Clutch Squeak - 2nd Time - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > 2nd Generation (2005+)
2nd Generation (2005+) Discussion area for the 2nd generation of the Toyota Tacoma
Old 09-07-2007, 11:21 AM   #1 (permalink)
View itawes's Photo Gallery
Took my '05 X-Runner in for the clutch squeak TSB about a year ago. The clutch pedal assembly was replaced. It has started to squeak again. Anyone who did the TSB have this same problem?
itawes is offline   Reply With Quote
Old 09-07-2007, 02:09 PM   #2 (permalink)
Just duct tape it!
06Sport's Avatar
View 06Sport's Photo Gallery
I just had it done and not even 1 week later it is creeking again. Rediculous.
Try and beat my BRUTE! http://06sport.mybrute.com
06Sport is offline   Reply With Quote
Old 09-07-2007, 03:37 PM   #3 (permalink)
C5 Meter Minder
hoofhearted's Avatar
View hoofhearted's Photo Gallery
+1
You gotta be tough to fly the heavies!
hoofhearted is offline   Reply With Quote
Old 09-07-2007, 07:01 PM   #4 (permalink)
frankho's Avatar
View frankho's Photo Gallery
+1
2005 Tacoma Prerunner,
Indigo Ink Regular Cab.
Dueler A/T Revos
Bestop Canvas Top
About as basic as you can get.
frankho is offline   Reply With Quote
Old 09-07-2007, 08:07 PM   #5 (permalink)
forget about "tsb's"
6shooter's Avatar
Gameroom cash: $110100
View 6shooter's Photo Gallery
have them do it again. even if it's out of warranty, they will do it no charge because you already had it done once and they can see that it is the same problem.
6shooter is offline   Reply With Quote
Old 09-07-2007, 10:35 PM   #6 (permalink)
05 Speedwayblue X-runner
rpmspeedyBlue's Avatar
View rpmspeedyBlue's Photo Gallery
Over at XR-U website found a fix for the squeaking clutch-
[QUOTE=tacoturbo;66618]Aloha guys. I think this might help. I've had the creaky clutch before. I work for Toyota and the first repair under the TSB lasted for about 6 months. The creak came back worse than ever. I think I found the problem and solution. The clutch pedal arm is a composite (plastic) material and the pivot point on the plunger shaft mates in the back. What I've noticed is that over time the shaft has a tendency to rotate alittle, enough so that the pivot point binds and causes a creak that is heard and felt in the pedal as it's depressed. Mine creaked and vibrated on the first initial travel of 1 1/2 to 2 inches. All I did was to rotate (center) the shaft untill it felt like it was in the pocket again. Squeak, creak and vibration is gone. The cure was instant and has not returned for 2 months now. As an experiment I rotated the shaft as if it was out of line and the creak returned. To me the problem is identified and solved on my X. Try this it may work and save you a trip to the dealer. BTW, I didn't lube the pivot at all. I hope this helps. The creaky cluch drove me nuts!
Stock 05 X-Runner
rpmspeedyBlue is offline   Reply With Quote
Old 09-10-2007, 12:34 PM   #7 (permalink)
[quote=rpmspeedyBlue]Over at XR-U website found a fix for the squeaking clutch-
CAn you hand turn that or do you need a grip or pliars?
Old 09-10-2007, 04:54 PM   #8 (permalink)
C5 Meter Minder
Any pics??
Old 09-10-2007, 05:55 PM   #9 (permalink)
View gtimark's Photo Gallery
Originally Posted by hoofhearted
Any pics??
x2!!
'07 4x4 Regular Cab
gtimark is offline   Reply With Quote
Old 09-10-2007, 06:25 PM   #10 (permalink)
[quote=itawes]
you can hand turn the whole shaft by hand about 1/3 of a turn. I turn it about an 1/8 each time and pressed the clutch until it stopped squeaking. so far no squeaking even when the weather was in the 100,
Stock 05 X-Runner
Old 09-10-2007, 07:45 PM   #11 (permalink)
Thanks for the above pic!! So, it's the silver shaft with the nut on top that we're supposed to rotate ... right?? Sorry to sound so ignorant ... but.
PS And thanks for such a quick response!!
'07 4x4 Regular Cab
Old 09-10-2007, 11:55 PM   #12 (permalink)
[quote=gtimark]
Yes your correct the silver shaft/nut + the black plastic unit will move. No problem with the questions.
http://[IMG]http://img174.imageshack....gif[/IMG]
Stock 05 X-Runner
Old 09-11-2007, 02:31 AM   #13 (permalink)
Go Balls Deep
stocktaco's Avatar
View stocktaco's Photo Gallery
Cool beans!
The Five D's of Dodgeball: Dodge, Duck, Dip, Dive, & Dodge
stocktaco is offline   Reply With Quote
Old 09-11-2007, 07:03 AM   #14 (permalink)
Just duct tape it!
06Sport's Avatar
I checked the shaft and it is extremely loose... It rotates and has a lot of play. It got rid of the creaking but only for about 10 minutes. Is there a way to tighten it up at all? Because it wont stay in one place at all. I definitly believe that is the culperit though because it does make it go away, but it comes right back because i think its so loose.
Old 09-18-2007, 07:37 PM   #15 (permalink)
I checked mine too and found the same problem: the shaft rotates way too easily. I can't figure out the correct position. The creaking/squeaking will come and go through a trip home from work.
It seems like that shaft needs to be tightened, kind of like SpeedyBlue has stated. But, I've had no luck with the 1/3rd turn yet. I've found no "sweet spot" for it to sit in.
Anymore words of advice???
'07 4x4 Regular Cab
interesting article about double clutching boroEF Hardcore Tech and Competition 40 07-23-2007 01:12 AM
clutch squeak zoidberg Archived Corolla threads 16 05-22-2006 04:09 PM
Clutch Pedal Squeak karazy 1st Generation (1995.5–2004) 2 04-13-2006 05:14 PM
new clutch = broken wallet eyz closd MR2 Forum 4 03-12-2005 04:16 PM
Time for new clutch(?) userlain Camry & Solara Lounge 4 07-14-2004 03:59 AM
