Oil capacity with longer filter - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > 2nd Generation (2005+)
2nd Generation (2005+) Discussion area for the 2nd generation of the Toyota Tacoma
Old 06-30-2007, 09:29 AM   #1 (permalink)
View tsl90's Photo Gallery
I've been using the Wix 51516. It fit's our truck but is longer/taller. I had written down the correct capacity increase for the V6 with that filter but can't find it.
I'm coming up empty with a search too. Anyone know the correct capacity with this filter?
Thanks
TL
06 Silver Streak Mica V6 4x4 Access Cab TRD Off Road
tsl90 is offline   Reply With Quote
Old 06-30-2007, 10:58 AM   #2 (permalink)
Theatre Nerd Person...yea
Sony's Avatar
View Sony's Photo Gallery
It's ether 5.5 or 6 quarts, I can't remember which though. I put 6 quarts in mine this last oil change (I am using the Mobil M1-209) but I think I may have overfilled it...it so freakin hard to read our dipsticks...
2006 Toyota Tacoma DCab Long Bed SR5 V6 5spd Auto 4x4
Tow Package, 6 CD Changer, Rear Limited Slip Differential, 16" Alloy Wheels
Silverstar H4 Headlamps and
Silverstar 9005 Foglamps, Bed Storage Utility Lock Mod, Redline Tuning Gas Hood Struts, Roll-N-Lock M-Series Retractable Tonneau Cover
Sony is offline   Reply With Quote
Old 06-30-2007, 11:19 AM   #3 (permalink)
MD-80 PILOT
flyman767's Avatar
View flyman767's Photo Gallery
5.5 qts is factory(prerunner/4WD)
The original factory filter is larger than the replacement Toyota OEM. I remember a previous post that the WIX filter is approx .17 to .30 larger than the OEM, not sure if this was reference to the original factory installed filter or the replacement OEM.
As far as reading the dipstick what I found works for me. Pull the dipstick all the way out and wipe it clean. Stick it back in about 6 inches so most of it hangs out. Wait 5-10 minutes for all the oil in the tube to drain back down. Then push the dipstick all the way in with one thrust, pull it all the way out and read it. One side or the other usually will have a solid line of oil that is easy to read. The problem with the long tube is that oil seems to seep up into it and won't easily drain back down with the stick inserted. If you repeatedly pull and replace the dipstick it makes it worse because each time you pull it out you drag more oil back up into the tube.
2007 TRD OFF-ROAD, Auto, VSC, Truxedo LoPro Soft Cover, Stainless Factory Tube Steps(Challenger's), EGR In Channel Window Shades, Black headlight Mod, EGR AERO Bug Guard, Amsoil series 2000 synthetic 0W-30
flyman767 is offline   Reply With Quote
Old 06-30-2007, 11:20 AM   #4 (permalink)
View trx450always's Photo Gallery
5.5 quarts will fill my truck to the full line. I can not see the bigger filter holding more than .2 quarts more than the other smaller filters. try 5.5 and go from there.
trx450always is offline   Reply With Quote
Old 06-30-2007, 11:35 AM   #5 (permalink)
Thanks for the help. I may just have to work until I get it right. I know Boone or someone once posted what seemed like an accurate capacity when using this filter. I think it was in the thread about oil that pointed me to the 51516 origially but I can't find that thread again.
TL
Old 06-30-2007, 12:28 PM   #6 (permalink)
i call it the octagon
chilidogrc's Avatar
View chilidogrc's Photo Gallery
i just scored my dipstick with hash marks. my 22re's dipstick was like that, and it was easy to read.
the SPNKr
chilidogrc is offline   Reply With Quote
Old 06-30-2007, 06:42 PM   #7 (permalink)
Came to just about 5.5qt. I might be a hair shy of the totally full line.
TL
WTF! 2007 Camry SE Only Giving Me 263.7 mi WITH Full Tank! LunarMist 5th & 6th Generation (2002-2006 & 2007-2011) 262 01-15-2011 01:17 PM
Oil Filter Drain Plug timpearson26 2nd Generation (2005+) 94 08-08-2007 01:43 PM
Longevity of Synthetic oils? Blackhawk3D 3rd & 4th Generation (1992–1996 & 1997–2001) 20 11-24-2006 11:59 PM
30,000miles on single oil change(how to help my car?) Part 2 Rob-D Camry & Solara Lounge 6 10-14-2006 12:26 AM
Sure was fun changing my oil today... Infinitrium Archived Corolla threads 18 10-12-2006 08:38 PM
