Ticking fan noise on low setting. - Page 3 - Toyota Nation Forum : Toyota Car and Truck Forums
2nd Generation (2005+) Discussion area for the 2nd generation of the Toyota Tacoma
#31 Old 01-12-2008, 03:13 PM
Of sturdy stock; fervent
tomesd's Avatar
Quoted: 0 Post(s)
I have (had) the exact same ticking and when I searched this on the forum I read where someone just hit it with their fist and it stopped- well I tried this and the shit stopped!! It will probably start back but at least I get some relief for a while. It is annoying as hell!
'06 OR 4x4, HAC-DAC, VSC, TRD Supercharger/DTLT's/TRD exhaust/CAI, Snugtop XV, Frontrunner rack, OME 886's, Dakar springs, TC UCA's, TW DS, ATX Artilleries w/ BFG MT 285/70/R17's, Downey skid plate, Demello sliders
tomesd is offline
#32 Old 01-19-2008, 06:26 PM
Quoted: 0 Post(s)
Solution to the A/C heater blower tick
Air Conditioning Tick/Noise
here's to hoping your have your profile set to send you an email with updates to this thread.
enjoy.
2002 Impulse Red Pearl Tacoma DoubleCab 4x4 v6 S/C 195,000 miles and counting!!!
Favorite Beer - Blue Moon
eyedoc is offline
#33 Old 09-26-2010, 11:49 AM
KDI
Quoted: 0 Post(s)
Canada
enjoy.
The advice in the link above did the trick for my 07 Double Cab. I didn't have to take out the glove box but it was the two silver screws under the plastic cover that I was able to tighten and make the VERY ANNOYING ticking disappear. Thanks!!!
KDI is offline
#34 Old 10-28-2011, 11:47 AM
Quoted: 0 Post(s)
My 2011 was doing this. I took it to the dealership the 1st time and they claimed to have pulled a leaf out and told me to come back if I hear the rattling noise again. About a mile down the road from the dealership the rattling noise was there. Today I went back (about 5 days later) and informed them that it is rattling again. Once again they claimed to have found a leaf and told me to come back if I heard it again. I asked to talk with the mechanic and informed him that it is the blower fan. That I have made adjustments to it prior to silence it for a couple weeks at a time. As soon as I started explaining 5.5mm socket and phillips screw driver he started to listen and informed that the 05-09's are known to have blower fan issues and that he thought the 10-11's came with the newer blower fan assembly, that he would look into it, and if I heard it again to come back. As soon as I left the dealership it started to rattle again so I pulled a U turn and drove right back in. Turns out that the new Motor sub-assy: 87103-04043, is put into the 2012's. They dropped one into my 2011 and so far I have silence.
genconex is offline
#35 Old 10-28-2011, 12:03 PM
Quoted: 0 Post(s)
The technician, Morgan, informed me that MOTOR SUB-ASSY: 87103-04043 has a bolt that attaches the fan to the motor instead of the former hardware which included a compression spring in the 05-11 Tacoma's. This should prevent the fan from loosening from the motor and rubbing on the plastic housing which creates the rattling noise on the low settings.
If I have time I will pull out this new assembly and see if I can see any changes from the original one that came with my truck.
genconex is offline
#36 Old 10-28-2011, 12:30 PM
Senior TN Member
RTFM's Avatar
Quoted: 4 Post(s)
I know my two fans aren't loose on the shaft. I tried to move both of them to see what would happen. Afraid of damaging the fan, so I stopped.
06 DC LB, 4x4, Speedway , TRD Sport w/ Tow, JBL 6CD w/ Grom to IPod, Roof Rack, Weathertech bug deflector & floormats, Access LE tonneau, Hood Struts, Scangauge, Clifford 10.5x alarm, Homelink Mirror, Ultra Grinder Wheels, Toyo Open Country AT tires
RTFM is offline
#37 Old 10-28-2011, 05:15 PM
Quoted: 0 Post(s)
RTFM, my original blower fan didn't feel loose to me when I pulled it out and adjusted the two magic ear soothing screws on the bottom of the motor housing - not soothing enough since the rattling came back after about two weeks. I am using the description Morgan pulled up on their system's Service Bulletin Description at Toyota and reverberated back to me as the issue with the Tacoma Blower fans from 05 - 09 and extended through 2011.
genconex is offline
#38 Old 10-28-2011, 06:10 PM
Quoted: 0 Post(s)
I found some time and dropped the new MOTOR SUB-ASSY: 87103-04043 that was installed. At first glance it looks very similar to the original MOTOR SUB-ASSY (I think it was 87103-04042). I don't want to pull it completely apart and verify that it has a bolt attaching the fan to the motor and lacks the compression spring as Morgan stated. For now I am going to take his word on it.
genconex is offline
#39 Old 11-01-2011, 04:07 PM
Quoted: 0 Post(s)
Getting yet another Fan assembly Installed.
I've had the same fan/blower issues. My 2009 tacoma wENT in on warranty and had the blower assembly replaced last year according to the TSB with assembly #87103-04041. Since then I've tried the balance screws and it usually only quiets the noise untill I hit my first bump and then it starts again. I went down to the dealership and made them order the new assembly 87103-04043 since my warranty up soon. Have you had any luck with the new assembly GENCONEX?
lawzy1 is offline
#40 Old 11-02-2011, 07:09 PM
Quoted: 0 Post(s)
Lawzy1 - So far I have had no issues with it. I have only had it a couple weeks now.
genconex is offline
#41 Old 11-30-2011, 08:17 AM
Quoted: 0 Post(s)
These fans SSSSUUUUUUUCCCCCCKKKKKKKKK!!!! Replaced it about 6 months ago now the new one is ticking. Toyota PLEASE fix the problem.
Always wanted a black Toyo since the seeing the final scene of "Back to the Future" for the first time... Nerd, I know.
hamletjsd is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > 2nd Generation (2005+)
User Tag List
Linear Mode Linear Mode
