Front Parking Light Mod - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > 2nd Generation (2005+)
2nd Generation (2005+) Discussion area for the 2nd generation of the Toyota Tacoma
Old 09-09-2007, 10:04 PM   #1 (permalink)
View gtimark's Photo Gallery
Since my first Toyota truck in the late '80s, I've always wanted to have BOTH the turn signal light and the side/front parking light illuminated simultaneously. Being lazy, I never bothered to actually wire it up.
This mod is for the lazy modder
The front turn signal is actually set up for the "running light" mod -- the bulb has 2 filaments, and the socket has 3 pins (ground, blinker, and running light). All I did was run one wire from the turn signal pin to the side marker light. So easy!!
My truck does NOT have DRLs; and I don't know the possible negative interactions (if any) that may arise because of them.
Without the headlight on ...
With the headlight on ...
BTW: the intensity of the turn signal is equal to that of the side marker light .. even though it appears brighter in the pic.
'07 4x4 Regular Cab
gtimark is offline   Reply With Quote
Old 09-09-2007, 10:11 PM   #2 (permalink)
Toyotanation
iTrader Score: 12 reviews
View toku58's Photo Gallery
Sorry the front DTRL's are the Blinkers!
The filament that you hooked up is the low light. The actual DTRL uses the same filament that the blinker uses. That other filament is NEVER used.
The way you did your has been done by many member here. Do a search and you'll find tons of info on that.
But It works. But just not as bright.
toku58 is offline   Reply With Quote
Old 09-09-2007, 10:17 PM   #3 (permalink)
No, each filament has its own energy source. BOTH filaments are used; one for the turn signal; one for the running light. This is why I posted that the trucks with DRLs may not be the same.
'07 4x4 Regular Cab
Old 09-09-2007, 10:23 PM   #4 (permalink)
Toyotanation
No sorry you did this DTRL mod I think it was a sticky:
http://www.toyotanation.com/forum/t164710.html
This is how it comes from the factory:
http://www.toyotanation.com/forum/t176420.html
That 3rd wire is never used. And the Factory DTRL's are much brighter.
Landcruiser (1994) Front Parking Light bulb replacement gregorykorzon Land Cruiser Forum 1 03-15-2007 07:16 PM
front light setup downsouthdx Camry & Solara Lounge 1 02-25-2005 07:37 PM
Parking Light Flasher Mod dna59 Camry & Solara Lounge 2 08-05-2004 03:38 PM
AE92 trunk light mod homeguard Archived Corolla threads 25 04-18-2004 05:50 AM
