How to wire my driving lights? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > 2nd Generation (2005+)
2nd Generation (2005+) Discussion area for the 2nd generation of the Toyota Tacoma
Old 06-29-2007, 09:42 AM   #1 (permalink)
Southern by God's Grace
farmer_74's Avatar
View farmer_74's Photo Gallery
O.K. you electrical guru's, I need some help.
I am installing Hella 500's and would like to wire them so that I can either turn them on by themselves and also have it so that I can control them with the headlights( ie. have them turn on with the brights and off with the dims)
Would an on-off-on switch from http://www.4x4mods.com/ be what I need?
Also, can someone help me with instructions for wiring them this way. You will have to dumb it down enough for me to follow.
Thanks,
Kevin
2007 Dbl cab 4x4, Silver,5 speed auto,
3" Toytec lift w/ 885's, AAL's, OME Nitros, Total Chaos UCA's
16x8 Black ARE Fuels, 285/75/16 Nitto Terra Grapplers
Westin oval tube steps (Black), Hella 500's, Grillcraft MX
farmer_74 is offline   Reply With Quote
Old 06-29-2007, 09:44 AM   #2 (permalink)
View Phi Kai's Photo Gallery
I believe you would just wire them independtly with an on-off switch. All you need to do is run the power to wherever you plan on getting power from and run the ground to the switch and then to the ground. No need for an on-off-on because you just need to be able to turn them on whenver you want
2005 Toyota Tacoma TRD Sport 4x4:
Custom Painted TRD Off-Road Wheels, Undercover Bed Cover, Flowmaster Delta 40 Muffler,
Pioneer Avic D1, MA Audio 10" Sub and Amp
Phi Kai is offline   Reply With Quote
Old 06-29-2007, 11:44 AM   #3 (permalink)
HANG UP AND DRIVE!!!
nomad's Avatar
View nomad's Photo Gallery
Just out of curiosity, where are you going to mount them? I don't see a light bar in your sig. I've been thinking of some way to mount a pair, but I don't want the traditional light bar hanging off the front of the truck. I wish the Taco was like my old Passport. It had a steel brace directly under the plastic skin of the bumper.
nomad is offline   Reply With Quote
Old 06-29-2007, 12:28 PM   #4 (permalink)
look into the N-fab or I believe it's the all-pro one...both come out of the lower grill so its less noticable...might be what your looking for
Old 06-29-2007, 12:42 PM   #5 (permalink)
Banned
beastbluetaco's Avatar
iTrader Score: 25 reviews
View beastbluetaco's Photo Gallery
If you have a grillcraft or billet grill, you can mount some lights behind the grill. It won't work if you have a stock grill.
beastbluetaco is offline   Reply With Quote
Old 06-29-2007, 12:50 PM   #6 (permalink)
farmer_74's Avatar
I have them mounted behind my grill. Here are some pics from my phone:
Old 06-29-2007, 12:54 PM   #7 (permalink)
nomad's Avatar
I wonder how much light output the Grill Craft cuts down on? I thought about doing the same thing, but am concerned that the light output wouldn't be what it could. Also, does it do anything to the pattern of the light?
Edit: How much spacing do you have between the grill and the lenses (or is it basically touching)?
Old 06-29-2007, 03:38 PM   #8 (permalink)
View Doc Slaughter's Photo Gallery
Farmer,
Can you show us how you mounted those lights?? Its WAY COOL
Doc Slaughter is offline   Reply With Quote
Old 06-29-2007, 04:11 PM   #9 (permalink)
A.K.A. Ty
TacoMSU's Avatar
View TacoMSU's Photo Gallery
Here you go. I think you use a DPDT switch from 4x4mods.com. Or is it a DPST?
I got this from another member when I asked the same exact question.
A little search goes a long way.
You need to have a 5 pin relay and the other can be a regular 4 pin.
The relay on the left is your highbeam control and the one on the right is your switch control.
TacoMSU is offline   Reply With Quote
Old 06-29-2007, 04:48 PM   #10 (permalink)
A.K.A. Ty
TacoMSU's Avatar
I searched and found the link for you.
http://www.toyotanation.com/forum/t194545.html
Old 06-29-2007, 06:37 PM   #11 (permalink)
farmer_74's Avatar
Thanks TacoMSU,
I did search and I did see this diagram. My understanding of this (which is limited) is that it is for using the fog light switch, which doesn't allow you to turn them off if the high beams are on. I would like to be able to have them OFF (all of the time) or ON (all of the time) or ON (only with the brights)
Kevin
Old 06-29-2007, 07:02 PM   #12 (permalink)
farmer_74's Avatar
Nomad and Doc Slaughter,
I mounted the lights to the bottom of the grill frame. It's a very easy install. You only have to drill one hole for each light. Only the top of the light touches the grill.
I'm not sure about the light output since I don't have them wired yet.
Kevin
Old 06-29-2007, 07:06 PM   #13 (permalink)
Banned
Farmer, whose taco is sitting next to yours in those pics
Old 06-29-2007, 07:18 PM   #14 (permalink)
farmer_74's Avatar
That's my Stepdads truck. I need to post some pics of it. It's a sharp truck.
Kevin
Old 06-29-2007, 07:19 PM   #15 (permalink)
Banned
Kevin
Ya it looks pretty sweet, but not as cool as yours
driving lights bigdaddymike745 Camry & Solara Lounge 12 07-29-2005 11:44 PM
Making other lights (or underglow) blink when lockin/openin doors with the remote aleks77 Camry & Solara Lounge 9 09-12-2004 03:41 AM
projector ish driving lights Nick Camry & Solara Lounge 14 08-08-2003 06:54 PM
time for boro driving lights Nick Camry & Solara Lounge 2 08-07-2003 03:13 PM
