote
Old 12-08-2006, 08:36 PM   #15 (permalink)
Master Geniculater
Bamboo's Avatar
TL
Considering the fact that most of us four wheelers are driving in two wheel drive the majority of time it's comforting to know........My 2001 Durango had street performance directionals on it and Yokahama recommended front to back and vice versa. It seems the tire dealers who rotate for free take the quick and easy route. It figures.......
You should trust your tire manufacturer to give you the correct info on rotation.
Tires Feedback: Everyone please contribute. EKam Hardcore Tech and Competition 98 12-19-2006 02:05 AM
Upgraded Tire Option Question? Nhayden51 2nd Generation (2005+) 6 11-09-2006 12:23 AM
one simple tire question MattSWE 1st & 2nd Generation (1983–1986 & 1987-1991) 0 08-24-2006 12:40 AM
Winter Tire Question... newtestleper@ho Archived Corolla threads 3 11-17-2005 02:31 PM
Question about tire chains/cables ABTRD General Discussion 0 02-24-2005 11:48 AM
