IM getting some pretty nasty squealing from my front suspension what can it be? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > 2nd Generation (2005+)
2nd Generation (2005+) Discussion area for the 2nd generation of the Toyota Tacoma
Old 06-23-2007, 05:54 PM   #1 (permalink)
4.0 Smoking
TrdTacoma84's Avatar
View TrdTacoma84's Photo Gallery
Well i got my truck back from the body shop around a week ago now. And all of a sudden im starting to hear some pretty annoying squeals coming from my front end. What should i be looking at? Or should i take it back to the body shop... even though it had nothing to do with what they fixed....
Its annoying ill try to get some video....
http://www.cardomain.com/ride/2069203/1
2005 Pre Runner V6 access cab auto. Helo Maxx 6 17x9 Good Year Silent Armor 275/70/R17. Trd Exhaust, K/N 63 Series Intake w/AEM Filter.....
TrdTacoma84 is offline   Reply With Quote
Old 06-23-2007, 06:31 PM   #2 (permalink)
View andygriffith's Photo Gallery
Can you provide more information, like how often or what you are doing when you hear the squeal?
andygriffith is offline   Reply With Quote
Old 06-23-2007, 06:48 PM   #3 (permalink)
4.0 Smoking
slighty when i press the gas. I went over some rugged terrain and it does it pretty bad. Also when turning out of a drive way or parking spot. I also shoke the control arms and it squeaks as well.
Old 06-23-2007, 08:11 PM   #4 (permalink)
Mine is better than yours
iTrader Score: 6 reviews
View Marc M's Photo Gallery
Swaybar hitting the lower spring cup ???
Marc M
'06 Tacoma Dbl-cab, 4X4, V6, 6-spd, SR5 / TRD Off Road
'05 Corolla XRS 6-Spd
'00 Echo 5-Spd
'90 4Runner SR5 5-Spd - '86 Shortbed 4X4 5-Spd,SAS'd ASAP - '82 Supra 5-Spd
Take your automatic and "Stick" it........
Marc M is offline   Reply With Quote
Old 06-23-2007, 08:14 PM   #5 (permalink)
HANG UP AND DRIVE!!!
nomad's Avatar
View nomad's Photo Gallery
Squeal or squeak (as in with suspension movement)? How about spraying a little grease on your bushings?
nomad is offline   Reply With Quote
Old 06-23-2007, 09:11 PM   #6 (permalink)
4.0 Smoking
yeah its moslty coming from my right side. When a passanger gets out its squeaks. Ill try spraying all my bushing.
Old 06-23-2007, 09:11 PM   #7 (permalink)
4.0 Smoking
Marc M
I dont know i move grip the controller arm and shake the truck and i can hear it.
Old 06-23-2007, 09:38 PM   #8 (permalink)
I had a really bad squeak after an alignment. It ended up being what I mentioned. Try sliding a piece of heavy paper or card stock between the swaybar and cup.
Had to slide the swaybar bracket forward to clear it on one side.
Marc M
'00 Echo 5-Spd
Old 06-23-2007, 09:59 PM   #9 (permalink)
4.0 Smoking
Marc M
My truck also got algined after the accident too. Do you have any pics?
Old 06-23-2007, 10:28 PM   #10 (permalink)
1. Take your skid plates off, both of them
2. Crank down on all of the bolts on the bumper supports.
3. Either tighten or remove the bumper extensions on the left and right sides.
4. Put your skids back on and make sure they are tight.
Old 06-23-2007, 11:04 PM   #11 (permalink)
4.0 Smoking
I found out that the squeak is coming from the right side. I sprayed all the bolts and its still there. Should i take the truck back to the body shop that repaired it or should i visit the shop that installed the lift? It sounds like the contoller arm...
Old 06-23-2007, 11:56 PM   #12 (permalink)
Did you tighten all of those things I mentioned in my last post? I would do that before taking it back.
That is where I heard my noises, on the passenger side front. They are all gone now.
Old 06-26-2007, 01:04 PM   #13 (permalink)
4.0 Smoking
This is the noise i get....
Old 06-27-2007, 01:26 PM   #14 (permalink)
4.0 Smoking
So ive done everything that you guys mentioned above. The creaking and squeaking is worse.... Anyone know what else i could do. I took it to the shop that installed the lift and they just sprayed all the moving parts told me to bring it back if it continues making noise.
Old 06-27-2007, 01:55 PM   #15 (permalink)
Heart Art
Jesse1983's Avatar
View Jesse1983's Photo Gallery
well nice video at least, very descriptive. as for what that noise is,
3" Toytec, 285/70/17 BFG MT's, Moto Metal 951b,
OME Rear Shocks, TW DS, Grillcraft, hood struts, TC UCA's
black heads & tails, in-dash DVD, Sirius
Jesse1983 is offline   Reply With Quote
1997 Camry front suspension Bruced 3rd & 4th Generation (1992–1996 & 1997–2001) 6 06-14-2008 10:58 AM
Pop in front suspension hrhoward 1st Generation (1995.5–2004) 5 02-26-2007 03:20 PM
'04 Tacoma - squeaky front suspension ZIM 1st Generation (1995.5–2004) 0 06-27-2006 07:24 PM
Drift Setting help for GT3 I hate Toyota Corp :( Off Topic 3 11-10-2003 10:36 PM
