Synthetic Oils - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > 2nd Generation (2005+)
2nd Generation (2005+) Discussion area for the 2nd generation of the Toyota Tacoma
Old 09-10-2007, 01:18 PM   #1 (permalink)
View Hamdog1600's Photo Gallery
Synthetic Oils
I have a 07 Taco DBL Cab 4x4 with 12K miles on it. I have been running mobil 1 synthetic oil since the first oil change. Not much of a gear junky, but learning more and more each day so I was wondering what other oils in the truck should be replaced with fully synthetic oil (ie transmission, differentials, etc)? And what are peoples opinions on switching over to fully synthetic (pros and cons)? Thanks!
Hamdog1600 is offline   Reply With Quote
Old 09-10-2007, 01:43 PM   #2 (permalink)
demoncleaner's Avatar
View demoncleaner's Photo Gallery
I put full syn oil in the tranny (6spd), transfer, and front diff at 20K. LSD Rear Diff used syn blend. I put on alot of miles on in the winter, often in 4wd, so figured why not put in the good stuff. Everything works great even when its zero.
Do you need to run full syn? no. But in temps as cold as -30F, conventional oils are approaching their pour point.
6-spd, 05' D-cab Sport 4x4, Tow pkg, TRD exhaust
Summer: Stock 17's
Winter: Blizzaks on 16' black steelies
demoncleaner is offline   Reply With Quote
Old 09-10-2007, 01:45 PM   #3 (permalink)
Go Sharks!!!
SJlittlefoot's Avatar
View SJlittlefoot's Photo Gallery
most fluids in the tacoma can be replaced with synthetic except the auto tranny fluid. It requires expensive Toyota longlife stuff and using anything else will void the warrenty.
i'm running mobile 1 in the engine and rear diff and probably will continue to do so.
Pros:
Superior protection
Run it longer then conventional
Might increase some MPG (i gained about 1.5mpg average when i switched to synthetic)
Cons:
Cost more
06 Tacoma D-cab Prerunner TRD Off-Road
http://www.cardomain.com/ride/2284057
SJlittlefoot is offline   Reply With Quote
Old 09-10-2007, 05:14 PM   #4 (permalink)
Softball God
WilsonTheDog's Avatar
View WilsonTheDog's Photo Gallery
FYI: Bobistheoilguy.com has a lot of info.
Eric
2007 Toyota Tacoma
PreRunner SR5 V6 DC SB
WilsonTheDog is offline   Reply With Quote
Best synthetic oils? six7one 89-95 Toyota Pickup/Hilux 18 09-02-2007 01:24 PM
And The Day Has Come! Black 2000 Trd 4x4 Is Mine!!!! jentzschman 1st Generation (1995.5–2004) 13 08-21-2007 03:27 PM
Tranny Oil Xlerator 1st Generation (1995.5–2004) 3 03-19-2007 05:02 PM
Anyone heard of SR-1 SYNTHETIC MOTOR OILS TRD_Rob Camry & Solara Lounge 3 06-01-2004 07:37 AM
