Recalibrating throttle - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > 2nd Generation (2005+)
2nd Generation (2005+) Discussion area for the 2nd generation of the Toyota Tacoma
Old 06-25-2007, 11:24 PM   #1 (permalink)
View boydestruction's Photo Gallery
Well, I was on the way home from watching Evan Almighty (good movie, btw) with my little brother tonight. We've been doing a lot of work on his Dodge Charger lately, and he mentioned something about recalibrating his gas pedal. I've never heard of that before, but it seemed to make sense since a lot of new cars (and our Tacos, I belive) have electronic controlled throttle systems.
This is what he did: Turned the key to "on" positions and let everything normalize (lights shut-off, etc). He then pressed the gas pedal in a smooth motion all the way to full throttle, then let-off in a smooth motion all the way to resting. He waited five seconds and did it again. He said his throttle response went back to almost like new.
I've noticed a difference between how my throttle (56k miles) and my buddy's (12k miles) is. His is definitely more responsive, but he hasn't done any modifications to his truck. I've done quite a few to include "deckplate mod", secondary air filter removal, and a dual conversion on the exhaust. On the low-end, my throttle response is noticeable more sluggish than his, but at peak RPMs mine is much better.
Anyhow, I was sceptical about this 'calibration', so I pulled the truck over and tried it. Turned key to on, waited for lights to stabilize, smooth accel, smooth decel, waited 5 seconds, repeated. I started the truck again and it seemed to have made a difference in my throttle response.
Now, the reason I'm posting is because I want to know if anyone else has tried it; if this 'calibration' would even actually work on our truck; or am I getting the "K&N I feel more horsepower in the seat of my pants" effect? I swear it felt to me like the throttle responded better, so now I'm curious if there's some truth to it.
Jesus Christ was dead and back again by 33. You better get crackin'.
boydestruction is offline   Reply With Quote
Old 06-25-2007, 11:55 PM   #2 (permalink)
View ninja727's Photo Gallery
I used to do that on my Dodge Ram, and it definitely helped calibrate the throttle, but not sure if it will work with toyotas..........I'll give it a shot tomorrow
2006 Tacoma Double Cab 4x4 TRD Sport
ninja727 is offline   Reply With Quote
Old 06-26-2007, 12:01 AM   #3 (permalink)
THIS SPACE FOR RENT
humanoid's Avatar
Gameroom cash: $1003264
View humanoid's Photo Gallery
I'm not understanding how that would calibrate the throttle. Maybe someone can skool an oldtimer on this technique.
This is my sig.
humanoid is offline   Reply With Quote
Old 06-26-2007, 10:13 PM   #4 (permalink)
No one else has tried this or can tell me if I'm full of shit or not?
Old 06-26-2007, 11:07 PM   #5 (permalink)
A.K.A. Ty
TacoMSU's Avatar
View TacoMSU's Photo Gallery
I did it earlier, but I was carrying a few cans of gas so I couldn't get on it. I'll have a nice full-throttle run tomorrow to check it out.
TacoMSU is offline   Reply With Quote
Old 06-26-2007, 11:28 PM   #6 (permalink)
what rock? oops...
06RadiantTacoma's Avatar
View 06RadiantTacoma's Photo Gallery
i dont understand how that would "calibrate" anything plus our trucks are drive by wire correct?
06RadiantTacoma is offline   Reply With Quote
Old 06-26-2007, 11:38 PM   #7 (permalink)
A.K.A. Ty
TacoMSU's Avatar
I think the idea is that the drive-by-wire system "learns" your driving habits much like the transmission. You'd be "calibrating" or "resetting" your throttle back to stock, therefore giving more throttle response. I, personally, don't think it will do anything, but it won't hurt to try it.
Old 06-26-2007, 11:40 PM   #8 (permalink)
what rock? oops...
true and there is really no way to test if this does anything or not, couldnt you just unplug the battery real quick and it would reset to stock?
Old 06-26-2007, 11:43 PM   #9 (permalink)
A.K.A. Ty
TacoMSU's Avatar
The only way to tell is if you have an accelerometer and you could measure your 0-60 times before and after.
The only real way anyone will be able to tell is the "seat-of-the-pants dyno" and that isn't very accurate.
Supposedly, you can reset the truck's ECU by disconnecting the battery for at least 10 minutes or by pulling certain fuses for several minutes.
Old 06-26-2007, 11:45 PM   #10 (permalink)
View ob3lix's Photo Gallery
I think you'd have to leave it off for about half an hour before the system resets. I recall reading that here before.
'06 V6 4x4 AT SR5
Grillcraft BG, Pioneer Avic Z1, WeatherTechs, Viper 5900SST, De-badged, Clr HL's, Hood struts, SGII.
ob3lix is offline   Reply With Quote
Old 06-26-2007, 11:50 PM   #11 (permalink)
what rock? oops...
well luckily i just happen to have an accelerometer in my truck but my truck is a 6 speed so to get 0-60 times is nearly impossible but ill try it and tell you what the accelerometer says
Old 06-26-2007, 11:55 PM   #12 (permalink)
I've reset the computer before by pulling fuses when I did the deckplate mod and pulled the secondary air filter. I noticed a difference in the throttle then, too. I'm just curious if this 'retrain' thing works or if I'm imagining things.
Old 06-26-2007, 11:58 PM   #13 (permalink)
what rock? oops...
i think i have an excuse to go to the drag strip this weekend i already have gone and every run i was within a tenth of a second (which is pretty consistent for driving a standard) so ill "reset" or "recalibrate" AT the drag strip and see if i get any different numbers
Old 06-26-2007, 11:59 PM   #14 (permalink)
A.K.A. Ty
TacoMSU's Avatar
I don't think this particular "calibration" will do anything.
I do, however, think that pulling fuses or the batter will reset the transmission shift points and give the feeling of more throttle resoponse.
Old 06-27-2007, 03:51 PM   #15 (permalink)
Pb
Surfing TN via iPhone
Pb's Avatar
iTrader Score: 15 reviews
View Pb's Photo Gallery
Gadget from URD told me that disconnecting the battery doesn't reset the computer or anything like that on our trucks.
It only works on '99 and older models.
Pb is offline   Reply With Quote
Throttle stop setting? Mystos 89-95 Toyota Pickup/Hilux 1 10-06-2005 12:04 AM
Throttle Body Cleaning nobrainer Camry & Solara Lounge 13 06-29-2005 03:02 PM
*HELP* RPM inquiry toyotoyota Camry & Solara Lounge 6 06-22-2005 12:43 PM
Hesitates at half throttle.....Please Help 89TCGTS Archived Corolla threads 7 02-16-2005 08:16 AM
Answer to engine rock/bounce on throttle lift brink Hardcore Tech and Competition 5 10-23-2003 10:34 PM
