rear leaf replacement and lift - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > 2nd Generation (2005+)
2nd Generation (2005+) Discussion area for the 2nd generation of the Toyota Tacoma
Old 09-07-2007, 08:39 PM   #1 (permalink)
View Shawster's Photo Gallery
Just had my rear springs replaced with the 4 leaf replacement. Prior to replacing I had the 884 coils in front and the AAL in the rear with the 3 leaf pack. With 265 70 17's, I was measuring 39 1/4 from the ground to the top of the arch on the rear. Now with the 4 leaf pack I'm measuring 37 1/4 for a 2" drop. I was hoping to only lose an inch or so. Not too happy with the stance now as it is nose high. No question is rides better as the rear springs aren't as stiff as they were with the AAL but I would like to gain some height back. I don't really want to put the AAL back in as I'm going to go the other way and then be too high.
I'm looking for about 1 to 1 1/2 inch increase in the back. Any suggestions? Also this is a 2005 Double CAB Sport with a Leer cap.
Shawster is offline   Reply With Quote
Old 09-07-2007, 08:42 PM   #2 (permalink)
forget about "tsb's"
6shooter's Avatar
Gameroom cash: $110100
View 6shooter's Photo Gallery
the blocks that come in a revtek kit are 1 1/2" tall. you can buy them seperate too. i'd do that.
6shooter is offline   Reply With Quote
Old 09-07-2007, 10:25 PM   #3 (permalink)
Certified Imposter
SMEbay's Avatar
View SMEbay's Photo Gallery
+2, except I used the ToyTec 1.5" block and the axle shim (instead of RevTek). Truck is maybe 1/2" higher in the rear.
I stayed away from the AAL and 4-leaf spring for the same reason. The rear is still stiffer than the front with 884s, but it feels like a good mix. I expect the rear of a truck to be a little stiffer.
Here is what it looked like the day I got it all installed. The rear was exactly /14" higher. Now, 3 weeks later, the front has settled maybe 1/2" so the rear is now 1/2" to 1" higher, if that.
'06 DC SB Sport, V6, AT, 4X4, MB Gunner 6's, Bridgestone AT, 285/75/16, 884s w/top plate spacer & 1.5" blocks in rear. TSB rear springs... R. I. P.
"The older I get, the better I was."
SMEbay is offline   Reply With Quote
Old 09-07-2007, 10:39 PM   #4 (permalink)
LVtaco05
View coolcatmars's Photo Gallery
Did you install the spacers? If you did you could probly remove them and it will take away about 1" on front. It's an easy way to level it.
coolcatmars is offline   Reply With Quote
Old 09-07-2007, 11:15 PM   #5 (permalink)
6shooter's Avatar
that's awesome looking.
Lifting your Taco. Things you need to know? toku58 2nd Generation (2005+) 67 05-13-2009 07:15 AM
Replacement Leaf Springs Yankee 1st Generation (1995.5–2004) 7 08-08-2007 09:22 PM
Best Rear Springs for lift and Load? jedi 2nd Generation (2005+) 17 02-14-2007 01:40 PM
2006+ and Greater than 2.5 Inch Front lift ? planohog 2nd Generation (2005+) 4 01-17-2007 07:25 PM
