Oil filter? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > 2nd Generation (2005+)
2nd Generation (2005+) Discussion area for the 2nd generation of the Toyota Tacoma
Old 09-12-2007, 08:40 AM   #1 (permalink)
View ECrepeau's Photo Gallery
Oil filter?
What oil filter is everyone using? The stock toyota? Was planing on using the stock toyota, but came across a coupon for buy one get one free for the Purolator Pureone filter. Also, was originally going to run Castrol GTX, but came across a coupon for the New Mobil 7500 for 99 cents a bottle.[FONT='Arial','sans-serif'][FONT='Arial','sans-serif'][/FONT][/FONT]
ECrepeau is offline   Reply With Quote
Old 09-12-2007, 09:12 AM   #2 (permalink)
View CrshOverride's Photo Gallery
I use the Toyota OE Filter with Mobil 1 Synthetic.
CrshOverride is offline   Reply With Quote
Old 09-12-2007, 09:18 AM   #3 (permalink)
Official Newb
TucsonTRD's Avatar
View TucsonTRD's Photo Gallery
there is no right or wrong answer here (well maybe a few wrong answers). but you will get 99% opinion. this is like asking a nuetral crowd who's better...ford or chevy?
if you want to make an informed decision and educate yourself about motor oils and filters spend some time on BITOG.
fwiw...i use what i consider the best, k&n oil filter and GC oil. but you aren't going to find that stuff cheap
2006 Tacoma DC 4x4 OR, OME 884 Coils, Alcan custom leaf pack, Bilstein 5125's, Cooper Discoverer STT's 265/75R16
TucsonTRD is offline   Reply With Quote
Old 09-12-2007, 09:26 AM   #4 (permalink)
Just basically wondering if their is any justification in using the toyota filter compared to competiors. For some reason a lot of people seem to lean toward the Toyota filter or a high end and from what I can tell their isn't anything special about the Toyota filter. Yeah wasn't trying to start a debate with everyones opinion just trying to see if there is any justification for the Toyota filter. Cause the info I ahve found is that they are made by Purelator anyways. Also on you pic I don't see the dog listed as a custom add-on. My taco didn't come with one of thos stock.
Old 09-12-2007, 09:39 AM   #5 (permalink)
Official Newb
TucsonTRD's Avatar
yeah, the dog was a dealer option, it was part of their security package
i don't know what type of justification you were looking for about the filter, but most filters are made by the same company. but i can't tell you how the oem filter compares to the purealator filters.
Old 09-12-2007, 10:07 AM   #6 (permalink)
forget about "tsb's"
6shooter's Avatar
Gameroom cash: $110100
View 6shooter's Photo Gallery
use a toyota filter. they are very high quality.
6shooter is offline   Reply With Quote
Old 09-12-2007, 10:25 AM   #7 (permalink)
I can has taco?
Oxymar00n's Avatar
View Oxymar00n's Photo Gallery
I used to use the Toyota filters, but recently switched to the Mobil1 Jeep Liberty filter. It's a good bit bigger (longer) than stock...
Oxymar00n is offline   Reply With Quote
Old 09-12-2007, 10:30 AM   #8 (permalink)
View TurDonor's Photo Gallery
The PureOne seems to have about the finest filtration properties in tests I have seen, but there are some reports that it also allows a lower flow rate. If you run this one, I suggest using the oversized PL20195 rather than the listed PL10241 so you can achieve better flow. Same specs except taller, and there's plenty room for it. (I'm running it.)
TurDonor is offline   Reply With Quote
Old 09-12-2007, 10:48 AM   #9 (permalink)
View meauxjeaux's Photo Gallery
oil filters
Originally Posted by ECrepeau
What oil filter is everyone using? The stock toyota? Was planing on using the stock toyota, but came across a coupon for buy one get one free for the Purolator Pureone filter. Also, was originally going to run Castrol GTX, but came across a coupon for the New Mobil 7500 for 99 cents a bottle.[FONT='Arial','sans-serif'][FONT='Arial','sans-serif'][/font][/font]
Absolutly only use toyata oil filters.They incorporata an anti-drainback valve that keeps oil in the filter while the engine is not running.Ever noticed that your filter is upside down?The benefit is that upon cranking the cold engine it will have instant pressure in the oil system.If the filter was right sside up this would not be a problem.
meauxjeaux is offline   Reply With Quote
Old 09-12-2007, 11:06 AM   #10 (permalink)
View steviestyles's Photo Gallery
Most filters made today incorporate an anti drain back valve . Wix, AC Delco, Purolator, Napa, Mobil1 and Fram all have them in their filters. The Anti drain back valve is not synonomous with just Toyota. Purolator, Mobil 1, Napa/Wix, AC Delco all make great OEM alternative filters.
2007 Silver Mica Double Cab TRD Off Road 4x4
2011 Silver Sienna XLE w/ Entertainment Pkg
steviestyles is offline   Reply With Quote
Old 09-12-2007, 11:19 AM   #11 (permalink)
filters
the toyata probably has a more durable valve than aftermarket because when changing oil with aftermarket filters,oil pours out of them,and not so much with
the toyota.
Old 09-12-2007, 11:26 AM   #12 (permalink)
No what I'm saying is most oil filters are manufactured with an anti drain valve based on the application of the filter. Toyota is not the only filter that has the anti drain capability. I use NAPA Gold filters made by WIX and it too has an anti drain valve. In fact if you do a search on oil filters you will see that the new Toyota OEM filter is not as good as the one that came from the factory in your truck. And before you ask, yes the filter tha comes in your truck from the factory is a different model than most dealers sell.
Old 09-12-2007, 11:28 AM   #13 (permalink)
the toyota.
Probably??? So you're speaking from experience or opinion? Have you used a different filter than the Toyota OEM?
Old 09-12-2007, 11:29 AM   #14 (permalink)
I hate hippies.
tacogrande's Avatar
View tacogrande's Photo Gallery
https://www.amsoil.com/storefront/detail.aspx?ID=6927
The finest filter money can buy. If you love your engine, use these.
tacogrande is offline   Reply With Quote
Old 09-12-2007, 11:32 AM   #15 (permalink)
filters
I have been a professional mechanic for over 12 years and this is the experience I have witnesses thousands of times.The toyota filters are made better,leak less oil out of them when they are removed.
2007 Camry Oil Change FYI! Wizrd23 5th & 6th Generation (2002-2006 & 2007-2011) 139 11-05-2011 07:36 PM
Oil Filter Drain Plug timpearson26 2nd Generation (2005+) 94 08-08-2007 01:43 PM
Full synthetic motor oil - 32¢ /quart + 1 oil filter ... Pep Boys skewe General Discussion 7 01-19-2006 03:31 PM
What I found when changing the oil. Kooter Camry & Solara Lounge 2 10-19-2003 06:37 PM
Oil Filter Wrench BenG Hardcore Tech and Competition 12 07-22-2003 10:01 PM
