oil analysis back...wear metals high - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > 2nd Generation (2005+)
2nd Generation (2005+) Discussion area for the 2nd generation of the Toyota Tacoma
Old 07-03-2007, 03:55 PM   #1 (permalink)
View mountain lion's Photo Gallery
Blackstone said it's normal, however this was the 4th change of oil in the truck...I've seen a few from other tacomas w/ ~11k that had a little less and some with hardly any metals.. guess I'll see how the next one goes.
mountain lion is offline   Reply With Quote
Old 07-03-2007, 04:02 PM   #2 (permalink)
rydr1's Avatar
View rydr1's Photo Gallery
just as some info what kind of oil are you using?
what is your oil service interval?
rydr1 is offline   Reply With Quote
Old 07-03-2007, 04:34 PM   #3 (permalink)
it's all in the picture above...
Old 07-03-2007, 04:39 PM   #4 (permalink)
TN's furry friend
iTrader Score: 17 reviews
View WhiteRabbit's Photo Gallery
how/where do you go for an oil analysis?
WhiteRabbit is offline   Reply With Quote
Old 07-03-2007, 05:51 PM   #5 (permalink)
Hobby or Mental Illness?
FRiZzO's Avatar
View FRiZzO's Photo Gallery
This is mine after I switched from Mobil 1 and OEM Filter. The new numbers are using Castrol Syntec 0W30 with K&N Filter HP-2009.
2005 Tacoma Access Cab, Super White, TRD Off Road package, Production Date:07/01/05 //// Viper 791xv Alarm/Remote Start / Panasonic CQ-C5310U // K&N Intake with AEM Dryfilter // TRD Exhaust // Toyota Hard Cover
FRiZzO is offline   Reply With Quote
Old 07-03-2007, 05:52 PM   #6 (permalink)
MD-80 PILOT
flyman767's Avatar
View flyman767's Photo Gallery
I just wonder since Mobil has changed it's base if that hasn't had something to do with the high metal content. I would have been curious to see if running Amsoil would have resulted in the same analysis. Where you using the Mobil filter as well?
2007 TRD OFF-ROAD, Auto, VSC, Truxedo LoPro Soft Cover, Stainless Factory Tube Steps(Challenger's), EGR In Channel Window Shades, Black headlight Mod, EGR AERO Bug Guard, Amsoil series 2000 synthetic 0W-30
flyman767 is offline   Reply With Quote
Old 07-03-2007, 06:02 PM   #7 (permalink)
FRiZzO's Avatar
Here is a nice post on Castrol 0W30 also known as GC ( German Castrol ) , available throughout the USA and at Canadian Tire / Walmart in Canada. Specific says made in germany on the back of the bottle.
http://theoildrop.server101.com/foru...e=0#Post711450
Old 07-03-2007, 06:09 PM   #8 (permalink)
Well...it still is a relatively new engine...this oil was used from 6k to 10.4k miles. However, I changed the factory oil @ 125mi, changed again at 1200 mi w/ m1, then at 6k again w/ m1. Been using a mobil m-102 filter since the 1200 mi change.
I saw a couple of Boone's uao's and his report at 11k mi was super clean. Might just have to do with how hard I drove it the first 6k miles...I babied until around then.
I went to german castrol this change w/ m-102...just have to check it out then. like they said I'm sure its nothing to worry about, this difference between mine and others is odd though.
Old 07-03-2007, 06:44 PM   #9 (permalink)
Stupid is stupid does
lotust's Avatar
View lotust's Photo Gallery
does anyone have anything better to do than test your freeking oil?
295/65/18 Goodyear Duratracs:2.5" lift in the front with 1" rear Block
JBA single exhaust:HID's W/Led's inside:Nfabs
E&G grill insert:ARE Z topper:Overhead DVD for my son:Front DVD for me
lotust is offline   Reply With Quote
Old 07-03-2007, 06:47 PM   #10 (permalink)
FRiZzO's Avatar
The main thing is, you are analyzing your oil! Do you have a fumoto valve yet? Having the fumoto valve will allow you to take enough oil out for another sample without having to do a full oil change.
Old 07-03-2007, 06:50 PM   #11 (permalink)
View andygriffith's Photo Gallery
I wonder if you changed to synthetic too soon and didn't allow the engine to break in with the factory oil.
andygriffith is offline   Reply With Quote
Old 07-03-2007, 07:05 PM   #12 (permalink)
Posible i guess..might just wearing slower rather than all it once...the oil i took out at 125mi was loaded with visible metal shavings, no thanks. mobil says on their site its perfectly fine to go straight to synth as well. ill email blackstone and see if they have avgs for this engine.
Old 07-03-2007, 07:49 PM   #13 (permalink)
Humble Servant
msibille's Avatar
View msibille's Photo Gallery
The text in their comments are common -for 1st or 2nd oil change.
I'd be a little concerned, though not freaking out yet, about two things -
a) you've flushed with several previous oil changes, and had a 6k run prior to this oil fill. You'll have break-in for some time, but still, those numbers seem high enough at this point to make me wonder -especially when you note the metal shavings (not unheard of, but not really common from a modern factory engine -not a rebuild).
b) the silicon numbers are high. That can be from a lot of things (and in the first 5k oil change, easily from sand casting residue), but it's often an indication of filtration not up to par -often the air filter. (Are you using a K&N or some other non-OEM filtration?)
My UOA at 15084odo (4364 on dino Castrol w/ Purolator filter):
Al 3
Cr 1
Fe 9
Cu 3
Pb 1
Tin Moly, Nickel, Mang, Silver, Ti, Potassium, Boron all 0
Silicon 13
Calcium 2122
Magnesium 9
Phos 804
Zinc 996
By contrast, my wife's 2006 Honda Ody at 1st oil change (4917mi)
Al 14
Cr 1
Fe 22
Cu 82
Pb 6
Moly 390
Mang 2
Pot 9
Bor 149
Si 118
Sodium16
Ca 1970
Magnesium 14
Phosphorus 728
Zinc 902
Barium 6
The msg with the Ody's report was similar to yours.
I'm curious if they realize that this is your 4th change, and that this oil went in at 6k, out at 11k.
msibille is offline   Reply With Quote
Old 07-03-2007, 07:56 PM   #14 (permalink)
Humble Servant
msibille's Avatar
The column to the far right of your report holds their avg data for that engine -according to their comments, this is for 4600 mi -though it's not clear, I believe that's 4600 mi of oil use after an engine is well broken in. (Their numbers look low for a first oil change though.)
Old 07-03-2007, 08:33 PM   #15 (permalink)
Yep using the URD intake for most of this oil's life..I added a drycharger wrap on it a few weeks ago, so if silicon goes down next change I wont know if it was residue/sealer or if the intake was sucking in a lot of dirt... I'm not sure if the drycharger adds much protection from dust. Just have to see I suppose. The amsoil filter is a solid filter regardless. I emailed blackstone letting them know it was the 4th change, etc....i shoulda added that to the comments when I sent it in.
otoh, i saw on oil drop someone had #s that were similar on an 05 taco w/ 12k miles... their Fe, Cu and Si were also all pretty high.
Men, Women and Oil Changes... BLUEMEANIE Off Topic 15 09-26-2007 09:42 AM
Synth. Oil Change Interval? Phi Hardcore Tech and Competition 46 09-18-2007 10:00 PM
oh Snap! Oil Oil everywhere!! Shogun1011 Pre-88 Toyota Pickup/Hilux 9 07-09-2007 04:46 PM
Trading Taco for a moped big chris 2nd Generation (2005+) 126 04-22-2006 04:04 PM
Should i switch Oil type? Mighty~Mart Camry & Solara Lounge 13 04-04-2006 09:01 AM
