Okay non moded 2 month old 06 DC LB.
When I press the brake pedal there is a really high picthed whine that is coming from somewhere in the cab. This might be similar to the other post however I've narrowed it down to only when the brake lights are coming off and on. If I pulse the pedal the whining pulses with it. When I disconnected the blue harness brake light switch the whine is gone (but obviously the brake lights don't work either). I checked the fuse and third brake light bulbs for filament singing, (common in household dimmers when the filament in a bulb vibrates from different amp and current draw causing a high pitched whining sound or ringing) but that didn't do it.
This could be what other may be hearing unless your getting it regardless of the brake pedal being pushed. Happens with or without the key in the ignition.
Any ideas? Maybe a relay or loose connection?
Here's the thread that is very similar. Anybody have any results there as well?
http://www.toyotanation.com/forum/t162334.html
