UCA Install + Alignment = Rubbing - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > 2nd Generation (2005+)
2nd Generation (2005+) Discussion area for the 2nd generation of the Toyota Tacoma
Old 09-12-2007, 05:17 PM   #1 (permalink)
hack the planet
View vitruvius's Photo Gallery
Wrote a long post only to have a "page cannot be displayed" bite me in the ass.
UCA installed caused some rubbing which I expected, but after the truck was aligned, it started rubbing the cab mount in the back of the wheel well.
Truck was aligned to these specs:
Caster: 2.4*
Camber: -.1*
Toe: .04*
Both right and left sides match perfect.
If you look at the truck from the side, with the wheels pointed straight ahead, it looks like there's about 1 inch of clearance between the fender flare and the tire in the back, and about 3 inches in the front.
Seems like the caster angle is too steep and is pulling the tire back in the wheel well. If I increase the caster, maybe to 4*? Think it would bring the tire back into the center of the wheel well? Any advice? Thanks!
2005 Toyota Tacoma Double Cab Short Bed w/ Auto, TRD Offroad, and Towing Packages
http://www.cardomain.com/id/Vitruvius
vitruvius is offline   Reply With Quote
Old 09-12-2007, 09:28 PM   #2 (permalink)
hack the planet
Anyone got any advice?
Old 09-12-2007, 11:27 PM   #3 (permalink)
Toyotanation
iTrader Score: 12 reviews
View toku58's Photo Gallery
Your specs all look good!
How big are your tires? And do you have a lift?
Sorry! Just checked you Cardomains.
Your ires should clear? But obviously it doesn't.
The specs you have are exactly the same as mine.
And my rims only have 2 1/4" BS so if anything mine should be worse than yours.
Do you have better pics of your set up?
toku58 is offline   Reply With Quote
Old 09-12-2007, 11:36 PM   #4 (permalink)
Toyotanation
Here is a picture of my truck from the side:
I have more than enough clearance from the rear and the front fenders. I have at least 3" front and back
Can you post pictures of your UCA's I would like to see their orientation.
Your tire should NOT have moved so far to the rear.
Old 09-14-2007, 11:42 AM   #5 (permalink)
hack the planet
I'll take some pictures later today, still haven't figured it out. Best guess is the caster but we'll see.
Old 09-14-2007, 12:13 PM   #6 (permalink)
hack the planet
Old 09-15-2007, 06:38 AM   #7 (permalink)
hack the planet
Toku, help!
Old 09-15-2007, 08:11 AM   #8 (permalink)
Trevor
View Adventure North's Photo Gallery
I'm going to say too much caster for the amount of lift you have. When it comes to lift and alignment specs one size certainly does not fit all. What are you sitting at? 2 - 2 1/2 inches of lift with the 884's?
My Images
Trevor
Adventure North is offline   Reply With Quote
Old 09-15-2007, 09:22 AM   #9 (permalink)
hack the planet
Just shy of 2.5" in the front, so you're saying I should probably increase the caster angle or decrease?
From what I understand, if I increase the angle, the tires will move forward more, angle moving from verticle to horizontal.
Decreasing would move the tires even further back, increasing rubbing and moving the angle from horizontal to vertical.
So I should increase the angle of caster in order to solve my problem? And if so, by how much? It's at 2.4* now, should I try 3*, 4*, 5*? I don't want to have to pay for an alignment 10 times, but also don't want to over shoot it.
Old 09-15-2007, 09:50 AM   #10 (permalink)
I hate hippies.
tacogrande's Avatar
View tacogrande's Photo Gallery
Read this, it should help you explain what you need to the alignment guy. Just because you are "within specs" doesn't mean you can't move your tire further away from the body mount and get the exact same numbers. http://www.*******.com/fsm/05+/data/...a/03900310.pdf
I would start by turning your rear cams to + until your tires clear, and then dial everything else into those. There's lots of adjutment, don't worry about maxing anything out.
tacogrande is offline   Reply With Quote
Old 09-15-2007, 10:27 AM   #11 (permalink)
hack the planet
I understand what you're saying, and I shouldn't have a problem explaining it as long as the guy "wants" to understand. He was cool about it last time so hopefully he can help me out. Going to have him set it up to the maximum amount of tire clearance and then dial in the alignment angles from that point. Thanks for the help, we'll see what happens.
Old 09-15-2007, 02:23 PM   #12 (permalink)
Toyotanation
+1 Agreed you don't have enough lift for the size tire!
Your tire are too large for the amount of lift you have.
Measure you height from ground to bottom of the fender, through the middle of your center hub. Should be about 39" with those tires. Mine is about 39.25".
Where is the top spacer plate??
Just to clarify: If you use the stock UCA's with 2.5" of lift you can get away with 285's but you alignment will be set at towards the MINIMUM spec range.
To be able to set it to the IDEAL alignment settings with 285's you will need a full 3" of lift. ("Ideal" is mid point of the Min. and Max. of the spec range for your alignment)
So either you set your truck more towards the Minimum which would make the cost of the TC's sort of a waste. (Because your truck will not get the full benefits of the UCA's)
Or install the top plate to give you better clearance. the 1/2" top plate will lift your truck an additional 3/4". That way your front will become a bit more level with your rear.
Good Luck!
Old 09-15-2007, 04:16 PM   #13 (permalink)
Trevor
A typical lift really has nothing to do with the ability to fit a larger tire. Should a "lifted" suspension be cycled it will still move through the same plane as it did stock. Reality is increased fender clearance by way of trimming, wheel offset and relocation of the bumpstops are what allow for a larger tires to fit properly.
My Images
Trevor
Old 09-15-2007, 04:42 PM   #14 (permalink)
Toyotanation
Yes AN is correct. But I guessing that because of the lesser lift it has caused your caster to move too far back. When you lift it higher you caster will be over the 2.4*.
Here are pictures of how my wheels sit:
My tires sit almost perfectly in the middle of my wheel well.
Rubs slightly only when the wheel gets jammed up in the fender while I'm reversing and turning.
Old 09-15-2007, 04:46 PM   #15 (permalink)
Spanky!
View hyperlitewkbrdn's Photo Gallery
wow i havent been on here in forever, thought id chime in on this one.
i have the 884's with the 1/2" spacer and i have had the same problem as vitru for a few months now. it rubs on the metal bracket towards the rear bad. i'm wondering if its because of the 884's but i dont know. the reason for this is because it rubbed on the front before i got the tc uca's. once i got the uca's and increased the angle, it seemed like it pulled the tire back. it changed from like .8 to 2.4 i think and now it rubs on that back bracket instead of the front fender. so maybe the angle should be decreased????
06 Double Cab 4x4 TRD Off-Road Silver V6 6 Spd Manual
hyperlitewkbrdn is offline   Reply With Quote
5s-fe turbo install list R94CamryT Hardcore Tech and Competition 32 04-29-2009 01:37 AM
Total Chaos UCA Install Question vitruvius 2nd Generation (2005+) 6 09-20-2007 04:46 PM
Mechanical Oil Pressure Gauge Install Stillrunning 3rd & 4th Generation (1992–1996 & 1997–2001) 0 09-05-2007 05:12 PM
Help...bad alignment and other probs Redline Camry & Solara Lounge 3 03-09-2004 09:34 AM
Strut bar and alignment!!! need help Vampress Camry & Solara Lounge 17 06-28-2003 11:31 PM
