Originally Posted by 07RedTaco
Hey guys, I just picked up my '07 Tacoma the other day. I'm a bit of a Do-It-Yourselfer, as I've been building cars my entire life. I want to hook up a sub and amp into the system, and I was wondering if anyone has attempted to pull one of these dashes apart yet. Any sort of advice would be stupendous, as I do not want to break this thing. Thanks guys, it's appreciated.
-Cody
Take a look at the online FSM at it's new (temporary) home
http://www.*******.com/fsm/05+/index.html
Here is the instrument panel removal section
http://www.*******.com/fsm/05+/data/...06ta/06000.pdf
I recently did this, it took me 70 minutes for disassembly and a bit more for reassembly. I was running a new power wire to my HU, seriously the stock one is 20 gauge!
There are a lot of parts, but it's very simple for the most part. You just need an 8, 10 and 12 mm socket, and a tiny screwdriver or something for prying.
Two tricks:
To get the center console carpet up, stick a safety pin in it and pull up.
To remove the hood release latch, pry the heck out of the little tab, then the whole thing slides toward the front of the truck.
Also, it would help if you have an assistant when you finally remove the big dash piece at the end. It's a little tricky maneuvering it around the steering column, meanwhile it's heavy at the other end because of the passenger air bag unit. But it's doable by yourself; I did it.
Have fun!
