Originally Posted by iTacomike9
^^^ On a budget. I was going with a fabtech performance 6" lift kit, but I can wait on that.
Was just wondering if this will work, thats all. Thanks for the info tho.
That spacer goes ontop of (and outside) of the coil assembly.
What happens - it drops your entire suspension geometry downward.
If I remember correctly - there's a few issues that can create....
1) BAD driveline angles on front axle shafts / cv joints. Unless of course, you get a front diff lowering kit of some type.
2) You take the chance of bottoming out your struts easily on compression.
3) From what I remember....I think your knuckles will actually come in contact with your coil assembly. Since the A-arms are soooo stretched out, that puts the knuckles sooo close.
