Steel Brake Lines - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > 2nd Generation (2005+)
2nd Generation (2005+) Discussion area for the 2nd generation of the Toyota Tacoma
Old 07-03-2007, 08:40 PM   #1 (permalink)
View cu260r6's Photo Gallery
Steel Brake Lines
I've heard many owners complain about the spongines from thier brakes, and mine leave something to be desired in initial power while towing a trailer. Has anyone tired stainless steel wraped brake lines? I use them on motorcycles all the time to cut down on the expansion of the stock rubber lines and provide more power per mm of brake lever travel, but I was wondering if anyone has tried them on thier truck? I searched and found many threads complaining about the brake feel but only one post about SS lines.
cu260r6 is offline   Reply With Quote
Old 07-03-2007, 08:53 PM   #2 (permalink)
Banned
BillBrasky's Avatar
iTrader Score: 12 reviews
View BillBrasky's Photo Gallery
I have these all the way around. Had thenm about a year now.
http://www.cardomain.com/item/GDR221155
They will make the squishy pedal go away.
There is a member here named Adospeed (I think) that works for Goodridge. He's full of good info on this subject.
BillBrasky is offline   Reply With Quote
Old 07-03-2007, 09:18 PM   #3 (permalink)
Official Newb
TucsonTRD's Avatar
View TucsonTRD's Photo Gallery
i put stainless lines in the rear, but i didn't notice any difference in pedal feel. but i only changed the rear lines for more suspension travel. so far, i don't have any complaints about the braking power or feel, so i haven't looked into swapping the front lines
2006 Tacoma DC 4x4 OR, OME 884 Coils, Alcan custom leaf pack, Bilstein 5125's, Cooper Discoverer STT's 265/75R16
TucsonTRD is offline   Reply With Quote
Old 07-03-2007, 09:23 PM   #4 (permalink)
View 05SCtaco's Photo Gallery
what about the brakelines from wheelers? I've been pondering about getting some but i don't know about the quality and build. Anyone have them from wheelers?
I take it to yo mama's house.
05SCtaco is offline   Reply With Quote
Old 07-03-2007, 09:30 PM   #5 (permalink)
Banned
BillBrasky's Avatar
This is a quote from Adospeed about mis-matching rubber and SS brake lines, and subsequently, why I went all the way around instead of just the rears.
Originally Posted by Adospeed
I dont recommend running 2 lines SS and the other two stock. You will have a disproportionate amount of brake pressure shifted to the rear lines... In theory that could lead to lock up easier.
You can take the Goodridge part number for the stock height vehicle and then simply add + "inches"over stock.
Example : 24104 + 4" (thats not the correct part number, just using it for an example.
You can then special order them through a Goodridge dealer.
(yes I do Tech support at Goodridge)
Old 07-03-2007, 09:51 PM   #6 (permalink)
Pb
Surfing TN via iPhone
Pb's Avatar
iTrader Score: 15 reviews
View Pb's Photo Gallery
Wheelers just re-sells the Goodridge kit. I have em. I hope to install them in a couple weeks.
To illiminate the sponginess need to replace both the front and the back. If you replace just back then your stock front hoses will still expand. Getting SS front and rear lines will illiminate the weak spots.
Pb is offline   Reply With Quote
Old 07-03-2007, 10:31 PM   #7 (permalink)
If the braking system uses two different master cylinders like on some vehicles then there won't be as negative an effect from just switching one end, but it they run off the same master then you'll stress the rubber ones out without gaining much benifit from the steels.
Old 07-04-2007, 12:50 AM   #8 (permalink)
Badassness
BruynBoy's Avatar
Location: Sasquatch Protection & Refuge Area (Whatcom County, WA)
View BruynBoy's Photo Gallery
I have the goodridge 4" extended lines, and they definitely helped with the brake feel. No more spongy brake pedal, and it also got rid of the abs chatter.
Donahoes, Dakars, Glassworks, 35" Toyo M/Ts, AR Fuels, TRD S/C
BruynBoy is offline   Reply With Quote
Old 07-04-2007, 08:23 AM   #9 (permalink)
Banned
BillBrasky's Avatar
Yeah, they are money well spent, IMO.
brake lines iwannadie Supra Forum 4 05-21-2006 09:01 AM
Custom Stainless Steel Brake Lines? 86B General Discussion 8 11-20-2004 04:31 AM
Brake lines hydra504 Camry & Solara Lounge 0 03-06-2004 12:18 PM
Brake lines - advice needed kocho Camry & Solara Lounge 2 07-01-2003 02:30 PM
Stainless Steel Brake Lines SpectraBlueCam General Discussion 7 11-30-2001 05:06 PM
