Toytec Rear Shock Extenders helped my Ride! - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > 2nd Generation (2005+)
2nd Generation (2005+) Discussion area for the 2nd generation of the Toyota Tacoma
Old 09-07-2007, 08:49 PM   #1 (permalink)
View 2008trd's Photo Gallery
Did OME coils with AAL using the OEM factory off road Bilstiens. Had issues with the factory shocks fully extending at the slightest bump and dip. Doug with Toytec decided to fabricate a solution in the form of extenders. I received the Toytec extenders today and installed them. All I can say is wow! What a remarkable improvement over the stock set up with AAL.
The Tacoma off road set up with the Blistiens would fully extend at the slightest dip or bump in the road causing a roaring "thump" as the shock had little room before full extension with the AAL rear lift installed. While installing the Toytec rear shock extenders I unscrewed the upper shock mount and noticed the weight of the unsupported rear differential caused the shock to drop approx. 2 inch from the shock mount while in the fully extended shock position. The rear shock extenders added 2 1/2 to 3 Inches of added length to the height of the shock and mount thus allowing increased travel.
The result is a much smoother ride and the ability to hit dips and bumps without slowing and realizing the factory shocks damping effect as if I installed extended length shocks. No more worries of hitting a bump to fast with the AAL and breaking to avoid a jarring experience for passengers or myself. The install itself was done in 20 minutes.
Doug and Toytec thanks again for your insight, the fabrication and expertise.
(Sorry about the Phone Pics below)
2008trd is offline   Reply With Quote
Old 09-07-2007, 09:03 PM   #2 (permalink)
Forumatic Immunity!
docindahouze's Avatar
iTrader Score: 9 reviews
View docindahouze's Photo Gallery
you need to host them on a site like www.photobucket.com and then post the direct link/url in this
05 Tacoma DC LB TRD Sport Super White.
"I thought I'd get your theories, mock them, then embrace my own. The usual."-House.
docindahouze is offline   Reply With Quote
Old 09-07-2007, 09:08 PM   #3 (permalink)
Toyotanation
iTrader Score: 12 reviews
View toku58's Photo Gallery
What about the front? Did you extend those also??
I have been thinking about the shock extenders that NAPA auto parts sell. But I would need to order longer brake lines first.
toku58 is offline   Reply With Quote
Old 09-07-2007, 09:12 PM   #4 (permalink)
No Toku, I did not experience any sort of travel limitations with the front set up. In fact the OME front shocks are almost the exact same length as the factory Bilstiens. I checked the rear break lines during install and there was ample play in the line with full extension.
Old 09-08-2007, 01:12 PM   #5 (permalink)
Toyotanation
Oh O.K. you have the OME shocks in the front!
Gotchya!
Old 09-08-2007, 01:45 PM   #6 (permalink)
ilovetacos's Avatar
View ilovetacos's Photo Gallery
Are these on the ToyTec site? I searched and couldn't find them. How much are they? Will they give any lift at all?
ilovetacos is offline   Reply With Quote
Old 09-08-2007, 05:42 PM   #7 (permalink)
Banned
beastbluetaco's Avatar
iTrader Score: 25 reviews
View beastbluetaco's Photo Gallery
Those seem pretty sweet. How much were they and where did you get them?
beastbluetaco is offline   Reply With Quote
Old 09-08-2007, 07:01 PM   #8 (permalink)
sandpic's Avatar
View sandpic's Photo Gallery
Looks to me like a threaded rod coupling with a stud screwed in one end. I'm sure it's stong and most of the force is inline with the shaft. But in my eyes you just created a weak link. I've seen failure occur normally before or after the coupling, but they were used in construction fabrications. I don't know how much I would trust that. just my 2 cents.
sandpic is offline   Reply With Quote
Old 09-08-2007, 07:58 PM   #9 (permalink)
LaVaCrAwLeR
beachbumz's Avatar
View beachbumz's Photo Gallery
wow, just thinking of getting new extended length shocks for the rear earlier today when I wentover a speed bump to fast and THUNK... This might be all I need.. I have the AAL's with the stock trd offroad shocks, SWEET!
thanks for the heads up...
I'll give doug a call... next week.
aloha
beachbumz is offline   Reply With Quote
Old 09-08-2007, 08:00 PM   #10 (permalink)
Toyotanation
You can get these at most auto parts stores. Ask for shock extenders.
They do not give any lift. They allow your shocks to have full range of damper.
Old 09-08-2007, 08:47 PM   #11 (permalink)
ilovetacos's Avatar
Thanks Toku!
Old 09-08-2007, 09:05 PM   #12 (permalink)
LaVaCrAwLeR
beachbumz's Avatar
So what are the cons of using these? Do they snap pretty easy? or?? anybody else using these?
Old 09-08-2007, 11:57 PM   #13 (permalink)
These will be a new item offered from Toytec. I believe they will be in the $10-$20 range. Give Doug with Toytek a call.
Old 09-16-2007, 08:28 PM   #14 (permalink)
View MDTRD's Photo Gallery
09 Camry SE V6
07 Taco DC TRD OR
06 Sequoia Limited
00 Taco Xtracab s/c'd TRD V6 5sp -- PARTING OUT!!!
MDTRD is offline   Reply With Quote
Old 09-16-2007, 08:43 PM   #15 (permalink)
ilovetacos's Avatar
They're now on the toytec website for $10.99
Smoother ride in the rear... what do you recommend? pointerDixie214 2nd Generation (2005+) 7 12-19-2006 10:32 PM
Anyone with a 3" lift?????? toku58 2nd Generation (2005+) 9 09-17-2006 03:51 PM
Drift Setting help for GT3 I hate Toyota Corp :( Off Topic 3 11-10-2003 10:36 PM
