Amp Mounting Question.. - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > 2nd Generation (2005+)
2nd Generation (2005+) Discussion area for the 2nd generation of the Toyota Tacoma
Old 07-03-2007, 01:27 PM   #1 (permalink)
In The REAL Norcal...
View vendeta2k's Photo Gallery
Did a search but didn't find a good answer
What is the best way to mount my amplifiers under my seats? I'm getting ready to put my Rockford 200X2 and Power 500A2 under my seats....what type of screws should I use? Any guess's on the lenght...I'd hate to go to long and find something under the truck!
Thanks
Vendeta2k
vendeta2k is offline   Reply With Quote
Old 07-03-2007, 02:20 PM   #2 (permalink)
lover of teh boobies
johnecon2001's Avatar
Gameroom cash: $463130
View johnecon2001's Photo Gallery
FInd some simple sheet metal screws, about an inchif your paranoid.
Also, its not like its hard to crawl under the truck and look to see if there might be anything in the way.
johnecon2001 is offline   Reply With Quote
Old 07-03-2007, 02:28 PM   #3 (permalink)
View strubby's Photo Gallery
Yeah, just us a zinc self-tapper. You should shoot right through.
strubby is offline   Reply With Quote
Old 07-03-2007, 03:11 PM   #4 (permalink)
Banned
beastbluetaco's Avatar
iTrader Score: 25 reviews
View beastbluetaco's Photo Gallery
Not trying to steal the thread, but what is the best way to mount an amp on an mdf sub box?
beastbluetaco is offline   Reply With Quote
Old 07-03-2007, 03:16 PM   #5 (permalink)
Either drywall screws or use T-nuts.
Drill a hole and put the T-nut on the inside of the box. then you use a bolt through the hole to the T-nut and screw it tight. The nut has little sharp feet that dig into the box itself and grip it.
Old 07-05-2007, 01:55 AM   #6 (permalink)
cam2Xrunner's Avatar
If you want to do it the best way. Get 1/2" MDF. Bolt that down to the floor of the truck using rubber lined washers with bolts and nuts. Silcone on both sides to prevent rust or water from entering.
Then use T nuts on the bottom of the MDF and bolt the amp to the MDF.
You will need to go with less taller amps in order to clear the seat though so keep that in mind when picking out an amp if you go this route.
Question About Speakers And Amp umeshr85 Audio, Video, and Security - Tech 0 01-09-2007 07:02 PM
installing 4chan amp, hu 12v wiring question p2adan 1st Generation (1995-1999) 1 12-07-2006 08:45 PM
Amp question (yes I meant to put it here) Waterwookiee 2nd Generation (2005+) 8 03-21-2006 12:53 PM
Amp Question Vato Loco General Discussion 4 08-15-2002 11:57 AM
