Cloud inside headlight?!? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > 2nd Generation (2005+)
2nd Generation (2005+) Discussion area for the 2nd generation of the Toyota Tacoma
Old 06-23-2007, 11:02 PM   #1 (permalink)
Tacosalad
View Goatkey's Photo Gallery
Hey guys...I just did the black headlight mod......I cleaned of the access glue and washed the truck....went for a cruise and such...went outside later and noticed a cloud in one of the lights......looks like moisture...I wonder if anyone else had this.....I'm wondering if I need more glue...or if the factory amount should work? maybe I should reheat at 300 degrees and try and squeeze together again???
what do you guys think?
Goatkey is offline   Reply With Quote
Old 06-23-2007, 11:05 PM   #2 (permalink)
need to find money tree
View amp2oo1's Photo Gallery
sounds like they didnt get sealed up when you put them back together
No more truck...
amp2oo1 is offline   Reply With Quote
Old 06-23-2007, 11:11 PM   #3 (permalink)
Banned
beastbluetaco's Avatar
iTrader Score: 25 reviews
View beastbluetaco's Photo Gallery
Ya man, you have to put them back in the oven to completely seal them up, otherwises you will get some moisture in them. You really don't need any extra glue, just use what is there.
beastbluetaco is offline   Reply With Quote
Old 06-23-2007, 11:15 PM   #4 (permalink)
Tacosalad
I guess the first one did...but the drivers side is the one with the cloud...I guess it will go away on its own but after any water gets in it will do the same thing...I think I will take it apart and heat it up again...see if that cures all that ailes me....I was scared shitless about messing this mod up ...it's pretty eash tho...and it looks good
Old 06-23-2007, 11:16 PM   #5 (permalink)
Pb
Surfing TN via iPhone
Pb's Avatar
iTrader Score: 15 reviews
View Pb's Photo Gallery
Do you have the vent plugs and the headlight bulb grommet installed properly?
Pb is offline   Reply With Quote
Old 06-23-2007, 11:17 PM   #6 (permalink)
Tacosalad
Oh and one more thing......when you guys sealed them back together....did they close completely...or was there a little bit of a gap left?????
Old 06-23-2007, 11:17 PM   #7 (permalink)
Banned
That could also be the problem, but most likely the gule seal
Old 06-23-2007, 11:20 PM   #8 (permalink)
Tacosalad
oh oh....that is the black and white caps that were on the back of the light??? which one is supposed to be at the top and which is supposed to be at the bottom??? installed properly???
Old 06-26-2007, 06:40 PM   #9 (permalink)
ToyotaNatoin
lilgerber's Avatar
View lilgerber's Photo Gallery
i had to re glue mne, and you a hair dryer to get rid of mine, also left out side looking towards sun, in 107 heat haha..
never had a problem since..
flowmaster40/billet grill/chrome handles,mirrors/volant intake/3"toytect lift./KING coils/Motometals951,285/70/17rims/sound system .Tc uca's/Gw fenders
http://www.cardomain.com/ride/3821302
lilgerber is offline   Reply With Quote
Old 06-26-2007, 06:47 PM   #10 (permalink)
Playoff bound, 8 long yrs
zmtnbik's Avatar
View zmtnbik's Photo Gallery
NO GAPS...that is probably your problem right there.
If you want a quick fix, invest $20 in a heat gun. Just heat up the glue and close the gap. You may have to use tape or something to close the gap once you heat up the glue though.....user painters tape so you don't scratch up your lenses.
Good luck
2006 4x4 Access, V6, 6spd, TRD Off-Road, tow pkg. Donahoe Co's, TC UCA's, Dakar leafs, 5125's in the back and u-bolt flip kit. TRD exhaust, CAI. URD MAF calibrator. 17x9's, 285/70/17 BFG MT KM2. Locker-mod, fog mod and console vault.
zmtnbik is offline   Reply With Quote
Old 06-26-2007, 07:55 PM   #11 (permalink)
Keepin' it simple
Grumpy_X's Avatar
View Grumpy_X's Photo Gallery
Your neighborhood Harbor Freight has 'em for $9.99. Cheapie w/o cool down feature but it gets the job done.
Here's the linky --> http://www.harborfreight.com/cpi/cta...emnumber=35776
Grumpy_X is offline   Reply With Quote
Old 06-26-2007, 10:16 PM   #12 (permalink)
Tacosalad
I took the light apart again and did a complete heat and seal using the oven....I hope it works...its calling for rain tommorow so we'll see
the problem I see already is that I should have scuffed the thing before I painted ..or even used a primer...and a finishing bomb because a couple pieces chipped...not huge or anything...but I notice if I look close...I won't be taking apart again..that is for sure
Old 06-27-2007, 12:10 AM   #13 (permalink)
View boydestruction's Photo Gallery
I had a problem with water in one of my headlights after the dealership forgot to replace one of my rubber boots. I ran a hairdryer in the housing for an hour and it seemed like everything was good, but a few hours later they had fogged-up again. I took the housing out and removed everything from it only to find out that the little sponges in the small white and black caps (on the back of the housing) still had water in them. Once I dried those out it was fine and I haven't had any problems since.
So, I guess my point is: check the small sponges.
Jesus Christ was dead and back again by 33. You better get crackin'.
boydestruction is offline   Reply With Quote
Old 06-27-2007, 10:26 AM   #14 (permalink)
mall crawler
MrGrimm's Avatar
View MrGrimm's Photo Gallery
clouds
MrGrimm is offline   Reply With Quote
Old 06-27-2007, 03:46 PM   #15 (permalink)
Pb
Pb's Avatar
To seal mine up tight I clamp the seams together with rubber footed clamps while the headlamp is still warm out of the oven.
Headlight Questions 06UTSTi 2nd Generation (2005+) 5 04-13-2007 12:25 AM
Water inside the door Alex187 3rd & 4th Generation (1992–1996 & 1997–2001) 6 10-22-2006 01:42 PM
[UPDATED w/ more photos!!] Gen 3 new cystral headlight housing arrived (w/ pics) bowen 3rd & 4th Generation (1992–1996 & 1997–2001) 62 10-09-2006 11:01 PM
Removing Entire Headlight Housing Fresco Bob Camry & Solara Lounge 1 11-08-2005 02:42 PM
Headlight removal mr.andrew Archived Corolla threads 5 09-10-2005 03:31 PM
