Torque converter pretty tight for our trucks? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > 2nd Generation (2005+)
2nd Generation (2005+) Discussion area for the 2nd generation of the Toyota Tacoma
Old 09-12-2007, 03:07 PM   #1 (permalink)
View zmanphx's Photo Gallery
I have the DC prerunner auto. I notice that this truck has a tighter torque converter compared to other vehicles with auto tranny. This is most noticeable when starting the truck up and putting it in gear. The truck moves with ease with no need to push the gas pedal. It can get up to 10 mph easy just in idle. Has anyone else noticed this?
I wonder what is the lowest mph the converter will lock up? Is converter lockup basicly a sixth gear?
zmanphx is offline   Reply With Quote
Old 09-12-2007, 03:11 PM   #2 (permalink)
forget about "tsb's"
6shooter's Avatar
Gameroom cash: $110100
View 6shooter's Photo Gallery
well, when you first start it up as you described, the rpms are much higher until it warms up. so if you're starting it up and putting it into gear right after, it will crawl pretty good i would imagine because the rpm's are so much higher than they are any other time.
6shooter is offline   Reply With Quote
Old 09-12-2007, 03:15 PM   #3 (permalink)
View meauxjeaux's Photo Gallery
touque converter
+1
meauxjeaux is offline   Reply With Quote
Old 09-12-2007, 07:53 PM   #4 (permalink)
MD-80 PILOT
flyman767's Avatar
View flyman767's Photo Gallery
The torque converter has been discussed recently. I believe, the torque converter is the culprit for the many of us who have reported the infamous "lurching" or sudden forward acceleration. . The converter does not appear to be releasing or bypassing at low idle correctly(torque lock-up). Hopefully, with the several dozen + Tacoma owners complaining about this...Toyota will come up with a fix.
As far as the high idle at start-up...this is designed strictly for emissions. The quicker the catalytic converter heats up... the less pollution.
http://www.toyotanation.com/forum/t209055-4.html
http://www.toyotanation.com/forum/t182096.html
2007 TRD OFF-ROAD, Auto, VSC, Truxedo LoPro Soft Cover, Stainless Factory Tube Steps(Challenger's), EGR In Channel Window Shades, Black headlight Mod, EGR AERO Bug Guard, Amsoil series 2000 synthetic 0W-30
flyman767 is offline   Reply With Quote
spark plugs torque specs??? rice Archived Corolla threads 7 10-23-2006 01:33 PM
torque imbest123 General Discussion 7 05-19-2006 04:09 PM
Auto Trans / Torque Converter life expectancy?? redgtxdi Camry & Solara Lounge 5 08-03-2005 12:55 AM
Cat Converter Flange bolts?? green94camry Camry & Solara Lounge 1 11-19-2004 06:15 PM
Gen 3 Torque converter clutch lockup JasonH 3rd & 4th Generation (1992–1996 & 1997–2001) 0 04-16-2004 09:47 AM
