Ok, I did a search and didnt find much of anything. Just curious why the 2007 Tacoma is rated at 236 hp @ 5200 rpm 266 lb.-ft. @ 4000 rpm and the FJ is rated at 239 hp @ 5200 rpm 278 lb.-ft. @ 3700 rpm
While the hp might only have a 3 hp difference, the Tq is off by 12 ft lbs at a lower rpm! Last I checked the motors were the exact same. Is it cause of a different exhaust layout possibly?
I know both these vehicles are based off the new SAE rating (which brought down the original tacoma numbers from 245 to 236).....so Im just kind of curious if anyone has a theory or actually knows whats up?
I'll also add that the 07 4-runner is rated the exact same as the tacoma with the 4.0L
I assume that's the 4-runner with the 4.0l and not the v8
2006 4x4 Access, V6, 6spd, TRD Off-Road, tow pkg. Donahoe Co's, TC UCA's, Dakar leafs, 5125's in the back and u-bolt flip kit. TRD exhaust, CAI. URD MAF calibrator. 17x9's, 285/70/17 BFG MT KM2. Locker-mod, fog mod and console vault.
I was reading on Wikipedia for the GR Motor that if you use 91 octane you can get 239hp and 278lb/ft torque. I don't know how true this is
The 1GR-FE is the 4.0L version. Bore is 94 mm and stroke is 95 mm. Output is 236 hp (183 kW) at 5200 rpm with 266 lb-ft (382 Nm) of torque at 4000 rpm on 87 octane, and 239 hp at 5200 rpm with 278 lb-ft at 3700 rpm on 91 octane. This engine features Toyota's single VVT-i, variable valve timing, system and a compression ratio of 10.0:1. Inside, the 1GR uses a taper-squish combustion chamber design with matching pistons to improve anti-knocking and engine performance, while also improving intake and fuel efficiency. Toyota adopted a siamese-type intake port, which reduces the surface area of the port walls and prevents fuel from adhering to such walls. This engine has special cast-iron cylinder liners cast into the block, which are a spiny type to improve adhesion between the liner and cylinder block. With these special thin liners it is impossible to bore the block. In the event of cylinder wall damage (scoring, deep protrusions, etc), the entire cylinder block must be replaced. For increased block rigidity, the 1GR also receives a high temperature plastic insulator/protector, which fills the empty space between the outer portion of the cylinders and block material common to open deck engines. For increased cooling efficiency, the 1GR employs water passages between the bores of the engine. There are such 2 passages for each bank for a total of 4. This reduces cylinder hot-spotting and keeps combustion chamber temperatures more uniform.
__________________ 2007 Speedway Blue Tacoma X-Runner 1GR-FE - URD Exhaust, URD Y-Pipe, TRD CAI, TRD Short Shifter, SS swaybar kit, TTC Traction bars, TL Projector retrofit, and more 2010 Magnetic Gray Metallic Camry SE V6 2GR-FE - TRD Dual Catback Exhaust, JL Stealthbox, Alpine PDX-M6, UR Strut Bar
......VERY interesting. Wonder why toyota would publish the FJ numbers using Premium unleaded...and the 4-runner and tacoma with regular unleaded?
I have TOTALLY felt a difference in my truck with 92 vs 87 or 89. I know the timing was being retarded, cause I few times I actually heard it knock using 87. AND, I would always notice the truck would run strong one minute, then run kind a "restricted" the next. Felt like it was being held back.
NOW it just runs...and runs really well.
yes, squish is a technical term, it's used to describe the area of the combustion chamber where the piston meets the head (nearly) creating a shockwave into the rest of the chamber to stir the mixture.
Don't forget about the 2007 Tundra....it also comes in a 4.0L configuration.
It has the same output #'s:
236 Horsepower @ 5200 rpm
266 Torque @ 4000 rpm (lb.-ft.)
Damn, Toyota is using this engine in a lot of vehicles: Tacoma, FJ, 4-Runner, and Tundra.
__________________ The greatest security a person can have comes from within himself, not from the outside. Nothing anyone can do for you can begin to match what you can do for yourself.
-Samuel Goldwyn
