3" LIFT & Alignment UCA's - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > 2nd Generation (2005+)
2nd Generation (2005+) Discussion area for the 2nd generation of the Toyota Tacoma
The Gameroom
There is 1 open event in the Betting section.
Old 04-01-2007, 04:09 PM   #1 (permalink)
Toyotanation
iTrader Score: 12 reviews
View toku58's Photo Gallery
UCA's
The new info can be found here.
UCA's and Alignments
Last edited by 08TRDOFFROAD; 01-30-2010 at 04:11 AM. Reason: Added link to new info
toku58 is offline   Reply With Quote
Old 04-01-2007, 04:25 PM   #2 (permalink)
Forumatic Immunity!
docindahouze's Avatar
iTrader Score: 9 reviews
View docindahouze's Photo Gallery
UK
you are one sick man toku. i'm deeply concerned, i'm suggesting that you be sedated immediately and undergo a full psychological evaluation.
oh yeah, i knew this already, good for you to post this up though. HAHA.
05 Tacoma DC LB TRD Sport Super White.
"I thought I'd get your theories, mock them, then embrace my own. The usual."-House.
docindahouze is offline   Reply With Quote
Old 04-01-2007, 04:30 PM   #3 (permalink)
Toyotanation
Thanks Doc!! From you I take that as a compliment!!!
Old 04-01-2007, 05:03 PM   #4 (permalink)
Trevor
View Adventure North's Photo Gallery
It's like a women walking around all day on the tip of her toes. (To be 3 inches taller) Yes! Her foot is designed to articulate into this position. But overtime she will have some serious problems. Because her feet wern't designed to walk that way, for extended periods of time!
But do it correctly? And give her a comfortable pair of pumps to wear? Now she is 3" taller and the risk of injury or complications is now greatly reduced!
Toku- TN's very own orthopaedic surgeon. Better send this notice out to all those pretty little ladies wearing those clear heels.
My Images
Trevor
Adventure North is offline   Reply With Quote
Old 04-01-2007, 05:16 PM   #5 (permalink)
Toyotanation
LOL!!! To be honest?? I don't really know what PUMPs are???
I knew I'd catch some ribb'n for this thread!!
Old 08-27-2007, 03:55 AM   #6 (permalink)
4x4 User
haloplayerhater's Avatar
View haloplayerhater's Photo Gallery
I understand, sex is way better with a partner!
2007 Tacoma Double Cab V6, TRD Off-Road 4x4, Strawberry Ice Cream, 5-Speed Auto, Desert Sand Mica.
haloplayerhater is offline   Reply With Quote
Old 08-27-2007, 07:27 AM   #7 (permalink)
tacomatose
voodoochile's Avatar
View voodoochile's Photo Gallery
I'm going to sell my lift and use the funds to get laid.
Thanks for the practical advice, Toku!
2007 taco ac, 2.5 fjc camburgs, aal, arb bumper, superwinch,
all-pro sliders, oba, 33" bfg muds, arb air locker
voodoochile is offline   Reply With Quote
Old 08-27-2007, 12:37 PM   #8 (permalink)
i <3 Miley Sirus.
tonythemarine's Avatar
iTrader Score: 7 reviews
View tonythemarine's Photo Gallery
what about sex with a doll? is that like a lift with some crappy UCAs?
^ a sockmonkey prod. ^
tonythemarine is offline   Reply With Quote
Old 08-27-2007, 01:27 PM   #9 (permalink)
tacomatose
It's probably indiscernible from a set of rear airbags. Just my guess, though. I haven't tried either one.
Old 08-27-2007, 02:06 PM   #10 (permalink)
View lambone's Photo Gallery
I just bought a set of Bilstien 5100's from downsouthmotorsports (ebay) and plan on lifting the front end 2" to level it out and give my tires a little more clearance. I have 265 muds that rub if going over a bump in a hard turn.
My question is would the TC UCA's be a big improvement over the stock handeling with just the 5100 lift?
When I changed the stock tires to the mud tires I noticed a lot more wheel "feedback" in the steering wheel. And the truck seems to float around the road a bit more. I'm not sure how much of this is just the tire, and/or how much it could be improved with the UCAs. I know they help, but how much?
I guess my question is would you put the TCs on a stock truck? Or with 5100 2" leveling kit vs Toytec or Coilovers 3".
Thanks
'07 DC LB TRD Sport/Superwhite/TRD Intake & Exhaust/SnugTop XV Canopy/5100s/Eagle Alloy 185s 17"/Nokian Vatiiva M/T 265/70/17
lambone is offline   Reply With Quote
Old 08-27-2007, 02:18 PM   #11 (permalink)
Trevor
An aftermarket UCA will not improve on steering or wander so long as you have or will have your truck aligned properly. Problem with going up to around 3" of lift is you can only get the alignment specs so close to ideal, which of course results in road wander. At only 2" of lift you should be able to have your truck aligned properly without the need for them. Tire size and tread pattern do not effect your alignment but can effect road feel, most likely what you have noticed. Aftermarket UCA's will not change that.
My Images
Trevor
Old 08-27-2007, 04:05 PM   #12 (permalink)
Heltah-Skeltah's Avatar
View Heltah-Skeltah's Photo Gallery
I can confirm with 2-1/2" of lift the caster is way off. Camber is also just out of spec.
'07 Dub Cab Long Bed 4x4 Sport,Black,LR coilovers (3"),TC UCA's, Alcan AAL,Bilstein extended shocks, ProComp7089, 265/70BFGTAKO,Borla SIDO,Sanded flaps,Bed storage locks,Grillecraft black mesh,SGII w/ BlendMount,DF-TOY, C2C Hoodstruts & Eyelids,Wet Okoles,Certified Brokanic
Heltah-Skeltah is offline   Reply With Quote
Old 08-27-2007, 05:41 PM   #13 (permalink)
thanks AdventureNorth!
maybe someday if I have extra $ to burn...or when I get another spell of upgradeitus.
Old 12-01-2007, 06:54 PM   #14 (permalink)
jtrovato's Avatar
Gameroom cash: $161175
View jtrovato's Photo Gallery
Is the caster adjustable on our trucks? When I got my alignment done after the 5100's at 2.5", the caster is the only spec that was off and they said they could not adjust it on our trucks. Right now it's set at 0.55 degrees and 0.75 degrees, so it's about a full degree less than it should be. From reading the tech article on Tire Rack, this is why I have the slight wandering and decreased stearing effort at highway speeds. Is the TC UCA the only way to adjust caster back to where it should be or is there something else we can do on our trucks?
jtrovato is offline   Reply With Quote
Old 12-01-2007, 07:01 PM   #15 (permalink)
Toyotanation
The Caster is adjustable. TC UCA's are one way All Pro UCA's are another.
lift pics 3" lift w/ 3" body 2005/06 checkster 2nd Generation (2005+) 43 12-31-2006 08:43 PM
3" revtek lift/ tires yota06taco 2nd Generation (2005+) 6 11-29-2006 09:26 PM
Glassworks and a 3" lift? Not asking about 6" lifts just 3"? Nicky9 2nd Generation (2005+) 2 06-13-2006 09:36 AM
3" Spacer Lift or 3" Add-a-Leaf Dahveee 2nd Generation (2005+) 16 04-27-2006 01:02 AM
How many people have a 3" lift? marnes2986 2nd Generation (2005+) 7 04-21-2006 01:11 AM
