Climate control thinks I'm a dumbass - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > 2nd Generation (2005+)
2nd Generation (2005+) Discussion area for the 2nd generation of the Toyota Tacoma
Old 12-14-2006, 11:16 AM   #1 (permalink)
dl1027's Avatar
Gameroom cash: $127425
View dl1027's Photo Gallery
I am new to Toyotas. I just got my first (Taco) less than 90 days ago. I just noticed that when I turn the climate control selector to any of the two that blows on the windshield that the AC kicks on. But heres the kicker. The AC light does not come on telling me that it's on. I can tell it's on by the smell of it and the fact that when I turned the selector to feet it began fogging up my windows again. If I wanted the AC to come on I would have turned it on. This sucks and is exactly like domestic vehicles. I wish there was a way to blow air on the windshield without the AC on too.
dl1027 is offline   Reply With Quote
Old 12-14-2006, 11:24 AM   #2 (permalink)
SOOPER DOODIE!!!
View jdwilson's Photo Gallery
when you have it in defrost(blowing on the windshield) it will blow cold air(compressor will come on) if you don't want cold air blowing on the windshield, turn the tstat to the middle position, otherwise, the compressor will come on.
YOU SAY REDNECK LIKE IT'S A BAD THING.
2007 Tacoma Access Cab, 4cyl., 5 speed, Prerunner, and FOOL INJECTED.
jdwilson is offline   Reply With Quote
Old 12-14-2006, 11:31 AM   #3 (permalink)
Row Dialin'
boone's Avatar
View boone's Photo Gallery
Wah?!?
The A/C comes on intermittently to remove moisture from the air. It kicks on maybe every 30 seconds for only a second or two. It shouldn't be affecting your in-cab temperature.
Whether it comes on or not has nothing to do with where the temp dial is set.
Most cars use the A/C in conjuction with the defroster (windshield) setting. No, it will not indicate the A/C is on. It is not kicking on for the intent of cooling. Only for removing condensation.
2005 V6 4x4 Silver Access Cab, K&N/AEM Hybrid Intake, GC + 3oz. ARx, K&N HP-2009
265/70/17 Nitto Terra Grapplers, Black KMC XD Enduro Wheels, TRD Exhaust, URD Short Shifter
boone is offline   Reply With Quote
Old 12-14-2006, 11:42 AM   #4 (permalink)
rydr1's Avatar
View rydr1's Photo Gallery
alright since we are in the climate control issues i have one.
when i turn the air positon knob to just the feet it will blow on the windshield too. when i turn it to the just the windshield it will blow in the vents to the passengers too.
i did remove the a/c controls to install a dvd player and i think it lost its memory.
does anyone know if the dealer is the only place to fix it?
rydr1 is offline   Reply With Quote
Old 12-14-2006, 11:42 AM   #5 (permalink)
C5 Meter Minder
hoofhearted's Avatar
View hoofhearted's Photo Gallery
Originally Posted by boone
Wah?!?
+1
Before we had that, people would bitch about poor defog performance. We would
tell them to turn it on.
You gotta be tough to fly the heavies!
hoofhearted is offline   Reply With Quote
Old 12-14-2006, 11:46 AM   #6 (permalink)
dl1027's Avatar
Because of those people we all have to have a climate control that thinks for us? I guess it knows better than me what should be turned on.
Old 12-14-2006, 11:47 AM   #7 (permalink)
Row Dialin'
boone's Avatar
Still under warranty? Take it to the dealer, show them it's not working correctly and have them replace the HVAC unit. The worst they could do is say no.
I doubt it lost it's memory. I'm sure they don't use volatile EPROM from the early 90's to program our HVAC units. Maybe you messed up some of the wires when putting it back in, you could be getting a cross connection or it's all in your head and it's been that way all along.
I wouldn't mess with it yourself. Not worth the hassle or the chance of f@#king it up more.
Old 12-14-2006, 11:48 AM   #8 (permalink)
Row Dialin'
boone's Avatar
Well apparently it does because you said yourself the windshield fogs up when you turn it off. So I guess it does know what's best for you.
This isn't isolated. They've been linking the defroster and the compressor for 10+ years now.
Old 12-14-2006, 11:57 AM   #9 (permalink)
dl1027's Avatar
Well apparently it does because you said yourself the windshiled fogs up when you turn it off. So I guess it does know what's best for you.
OK. But the damn thing is like a crack addiction. Once you turn it on, you can't turn it off. If you do the windows will begin fogging up real fast. Plus you have to put up with that vile smell of "recently turned off AC". So once you turn it on you must leave it on or suffer from worse fogging than you originally had.
Old 12-14-2006, 12:02 PM   #10 (permalink)
Row Dialin'
boone's Avatar
Wait a few months. Your truck is brand new. I don't have the smell anymore.
I love the system. Clears the condensation in a few seconds.
Or you can do what I do most of the time. Crank the heat up a notch or two above what you would normally have it set on and drive around with the window cracked. No moisture. Still warm. In your case, no smell. Everybody wins.
Old 12-14-2006, 02:26 PM   #11 (permalink)
rydr1's Avatar
@boone yeah you could be right that it was always like that. is there any way you could check yours and see if it happens the same way im explaining it?
im not trying to compare manufacturers but i work for volkswagen and i know in certain occasions the a/c controls need to be reset.
Old 12-14-2006, 05:27 PM   #12 (permalink)
Gameroom cash: $287985
View worthywads's Photo Gallery
My honda allows me to reprogram so that I have the choice of A/C or not with defrost. I'd like to be able to do the same with my Tacoma, but it doesn't seem to be possible.
I'd rather think for myself too. My wife tends to set it to defrost and forget it, and would be running the a/c all the time. At least now she can turn it off, which she does most of the time. It's dry where I'm at.
2005 Impulse Red 4x2 Access cab 2.7L 5-speed SR5.
worthywads is offline   Reply With Quote
Old 12-14-2006, 06:14 PM   #13 (permalink)
View sgtshultz's Photo Gallery
What kind of Honda do you have??
sgtshultz is offline   Reply With Quote
Old 12-14-2006, 06:27 PM   #14 (permalink)
Element
Old 12-14-2006, 06:51 PM   #15 (permalink)
cam2Xrunner's Avatar
Read here.
http://www.customtacos.com/forum/sho...hlight=defrost
This mod might be doable for the new Tacoma.
HELP! Car won't Rev past 3000rpms supraskyguy 1st Generation (2003-2008) 26 09-19-2007 11:49 AM
Whiteline; Superpro and Dobinson Group Sale ...PART II raptorracing Supporting Vendor Sales 93 05-02-2007 05:02 AM
OBD-II Trouble Codes: Full List! thespud Corolla Lounge 0 07-30-2006 10:53 PM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 2 03-30-2006 12:49 PM
