Help - Cv Boot - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > 2nd Generation (2005+)
2nd Generation (2005+) Discussion area for the 2nd generation of the Toyota Tacoma
Old 09-07-2007, 08:25 PM   #1 (permalink)
Shut yo azzz
hooch364's Avatar
View hooch364's Photo Gallery
Help - Cv Boot
When doing my first oil change I noticed grease in the passenger side front wheel well and on my lower control arm. It appears to be CV boot grease, so I checked the boot and the spring. There was no tear and the CV boot clamps were fine. I also checked the bushings and they all seem OK.
Only thing done to truck was new font struts to level front end and an alignment. Have 32in tires on front.
Any ideas?? Could the techs grease the front when doing alignment and it is spitting out? I could not find anything when I inspected it? Thanks.
2007 White Tacoma DC TRD Sport 4x4
Rancho Quick Lift, Firestone Riderite Air Bags, Tint, Definity MT 265-75-16, Wheelers black alloy wheels, Blacked out badges and emblem.
hooch364 is offline   Reply With Quote
Old 09-07-2007, 08:26 PM   #2 (permalink)
forget about "tsb's"
6shooter's Avatar
Gameroom cash: $110100
View 6shooter's Photo Gallery
check your tie rod end for a split in the boot. i just replaced mine for that very reason.
6shooter is offline   Reply With Quote
Old 09-07-2007, 09:06 PM   #3 (permalink)
Ron Jeremy's twin brother
screeber's Avatar
iTrader Score: 6 reviews
View screeber's Photo Gallery
Did you check the inner boots as well? There's nothing that I can think of that would require more grease, so I think you are on the right track looking for a tear.
- disinterested
screeber is offline   Reply With Quote
Old 09-07-2007, 09:09 PM   #4 (permalink)
Shut yo azzz
hooch364's Avatar
6shooter,
Does the tie rod/bushing hold that much grease in it? Does the tie rod get a constant feed or is the the grease only in the bushing?
Also, did they cover it under warranty. Did they give you any problem because of your lift work?
Old 09-07-2007, 09:12 PM   #5 (permalink)
Pb
Surfing TN via iPhone
Pb's Avatar
iTrader Score: 15 reviews
View Pb's Photo Gallery
It's just packed with grease. If you hit it right some grease will squeeze out around the edge.
Pb is offline   Reply With Quote
Old 09-07-2007, 11:21 PM   #6 (permalink)
6shooter's Avatar
+1
also, i work for toyota so i have an unfair advantage when i comes to the question of warrantable or not - but in general, most dealerships should not give you any grief about it.
CV Boot Replacement - 97 Camry milano maroon 3rd & 4th Generation (1992–1996 & 1997–2001) 2 07-07-2007 06:59 AM
CV Boot problem dafugitive415 1st & 2nd Generation (1983–1986 & 1987-1991) 4 11-29-2006 09:06 PM
Replacing Inner CV Boot hydrogenh2 89-95 Toyota Pickup/Hilux 2 10-21-2006 11:01 AM
help with 4agze cv boot gasman Archived Corolla threads 6 10-06-2005 02:26 AM
91 Camry: Should I try to change cv joint boot? alkon 1st & 2nd Generation (1983–1986 & 1987-1991) 0 08-09-2005 08:19 AM
