toobluetacoma06 gave me this write up for an inverter mod.
It's a really easy mod actually:
1) Get a power converter
2)Remove the plate containing the plugs and the switch from the converter.
3) Next, remove the plugs and switch from the plate. They will probably just pop out.
IMPORTANT!!: be sure you mark which wires go where before you start cutting them.
4) Then, find a location to mount the plugs and the switch and cut the proper holes (I used the plate that the plugs came from as a template to cut the holes) See pictures on my cardomain.
5) Mount the plugs and switch with loads of hot glue so that they wont move.
6) Now extend all the wires that you cut to remove the plugs and switch and run them to the new plug and switch location.
7) Attach the wires to the PROPER terminals. I soldered wires to the terminals on the plugs and switch. I then connected those wires with quick connects to the wires from the converter to make things easier.
8) Next, use like 12AWG or 10AWG (depending on how many watts your converter is) wire for + and - leads from the converter. I grounded the converter to one of the seat bolts.
9) In my case, I had to install a "master" or second switch in-line with the + lead from the converter. I did this because when I ran the power straight to the battery from the converter, even w/ the converter turned off, one of the LEDs was still glowing. I didn't want that to run my battery down over time so I just installed a master swtich in the + lead from the converter. I keep the master switch off and the converter switch on so I only have to flip one switch.
10) Just incase, add an in-line fuse in the + lead right after the battery connection. Even though most converters have fuses, this will add a little safety. You can use whatever amp fuse your converter already has in it.
