spring TSB and steering/alignment? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > 2nd Generation (2005+)
2nd Generation (2005+) Discussion area for the 2nd generation of the Toyota Tacoma
Old 09-15-2007, 08:04 AM   #1 (permalink)
driveline vibration
04asphalt's Avatar
View 04asphalt's Photo Gallery
Exclamation spring TSB and steering/alignment?
I have the issue with my truck handling like crap on the highway,never got the alignment adjusted "out of spec" to correct it like recommended here.
anyone have this issue before having the TSB and after with the new alignment have the truck stop drifting on the highway?
04asphalt is offline   Reply With Quote
Old 09-15-2007, 09:01 AM   #2 (permalink)
View yrffej's Photo Gallery
not sure what your really saying or asking....
but it's more than a recomendation from the people here.... an alignment, is part of the tsb.... your svc dept got paid for it by toyota... i happened to ask for a print-out of before and after specs, to insure it was done. (although i was there waching it happen, whole tsb took 3hrs soup-to-nuts) which included having them change the differential fluid, which i felt was fair to pay for out of pocket. considering what toyota gave me for free....
'05 prerunner access trd sprt pkg1 w/tow & trd catback
yrffej is offline   Reply With Quote
Old 09-15-2007, 11:21 AM   #3 (permalink)
project-c2's Avatar
View project-c2's Photo Gallery
When I first got my truck. I took it to work and did the alignment, cause it pulled to the left on flat ground, no grade. The casster and toe was actually in the red. I used the Hunter alignment rack with the reflectors. Now it tracks straight. I since installed my SOS lowering kit and redid the alignment.
2007 SWB X: BHLM|FLM|OEM HID (IS350) retro|S2K antenna|17% Tint FS|DTRL|TRD seatcovers|TRD CAI|URD MAF calibrator|URD SS|brushed emblem|B/O Scoop|SOS drop w/DJM steel blocks|Eurolite Plasma: int., rev. light bulbs|Nokya 2500K FL|Hellwig EZ 550 springs|JBA exhaust|BSP XR emblem|Tailgate TSB|TTC alarm
project-c2 is offline   Reply With Quote
Old 09-22-2007, 10:17 AM   #4 (permalink)
driveline vibration
04asphalt's Avatar
as it is now my truck dosen't track well at highway speeds, several folks here told me if the alignment was corrected slightly outside what toyota spec. calls for it would be good.
my ?? is with the new springs and alignment from the tsb has anyone who had poor tracking seen an improvement?
Old 09-22-2007, 06:24 PM   #5 (permalink)
Gameroom cash: $164485
View HotRod53's Photo Gallery
I had the TSB and alignment and had no problem. Do you know that the spec for the alignment was changed with the TSB, maybe your dealer did the TSB and used the original alignment spec?? I can tell you that mine handled differently after the TSB, but not diferent in a way that I would say was bad. I recently had it up to 85 MPH and had no handling problem, so I would say that mine is good.
HotRod
'06 Tacoma DC, Super White, Leer 100R, bed mat, K&N, Weathertech liners and vent visors, TSB 4 pack springs, Ride Rite air bags, TSB Cat converter, TSB exhaust manifolds, driving light mod, repaired my compass (3 times), 162K+. '06 Camry XLE, V6, '07 Camry XLE I4.
HotRod53 is offline   Reply With Quote
Old 09-23-2007, 07:25 AM   #6 (permalink)
Janster's Avatar
View Janster's Photo Gallery
If everything is bone stock and all you're adding is the TSB rear leaf springs....
I'm VERY curious to know why an allignment is necessary? These trucks don't have anything to *allign* in the rear. They're not 4-wheel alligned.
I've read the TSB only raises the rear anywhere from 1-2" higher which isn't all that much and I'm really amazed it woud change the handing that much. Make me wonder what the Toyota techs are doing to the truck when they install these TSB springs. Unless they installed something improperly..... obviously I'm missing something.
Do you have lift coils or spacers on the front? If YES - then an allignment could possibly help. How much lift do you have in the front?
http://www.lieblweb.com/
Janster is offline   Reply With Quote
Old 10-03-2007, 05:38 PM   #7 (permalink)
driveline vibration
04asphalt's Avatar
Question
not done the tsb yet but was wondering if the highway wandering would improve or even get worse?? alignment spec changed with tsb??????
Old 10-04-2007, 05:28 AM   #8 (permalink)
View fishindude's Photo Gallery
i noticed that the truck handles a lot better after i got the tsb and the alignment done. prior to the work, the stearing wheel used to shimmy and pull to one side while doing 65. now it runs super straight and no stearing vibration.
'06 silver mica TRD Off Road double cab 4X4
mods:
BFG 265X75X16 all terrain, flowmaster 40 series dual exhaust, rear tsb, 5100 all around set at 1.75, 5% tint, fog light mod, sylvania silverstar headlights and fog lights, scan gauge II, TRD seat covers, Snugtop sport camper, ipod2car
fishindude is offline   Reply With Quote
Old 10-04-2007, 06:37 PM   #9 (permalink)
driveline vibration
04asphalt's Avatar
mine never pulls, it just drifts backnforth. more like the steering is too touchy at highway speeds. at lower speeds it tracks straight with hands off the wheel
Old 10-04-2007, 07:52 PM   #10 (permalink)
View forbye's Photo Gallery
hmmmm
i am interested in having the tsb work done, however , i am a bit hesitant cuz my truck runs perrrrfectly, other than the rearend sag with a load
06 Radiant Red V6 4X4 Access Cab SR5 Rear Spring TSB bedmat weathertech liners michelin ltxat2
forbye is offline   Reply With Quote
Old 10-04-2007, 09:10 PM   #11 (permalink)
try checking your tire pressure, too high a pressure, usually does what you describe.
Old 10-04-2007, 09:57 PM   #12 (permalink)
Keep On Keepin' On
hankthecowtruck's Avatar
View hankthecowtruck's Photo Gallery
It's not a tire pressure problem. I mean, unless it's a tire pressure problem. Some of these trucks have a definite steering challenge. Mine is one of them. They did the TSB on mine but *cough cough* ordered the OLD parts and put them on again!!!!! So now it drives a LITTLE better than it did at hwy speed, but still not good or comfortable. This is definitely something I hope the TSB gets sorted out, because my shoulder actually hurts after driving for a while from fighting the damn wheel so much, and yeah, it has been aligned. Twice now. If after the TSB being done correctly it still isn't tracking correctly and driving comfortably, 'not sure what I"ll do. Maybe try different tires? It seems discouraging to have to throw down money for tires but something's gotta be different cause road trips just aren't even an option with the steering this way.
hankthecowtruck is offline   Reply With Quote
Old 10-05-2007, 10:07 AM   #13 (permalink)
View suv-man's Photo Gallery
I got my Tacoma 4x4 TRD v6 '07 about four weeks ago. I am having some issues with steering as well. Mine too wonders on the road and seems to steer itself. If I go on a devided hiway, in the inner lane (road crown slopes to the left) I have to hold the steering wheel to the right, about 10 degrees in order to go straight. Even if I go in the right lane the vehicle sometimes pulls to the left... The dealer supposedly re-aligned the front end, however I cannot notice any difference... Also, if I stop at the light in the left lane, if I let the steering wheel go while decelerating (at about 5mph) to a stop, the steering wheel turns to the left by a good half turn. I have the stock leafs in the back... Any suggestions? Does the alignment TSB refer only to the leaf replacement TSB or to any new trucks? Any help would be appreciated.
suv-man is offline   Reply With Quote
Old 10-05-2007, 10:13 AM   #14 (permalink)
sechsgang's Avatar
View sechsgang's Photo Gallery
I had to go back after the leaf TSB to have the alignment done again. The steering wheel was off center going straight, no other symptoms, though.
It's straight now after the second alignment, and everything is ok. I am not even sure they did an alignment in the first place after installing the springs. Got to watch out for that, it's needed!
sechsgang is offline   Reply With Quote
Old 10-05-2007, 10:38 AM   #15 (permalink)
View Badlees's Photo Gallery
Tire Pressure like stated above. Drop it down some where in the middle of what the door says (29 PSI) and what the tires say. In my case it's 35 psi cold so I set the pressure to 32 psi all the way around. Once I did that the trucks steering was so skittish and I didn't wonder all over the lane I was in. Try it.
Badlees is offline   Reply With Quote
Steering/Alignment Question...2002 Corolla LE cement406 Archived Corolla threads 7 04-18-2007 04:23 PM
