Question about TC UCAs. - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > 2nd Generation (2005+)
2nd Generation (2005+) Discussion area for the 2nd generation of the Toyota Tacoma
Old 09-06-2007, 11:03 PM   #1 (permalink)
View menacekustoms's Photo Gallery
I just put my UCAs in today, and I noticed the truck is a LOT stiffer in the front. Could I have over-tightened the long bolt? Do I need to grease them more? Or, is this all normal?
Josh
menacekustoms is offline   Reply With Quote
Old 09-06-2007, 11:14 PM   #2 (permalink)
Toyotanation
iTrader Score: 12 reviews
View toku58's Photo Gallery
Did you have your truck aligned yet? If not, Try getting your alignment done. Because of the change in the angle it may have changed the ride characteristics.
As long as you greased it up prior to install and tightened it to 85 ft lbs. torque. It should be O.K.
Good Luck!
toku58 is offline   Reply With Quote
Old 09-06-2007, 11:16 PM   #3 (permalink)
Pb
Surfing TN via iPhone
Pb's Avatar
iTrader Score: 15 reviews
View Pb's Photo Gallery
Yeah, it's possible to overtighten it. I had mine too tight. I loosened it and the ride felt better. Don't tighten it so much that you distort the bushings.
Pb is offline   Reply With Quote
Old 09-07-2007, 09:44 AM   #4 (permalink)
New Tacoma owner
tcook's Avatar
View tcook's Photo Gallery
How often do you guys grease your TC UCA's
3" ToyTec Coil lift, OME shocks all around, TC UCA's, 285/70/17 Nitto Terra Grappler AT's on 17" ProComp 7089 Xtreme Alloys
tcook is offline   Reply With Quote
Old 09-07-2007, 11:49 AM   #5 (permalink)
Learning to Crawl
View ghan's Photo Gallery
I've heard you should grease them every time you rotate your tires.
I plan on doing it at each oil change, just to see how much grease they take.
I've noticed some grease oozed out after the first off road day, then the drivers side started to creak a little.
07 Silver TRD Sport DC SB 4x4
ghan is offline   Reply With Quote
Old 09-07-2007, 12:52 PM   #6 (permalink)
Learning to Crawl
I think the torque spec on the OE UCAs is 85ft/lb so that's what I tightened mine to and the bushings didn't distort.
If you loosened yours, what did you re-torque them to? My ride seems just a little stiff in the front, but I thought it might be because I cranked the DR Coilovers above 2.5 inch lift.
Thoughts?
Old 09-07-2007, 02:21 PM   #7 (permalink)
Playoff bound, 8 long yrs
zmtnbik's Avatar
View zmtnbik's Photo Gallery
Thoughts?
Did you install the coil-overs and the UCA's at the same time, or did have the coiovers on for a bit, then install the UCA's.
If it was the 1st scenario, then it's probably the result of the coilovers. The more you crank them down, the stiffer they will become since you are limiting the coilover travel and compressing the spring. If you are still having problems, time to start dating a heffer
2006 4x4 Access, V6, 6spd, TRD Off-Road, tow pkg. Donahoe Co's, TC UCA's, Dakar leafs, 5125's in the back and u-bolt flip kit. TRD exhaust, CAI. URD MAF calibrator. 17x9's, 285/70/17 BFG MT KM2. Locker-mod, fog mod and console vault.
zmtnbik is offline   Reply With Quote
Old 09-07-2007, 03:36 PM   #8 (permalink)
Learning to Crawl
I tried dating a heffer, didn't help. Those DR Coilovers are T U F F!
I installed both at the same time. I'm wondering what torque Pb tightened his to.
Think 75 ft/lbs would be safe? At least for a trial?
5hrs bouncing around in a rock garden didn't seem to loosen anything up.
I am installing my TC UCA's and the bolt is too long to remove without cutting it.... SinCityTaco 2nd Generation (2005+) 8 01-07-2006 09:18 PM
Attn: Scion Tc Owners Swift2fly 1st Generation (2005-2010) 26 07-23-2005 06:43 PM
2006 tC robit 1st Generation (2005-2010) 1 05-28-2005 01:02 AM
Faster 0-60 time = RSX Auto or tC Auto? cman2000 General Discussion 25 05-23-2005 02:40 PM
04 Tundra 4x4 TC lockup for off road question... Kartek 1st Generation (2000–2006) 3 05-09-2005 10:44 PM
