How to turn off the idiot light? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > 2nd Generation (2005+)
2nd Generation (2005+) Discussion area for the 2nd generation of the Toyota Tacoma
Old 06-26-2007, 05:34 PM   #1 (permalink)
View DS07Taco's Photo Gallery
Hello, all...
The amber "maint reqd" (maintenance required) light came on once I rolled over 5000 miles. I did the oil/filter change myself at about 4750 miles, so that about covers it. How do I turn that idiot light off? Anyone know???
Thanks a bunch...
Daryl
'07 bone stock, non-TRD silver Taco
DS07Taco is offline   Reply With Quote
Old 06-26-2007, 05:36 PM   #2 (permalink)
need to find money tree
View amp2oo1's Photo Gallery
http://www.toyotanation.com/forum/search.php
search and you will find plenty of threads about it. It's been discussed many time
No more truck...
amp2oo1 is offline   Reply With Quote
Old 06-26-2007, 05:37 PM   #3 (permalink)
Taking Donations.
njmueller363's Avatar
View njmueller363's Photo Gallery
Turn the key to the on position without actually starting the engine.
Then press and hold the mileage button in the gauge cluster untill the numbers clear (about 20 seconds)
Then keep the button pressed and crank the engine.....
lets go of the button....Thats it!!
What exactly qualifies your truck as a rig?
5100s with OME 885s, Pro Comp 7089 w/ 285/70/17 Pro Comp Xtreme Mud Terrains
njmueller363 is offline   Reply With Quote
Old 06-26-2007, 05:48 PM   #4 (permalink)
bummer, tried it 3x, didn't work. Tried it pushing the button in when in odometer mode, Trip A mode and in regular (how many miles are on the truck) mode. Nothing. It's probably me; I'm admittedly retarded when it comes to this stuff, but it pisses me off to have to go by the dealership and spend an hour while they dick around just to shut the darn light off.
Hmmm, what to do....
DS
Old 06-26-2007, 05:49 PM   #5 (permalink)
DS
maybe this will help...
http://www.toyotanation.com/forum/t193287.html
even though its going to say basically the same thing
No more truck...
Old 06-26-2007, 05:51 PM   #6 (permalink)
Taking Donations.
whoops...you have to have it pressed in before you put in the on position....
Old 06-26-2007, 05:58 PM   #7 (permalink)
View Toyogook's Photo Gallery
This is how I do it:
Turn the truck off.
In odometer mode, I press and hold the button
Turn the key PAST acc to the ON position
Keep holding the odometer button
You should see a series of dashes in the odometer screen doing a sort of countdown. When that's done, let go of the button and start the truck.
If you don't see the dashes, you aren't doing it right - operator error. The steps are also in the owner's manual.
[edit]nevermind, you figgered it out.[/edit]
06 Black Sand Pearl Reg Cab - willing to trade my nonscooped hood for your scooped hood. Pm's welcome.
Toyogook is offline   Reply With Quote
Old 06-26-2007, 06:22 PM   #8 (permalink)
rydr1's Avatar
View rydr1's Photo Gallery
READ THE OWNERS MANUAL.
rydr1 is offline   Reply With Quote
Old 06-26-2007, 06:28 PM   #9 (permalink)
Taco-ma-ma
View Remarkable's Photo Gallery
You have to change the nut behind the wheel........
Remarkable is offline   Reply With Quote
Old 06-26-2007, 07:06 PM   #10 (permalink)
Stupid is stupid does
lotust's Avatar
View lotust's Photo Gallery
or use the god damn search BUTTON
295/65/18 Goodyear Duratracs:2.5" lift in the front with 1" rear Block
JBA single exhaust:HID's W/Led's inside:Nfabs
E&G grill insert:ARE Z topper:Overhead DVD for my son:Front DVD for me
lotust is offline   Reply With Quote
Old 06-26-2007, 07:30 PM   #11 (permalink)
rydr1's Avatar
yeah but sometimes they rather complain about how the dealer needs to turn it off when the answer is already given to them.
Old 06-26-2007, 07:53 PM   #12 (permalink)
Banned
beastbluetaco's Avatar
iTrader Score: 25 reviews
View beastbluetaco's Photo Gallery
Put your key in the ignition, leave it in the off position. Hold in the reset Tac button, turn your key one spot to the accessory position. You should see you tacometer blink, turn to - - - - - and then to zero. Once it does that, let go of the button. Start up your truck, and the maint req light should go away.
beastbluetaco is offline   Reply With Quote
Old 06-26-2007, 08:10 PM   #13 (permalink)
Troyslegacy
troyslegacy's Avatar
View troyslegacy's Photo Gallery
The owners manual explains it quite clearly....
2006 Tacoma DC 4x4 TRD-Off Road 6spd "Stock the way God made it"http://www.cardomain.com/ride/2545827
troyslegacy is offline   Reply With Quote
Old 06-26-2007, 08:26 PM   #14 (permalink)
07 Tacoma 4x4 Off Road
denvertaco07's Avatar
View denvertaco07's Photo Gallery
denvertaco07 is offline   Reply With Quote
Old 06-26-2007, 08:32 PM   #15 (permalink)
bardb's Avatar
View bardb's Photo Gallery
Originally Posted by denvertaco07
x2 JFC!
bardb is offline   Reply With Quote
HOW TO: 2005-06 Fog Light Modification SWTRDSPORT 2nd Generation (2005+) 110 10-24-2011 07:40 AM
Tire pressure light won't turn off hlsuji 1st Generation (2001–2007) 7 11-06-2007 12:04 PM
Idiot Light Boatrocker 1st Generation (1995.5–2004) 5 12-15-2006 08:09 PM
Real HID's not necessarily "better" fredster34 5th & 6th Generation (2002-2006 & 2007-2011) 26 12-11-2006 06:06 PM
signal turn light bulb how to change tchoke 3rd & 4th Generation (1992–1996 & 1997–2001) 4 12-05-2006 06:12 PM
